Old 12-16-2014, 09:17 PM   #85
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
You mean the people that stick the engine so far out the back of the car it looks like a hemorrhoid and steers itself as the anchor swings the tail like a skank on ladies night? Understeer that turns into violent snap oversteer, yeah; give me some of that! I really don't care about their philosophy of car design.
Old 12-16-2014, 09:32 PM   #86
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
The 928 is front engined
Sure, I appreciate that but it would seem that some people do like it.
Old 12-16-2014, 09:35 PM   #87
themadscientist
Hotlink Terrorist
So's the 944 Mr. U-boat commander.
And, I must say, the 944 must appeal to me since I love the FC and Mazda admits they totally ripped off the look of that Porsche.
GM put a flat four in the back of a car once. And?
Old 12-16-2014, 09:40 PM   #88
Captain Snooze
Drives: Red Herring
The 928 has rear steer, I do not know about the 944.
Old 12-16-2014, 09:45 PM   #89
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Originally Posted by slicktop View Post
Having toe out on a car can make it seriously unsafe to drive. That "rear wheel steering" is the beginning of an accident waiting to happen.
Stop. Just stop. Get your damn car aligned before you cause an accident.
Calm down. My car is aligned. The way the car is designed, it will toe the outside wheel out and the inside wheel in when it leans over. It doesn't mean you can parallel park the car sideways. I'm only mentioning it because I'm not used to my car leaning in the corners. I'm changing to the stiffer FR-S springs this weekend anyway.
KoolBRZ is offline   Reply With Quote
Old 12-16-2014, 09:52 PM   #90
whataboutbob
AutoX-10/10ths every run
[ame]http://youtu.be/CMNry4PE93Y[/ame]
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
JB86'd (12-17-2014), themadscientist (12-16-2014)
Old 12-16-2014, 09:55 PM   #91
themadscientist
Hotlink Terrorist
Originally Posted by KoolBRZ View Post
The way the car is designed toe the outside wheel out and the inside wheel in when it leans over.
Put stock tires on the back and steer with the throttle. It would be safer.
You described what my GT-R used to do at low speeds
I mixed up my acronyms earlier. Atessa is the AWD gear, Hicas is what I meant to say.
At high speeds, Hicas turns the rear wheels WITH the front wheels, not against. Most people install a locked rack to eliminate the rear steer altogether which is what my car has.
You are building a suicide machine.
Old 12-16-2014, 10:57 PM   #92
KoolBRZ
KoolBRZ's Avatar
I'm not building a rear-wheel steer machine, I believe what I've been talking about is the automatic rear-wheel tracking that comes stock on the triplets. As the vehicle leans over the rear wheels are adjusted a tiny amount by the tracking arms so that they follow the tracks of the front wheels. This "tracking" helps the car to corner better at higher speeds and helps reduce under-steer. The effect can be exaggerated by aligning the rear wheels so the toe angle is 0%, and can be reduced by increasing the toe angle. So then, rear toe angles being equal, the BRZ will over-steer because it leans more, and the FR-S will under-steer because it leans less. I have BRZ rear springs on and that's why my car over-steers more than I'm used to.
Old 12-16-2014, 11:17 PM   #93
Fastbrew
Drives: 2014 Pearl White BRZ
My BRZ has a reactive organic steering and control compensation device. It's called the driver.
Fastbrew is offline   Reply With Quote
Old 12-16-2014, 11:32 PM   #94
What about roll steer?
I'm on board with this.
Old 12-16-2014, 11:52 PM   #95
I'm not on board with this.
Old 12-16-2014, 11:58 PM   #96
totopo
Drives: 370z
ehhh? i am pretty sure the rear suspension toes in on compression and out on extension.
totopo is offline   Reply With Quote
Old 12-17-2014, 12:02 AM   #97
totopo
Drives: 370z
ehhh? leaning has nothing to do with weight shift. Aren't the fr-s rears higher spring rates than the brz? High spring rates means more weight shift on that axle means less traction.
So the brz with less spring rates has less weight shift on the rear and will be more neutral understeer...
Old 12-17-2014, 12:04 AM   #98
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
That's bass ackwards.
Kotu100 is offline   Reply With Quote
Well this sucks. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-16-2014 10:18 PM
Getting OLD kinda sucks... blackhawkdown Off-Topic Lounge [WARNING: NO POLITICS] 44 06-13-2014 10:41 AM
Elitism..sucks RedLeader Other Vehicles & General Automotive Discussions 60 01-29-2014 04:09 PM
NY sucks Hardrock4445 Off-Topic Lounge [WARNING: NO POLITICS] 35 01-18-2013 09:28 AM
