Old 12-15-2014, 10:18 PM   #57
Originally Posted by Koa View Post
ugh Kool, I really am starting to think you're the world's most elaborate method-actor or troll... you do so much dang tinkering for the silliest things and report the most odd problems
It's The Couve so you may be onto something. ...sadly.
Old 12-15-2014, 10:20 PM   #58
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I don't know what the toe/camber links are actually called. That's just a descriptive name I use for them. There are short links on the rear suspension that changes the toe angle based on how compressed or extended the suspension is. The result is, a rear end that turns when it leans. It points the wheels to the outside of a corner, helping to rotate the car. It also tends to turn the car a lot sharper than you intend as soon as the weight shift starts causing body lean. I knew it was there, but this is the first time it was causing me to over-correct in a corner. The softer rear springs of the BRZ are inducing oversteer by increasing body roll, which makes the toe rods change the direction the rear tires are pointing. I'd rather have predictable understeer than unpredictable oversteer.
KoolBRZ is offline   Reply With Quote
Old 12-15-2014, 10:53 PM   #59
Bergen23
Drives: '15 Halo FR-S
I can't even
Bergen23 is offline   Reply With Quote
Old 12-15-2014, 11:06 PM   #60
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by KoolBRZ View Post
There are short rods on the rear suspension that changes the toe angle based on how compressed or extended the suspension is. The result is, a rear end that turns when it leans. It points the wheels to the outside of a corner, helping to rotate the car.
I am not familiar with steer on the rear of these cars. Could you point me in the direction of where I'd get more information?
Old 12-15-2014, 11:11 PM   #61
redlined600
redlined600's Avatar
Drives: Fr-s
I think you should look at the rear suspension a little closer.
redlined600 is offline   Reply With Quote
Old 12-15-2014, 11:12 PM   #62
swarb
first you need anti-reversion headers so you have have all that torque down low at 2k rpm/20mph
second you need frs springs in the front and brz in the rear, make sure your tow rods are set correctly.
I am not familiar with active steer at the rear on these cars. Could you point me in the direction of where I'd get more information?
Old 12-15-2014, 11:32 PM   #63
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Monty Python and the Holy Coilovers.
LOL.
Stang70Fastback is offline   Reply With Quote
Old 12-15-2014, 11:53 PM   #64
Racecomp Engineering
I will say that of all of the post/threads I have ever read on all forums since 1999 this one is the most ....."interesting"....by far !
Myles
Old 12-16-2014, 12:10 AM   #65
pantdino
Drives: Firestorm 2013 FR-S
If you all figure out how to make my '13 FRS ride less harshly, let me know.
In my '95 M3 I know the road is not completely smooth, but the 2-3mm bumps are smoothed just enough they don't get annoying. In the FRS I swear I could feel driving over a penny.
That is unnecessarily harsh for a street car.
And PLEASE don't tell me BMW doesn't know anything about suspension design.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 12-16-2014, 12:16 AM   #66
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Shouldn't you be working on a new forum name?
Old 12-16-2014, 12:49 AM   #67
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I like this guy, he test everything himself & focus on wuts important to him ONLY. Can't wait to see more haha
Old 12-16-2014, 09:26 AM   #68
jvincent
jvincent's Avatar
*shudder*
Don't worry, KoolBRZ isn't our favourite lawyer from Calgary.
If I am wrong, then I have severely underestimated Suberman's writing skills.
Old 12-16-2014, 12:35 PM   #69
KoolBRZ
KoolBRZ's Avatar
Are you still on the stock tires? I have 3 sets of tires I've tried, all sized 215/45/17. Les Schwab studless performance, Michelin Primacy, (stock), and Michelin PSS2. The PSS2's have very firm sidewalls and don't soak up the bumps. The best riding FR-S I've driven had stock suspension and 225/45/15 performance all-season tires. It rode better than my wife's 2011 Corolla. He had groceries in the trunk, so I couldn't really pitch it into the roundabout's without scrambling some eggs, if you know what I mean. That's what really blew my mind. All this guy did to his FR-S to get a better ride was get a slightly bigger set of tires. You already have FR-S suspension, so you're halfway there. I will be mounting my Bilstein HD shocks with FR-S springs this weekend. I want to try using the tophats from my HKS struts because they soak up more vibration and have camber adjustment in front. I won't know till next week, but I think your best ride is with the FR-S spring rates of 2.7 N/mm front to 3.7 N/mm rear.
Old 12-16-2014, 01:28 PM   #70
DAEMANO
Time Traveller
Originally Posted by Mr.Impreza View Post
This is actually how i feel with my Subaru. I have the Cusco Zero 2 coilovers and for the first year thought it was cool and loved them but now regret the purchase everyday because it drives pretty bad haha....good luck getting a coffee in that car
It's why I'm not planning to touch the suspension on this car. People say it has a wheel gap...i don't really think so...it's already so low and looks good. Also when a car is lowered you lose a lot o the fun factor unless your on a race track.
Only thing i may consider in the future is TRD springs
TRD Springs on stock struts will feel hard (supposedly they're the same as Eibach Pro-Kit which is firmer than stock). If you want more comfort, choose either a slightly softer but not too low spring (like "RS*R Down Sus" (not "Superdowns" unless you change the bump stops too) or go with a softly sprung coil like ST Coilovers, or RS*R Black-i or Sports-i.
Well this sucks. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-16-2014 10:18 PM
Getting OLD kinda sucks... blackhawkdown Off-Topic Lounge [WARNING: NO POLITICS] 44 06-13-2014 10:41 AM
Elitism..sucks RedLeader Other Vehicles & General Automotive Discussions 60 01-29-2014 04:09 PM
NY sucks Hardrock4445 Off-Topic Lounge [WARNING: NO POLITICS] 35 01-18-2013 09:28 AM
