Old 12-16-2014, 11:06 AM   #1
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Decompressing stock springs by jacking?
Hi all,
I've seen a few methods on youtube where people get around using a spring compressor by undoing the strut locknut up top and then slowly jacking the front of the car to decrompress the spring.
Obviously, this isn't the most conventional method but is it safe enough? Only issue I see is that there is unecessary downward load on the swaybar end-link as you jack the car up and the wheel starts to droop.
Has anyone attempted this before? This is where I got the inspiration:
[ame="https://www.youtube.com/watch?v=4C-ZUGi4R-Q"]Car Noob Ep. 7 - FR-S / BRZ Lowering Springs - YouTube[/ame]
Purpose is to reuse some of the items on the camber plate that I have installed on my stock struts in preparation for coilovers.
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 12-16-2014, 11:21 AM   #2
cnk
Drives: '13 DGM BRZ Limited
There's a post in the DIY section where some folks have done it that way.
http://www.ft86club.com/forums/showt...hlight=springs
You can get spring compressors at Pep Boys or Advanced Auto for like $30-50 or you can rent them. I would personally go that route instead, but the choice is yours.
Old 12-16-2014, 11:41 AM   #3
Koa
While not recommended for all McPherson setups, I and others (mostly thanks to Jeebo, mentioned by cnk above) have found you can undo the nut of the front struts while the car is on the ground, and then simply jack the car up and take off as normal. It will pop down, but the force is so neglible that it has been determined a safe procedure to do. I personally have done this twice on the twins, once on my friend's, and once on mine. Each time was as predicted.
YMMV but I doubt it! Have fun
The Following User Says Thank You to Koa For This Useful Post:
1Cor10:23 (12-16-2014)
Old 12-16-2014, 11:42 AM   #4
d1ck
Drives: Black 2013 FRS
You can stand it up on the floor and have someone lean on the mount while you take off the top nut.
d1ck is offline   Reply With Quote
The Following 2 Users Say Thank You to d1ck For This Useful Post:
1Cor10:23 (12-16-2014), tahdizzle (12-22-2014)
Old 12-16-2014, 11:45 AM   #5
1Cor10:23
1Cor10:23's Avatar
Perfect, thank you!
Old 12-16-2014, 11:46 AM   #6
Koa
A little bit more tricky to do when operating pass through wrenches, hands and bodies tend to get in the way. But yes you can!
The on-car method can be done solo, however
Old 12-16-2014, 12:23 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I did my springs that way by myself no issues. Just followed the DIY here on the forum
Old 12-16-2014, 12:29 PM   #8
Koa
Me too, actually. I bought Sportlines that were attached to stock struts from a member on here a few weeks ago (he said he didn't have the tool to remove them ), so I just leaned on them while tackling the bolt with a T-bar allen and passthrough driver. Not that bad innit.
I have found the on-car method to be waaaay easier, though, so that's what I'm underlining
finch1750 (12-16-2014)
Old 12-16-2014, 01:21 PM   #9
1Cor10:23
1Cor10:23's Avatar
@Koa with on car method, do you find there's unnecessary load on the swaybar end link? I can't fully visualize it now but I feel that typically a lot of the load would be on the strut lock nut/bolt and not on endlink. Any thoughts/watchouts?
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
Koa (12-16-2014)
Old 12-16-2014, 01:58 PM   #10
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
If your that worried about the swaybar end link, why not just disconnect it first. Im the one in that video doing the work, ive done this for years when i didnt have a spring comp available. i have them now, but even then this is so much faster, the only part that suck is i haven't found a pass through socket for the rears, but ive only done one other set of springs since this video last year. most get coilovers..
-Thomas
86SPEED is offline   Reply With Quote
The Following 2 Users Say Thank You to 86SPEED For This Useful Post:
1Cor10:23 (12-16-2014), Koa (12-16-2014)
Old 12-16-2014, 02:59 PM   #11
M23
Drives: 86
Yes, it works; and works good. I've been using this technique since the early '90s on several different cars.
M23 is offline   Reply With Quote
Old 12-16-2014, 03:02 PM   #12
Koa
-Thomas
For the rears, it truly will have to be a "lean on it and unbolt" scenario innit, GL OP have fun!
Old 12-16-2014, 08:40 PM   #13
1Cor10:23
1Cor10:23's Avatar
Won't have to worry about rears, that can stay I'm one piece - just have to get my camber plates off the fronts!
Old 12-16-2014, 09:10 PM   #14
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
This. ANd the kicker is that the rent ends up being FREE! There's no need to use awkward or dangerous methods to compress or decompress your springs. Unlike some cars, the strut assemblies can be removed in one piece on these cars. You can then safely disassemble them on a workbench in a safe matter. Even though Subaru uses very little pre-load, it's good practice to work with springs in this manner.
Safely Jacking and Supporting Your BRZ/FR-S GrimmSpeed DIY (Do-It-Yourself) Guides 152 06-11-2021 07:44 AM
Topside oil change without jacking up car DJCarbine DIY (Do-It-Yourself) Guides 35 11-13-2014 09:52 AM
FS: Openflash, Weathertechs,Mtech Trasmission Springs, Stock Exhaust, Stock intake Brahsbrah Canada Classifieds 11 11-09-2014 11:03 AM
Jacking a lowered BRZ/FRS? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-19-2013 02:04 AM
Car Jacking up Points? J-Money Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-21-2013 02:55 PM
