Old 12-16-2014, 04:10 PM   #71
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
See the toe/camber link?
I am not familiar with steer on the rear of these cars. Could you point me in the direction of where I'd get more information?
Check out this link http://www.ft86club.com/forums/showthread.php?t=3002 . It shows a pic of the right side rear and the Toe/camber link is directly in front of the axle. I copied the pic and circled it below. since it is neither a horizontal, nor a vertically fastened link, it changes both camber and toe when the suspension is either compressed or extended beyond normal ride height. That means that, yes, it changes both camber and toe when you lower your car. This is one reason to keep the stock ride height. So the rear wheel steering will continue to work correctly.
KoolBRZ is offline   Reply With Quote
Old 12-16-2014, 04:41 PM   #72
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by KoolBRZ View Post
I'd rather have predictable understeer than unpredictable oversteer.
So you're switching the suspension on a car that was tuned to have a more neutral setup and undertsteer for the suspension from a car that was tuned to have a rear biased setup that would induce more oversteer?
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
slicktop (12-16-2014)
Old 12-16-2014, 04:47 PM   #73
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
That alters toe only. This is why they are called toe links or toe rods. Rear camber is altered via camber bolts or the lower control arm which is not doable with stock lower control arms. Hence the need for aftermarket lcas.
You have not answered my question. The fact that the toe and camber changes when the car is lowered (or raised for that matter) is well known and is easily corrected. I am more curious about the rear wheel steering.
Old 12-16-2014, 05:05 PM   #74
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Ok...
This is my response to this thread...
[ame="https://www.youtube.com/watch?v=C3JzbWVDzac"]Billy Madison - "Everyone in this room is now dumber for having listened to it" [Legendado] - YouTube[/ame]
Jaden
Jaden is offline   Reply With Quote
The Following 3 Users Say Thank You to Jaden For This Useful Post:
brandonblt2 (12-16-2014), Shark_Bait88 (12-16-2014), themadscientist (12-16-2014)
Old 12-16-2014, 05:09 PM   #75
Calum
That Guy
Drives: 2013 asphalt FRS MT
The length and thus the arch that the upper and lower control arms move through are what determine the camber curves, not the toe link. You may have too much toe out at the moment but that is adjustable via said toe links if you get an alignment.
I can't believe you've spent that much time and money replacing suspension parts but you haven't bothered to sort out your alignment. The alignment will make a large difference in the feel of the car, especially the symptoms you've described. Also if you read the threads/reviews on any damper they'll tell you there is a break in period.
The Following User Says Thank You to Calum For This Useful Post:
Old 12-16-2014, 05:17 PM   #76
Captain Snooze
Drives: Red Herring
Do the triplets exhibit rear roll steer? Given the wheel side/outside of the toe arms travels in an arc with wheel movement. When cornering could there be unequal amounts of compression and rebound that result in differing left/right toe changes?
Old 12-16-2014, 05:25 PM   #77
KoolBRZ
KoolBRZ's Avatar
No, that isn't what I mean. My alignment is better than stock. I'm just not used to feeling the rear wheels helping me around the corner because I have had stiffer springs on the rear for the last 10 months. The car has to lean to create a noticeable turning effect.
Old 12-16-2014, 05:28 PM   #78
Shark_Bait88
Ok, I'm definitely convinced that this is an incredibly elaborate troll thread now.
Calum (12-16-2014)
Old 12-16-2014, 05:38 PM   #79
Calum
That Guy
Peace out koolbreeze.
Old 12-16-2014, 07:22 PM   #80
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
Wat. Rear wheel steering? Please stop.
I've copied the exact alignment specs that i run on my m3 to my brz and it has drastically change the behavior of the car. You are doing something wrong and trying to find a way to justify it
Digitalanalog is offline   Reply With Quote
Old 12-16-2014, 07:46 PM   #81
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Having toe out on a car can make it seriously unsafe to drive. That "rear wheel steering" is the beginning of an accident waiting to happen.
Stop. Just stop. Get your damn car aligned before you cause an accident.
slicktop is offline   Reply With Quote
Old 12-16-2014, 07:51 PM   #82
Captain Snooze
Drives: Red Herring
What about roll steer?
Old 12-16-2014, 08:33 PM   #83
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
As the owner of an Atessa equipped Nissan and a DTSS equipped Mazda I can say, rear steering is bullshit.
Old 12-16-2014, 09:03 PM   #84
Captain Snooze
Drives: Red Herring
I suspect Porsche may beg to differ.
Well this sucks. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-16-2014 10:18 PM
Getting OLD kinda sucks... blackhawkdown Off-Topic Lounge [WARNING: NO POLITICS] 44 06-13-2014 10:41 AM
Elitism..sucks RedLeader Other Vehicles & General Automotive Discussions 60 01-29-2014 04:09 PM
NY sucks Hardrock4445 Off-Topic Lounge [WARNING: NO POLITICS] 35 01-18-2013 09:28 AM
