Old 12-17-2014, 03:27 PM   #141
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
This is fantastic! Sub'd for sure!
- The Ancient BRZ Sacrament
by Zaku
Old 12-18-2014, 06:21 AM   #142
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
looking for a cage and I found this
cusco / safety21 makes a weld-in chromoly FIA-approved rally / GT cage... the price is surprisingly not that bad relative to having local shops cage the car, and the design is definitely above and beyond what most of them could do
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
The Following User Says Thank You to SomeoneWhoIsntMe For This Useful Post:
GT86_PRAGUE (12-18-2014)
Old 12-18-2014, 08:19 AM   #143
GT86_PRAGUE
Drives: GT86
Forgive my ignorance, but if you are getting new motot, new chasis/case, new everything, so what will you use from original car? Registration number?
Anyway, I wish you a success in your dream.
GT86_PRAGUE is offline   Reply With Quote
Old 12-18-2014, 08:41 AM   #144
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
Originally Posted by SomeoneWhoIsntMe View Post
http://www.ft86club.com/forums/showthread.php?p=2058520
listed the engine and trans for sale, people are talking shit about the price. anyone have any idea what that stuff is honestly worth / what I should be asking for it?
Transmissions are going for 750-850 on the forums, so you're close with your thoughts. Engine is worth scrap, so $75.
Not trying to be a ****, but I doubt anyone would want to use that engine since the fire was located at/on the motor.
He's reusing the chassis, just looking at a roll cage for it. The pictures shown are what it would look like installed and painted.
Travisty75 is offline   Reply With Quote
The Following User Says Thank You to Travisty75 For This Useful Post:
Old 12-18-2014, 08:49 AM   #145
SomeoneWhoIsntMe
@GT86_PRAGUE the picture is confusing because everything is painted white, the cusco product is just the roll cage tubing and gussets inside. I'm using the chassis that was in the fire, the rear diff + subframe + suspension, and I suppose that's about it.
You got it though, the registration number is still valid, so after I go through an inspection process, because it's listed as repairable salvage currently, I can actually register it and put it back on the road eventually.
Old 12-18-2014, 08:54 AM   #146
SomeoneWhoIsntMe
@Travisty75 I guess I'll probably wind up tearing the motor down to the shortblock and cleaning that up, and parting the shortblock / head castings / transmission, but that's a lot more work than I had wanted to bother with on a motor I'm not even using. oh well.
Old 12-18-2014, 09:06 AM   #147
GT86_PRAGUE
Drives: GT86
It is a lot of work and effort, you must have a lot of time and skills.
Good luck.
The Following User Says Thank You to GT86_PRAGUE For This Useful Post:
SomeoneWhoIsntMe (12-18-2014)
Old 12-18-2014, 09:18 AM   #148
Travisty75
Travisty75's Avatar
I'd like to pick up a long block, but I'm not willing to grab one for that much money. If you're rethinking the price, throw me a PM or message me from MI86/Facebook.
Old 12-18-2014, 10:31 PM   #149
SomeoneWhoIsntMe
The Following 2 Users Say Thank You to SomeoneWhoIsntMe For This Useful Post:
JTOFJPN (10-16-2015), slicktop (12-21-2014)
Old 12-19-2014, 04:56 AM   #150
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
pretty cool build sofar keep it up
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 12-22-2014, 07:08 AM   #151
SomeoneWhoIsntMe
so, motoiq is occasionally useful:
from http://www.motoiq.com/MagazineArticl...ubaru-BRZ.aspx
"Since the stock electric power steering does not have enough oomph and fades in hard use, a Camry steering rack was used because it had the same mounting bolt span as the stock FR-S rack. To reduce bump steer and to increase rack travel, outer tie rod spacers were made to allow more rack movement and provide a solid steering stop to prevent rack overtravel. The spacers put the outer tie rod joints in line with the lower control arm pivot. Solid rack bushings were machined to get rid of excess slop."
They don't explicitly say what camry that steering rack is from, but I'm pretty sure it has to be rack #26-2630. Looking that number up in cardone's catalog lead to me finding that there's another rack that uses the same mounting centers, #26-2632, from the Toyota Avalon. The Avalon rack looks to be about the same ratio, with a slightly longer throw, or at least a little wider. Ordered a reman rack from Detroit Axle on ebay for $120 shipped.
The Following 3 Users Say Thank You to SomeoneWhoIsntMe For This Useful Post:
Jive Turkey (01-07-2015), Travisty75 (12-22-2014), Ultramaroon (12-22-2014)
Old 12-22-2014, 02:26 PM   #152
Travisty75
Travisty75's Avatar
Interesting find! Looking forward to your thoughts on the rack once you get it installed and the car moving.
Old 12-29-2014, 02:37 PM   #153
SomeoneWhoIsntMe
my SSR gartmaiers showed up from japan finally.
I think I'm going to build just one single rear wheel first to make sure the lips and barrels I want to use actually fit, I'm going to do 18x10.5 -32 in the rear to hopefully get me pretty close to good fitment without having to run a huge spacer.
Old 01-24-2015, 06:05 AM   #154
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
@SmsAlSuwaidi you gotta see this thread.
Yamajee is offline   Reply With Quote
Dreams Priapus Off-Topic Lounge [WARNING: NO POLITICS] 15 08-04-2014 11:57 PM
Front pipe choices, resonated vs straight pipe jflogerzi Engine, Exhaust, Transmission 4 12-29-2013 10:14 PM
Garage Life: We bring your dreams to life! Garage Life Southern California 0 08-17-2012 07:33 PM
BRZ/FR-S Dreams? MrBRZ Off-Topic Lounge [WARNING: NO POLITICS] 7 03-22-2012 08:55 AM
Dreams about the BRZ 86'd BRZ First-Gen (2012+) — General Topics 20 02-25-2012 10:58 PM
