Old 12-13-2014, 06:45 PM   #29
FirestormFRS
Originally Posted by wootwoot View Post
I hope not. I am missing one of the power block gaskets. But I think that is too big to fall in the motor.... It's likely on the floor someplace.
If I did have something in the block, what would the car do? I confirmed nothing was in the intake valves visually after it didn't start the first time.
Once you crank that thing over whatever may have been there will be ingested and destroyed....just so ya know.
Check all your wire harness connections. You may have half locked one. Just disconnect and reconnect all of em. Happens a lot more than you think.
FirestormFRS is offline   Reply With Quote
Old 12-13-2014, 06:48 PM   #30
wootwoot
Drives: FRS
Figured as much. And I think that is likely what happened. Are there any connections under the manifold I should look at? Or are they all exposed?
Old 12-13-2014, 07:06 PM   #31
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Forgot to connect MAP sensor?
Beat me to it. That's what it sounds like.
Old 12-13-2014, 08:09 PM   #32
kosoku
Drives: 2013 fr-s
Does it stay running if you give it a little bit of throttle?
kosoku is offline   Reply With Quote
Old 12-13-2014, 08:30 PM   #33
wootwoot
Drives: FRS
No. Throttle input does nothing.
Does that suggest it is not a vacuum leak?
Old 12-13-2014, 08:48 PM   #34
cjd
cjd's Avatar
Drives: 2017 BRZ
That suggests a rather bad leak, if that's indeed what's going on. It would mean the engine might be completely bypassing the manifold/TB/MAF (though this is my first car with a MAF so I'm speculating.) Missing gaskets are bad news if you're trying to run the car that way.
If it's any consolation, I once had the tube between the TB and manifold on a previous car sucked off the TB. It happened in the middle of stop-n-go Chicago rush hour traffic in a construction zone (was a 4" drop to pavement they'd carved off, no shoulder)... I was running a prototype CAI, and we learned something about just how much vacuum the car generates... also, that it's a bad (factory!) design to put a rubber tube between the TB and IM. In hindsight, it was a bad design on that first round of the CAI but ...
There's a BRZ FSM CD available for download in the BRZ forum if nothing else, should be the same for your troubles. This is something you're up to solving, it will just take patience, which is really hard to come by when your car has decided to stop working right after you tried to give it a little extra care...
FWIW, the smoke suggestion would be motor off. It does not take a lot of pressure to get smoke to show up where it shouldn't. Sometimes no pressure at all.
The Following User Says Thank You to cjd For This Useful Post:
wootwoot (12-13-2014)
Old 12-13-2014, 09:04 PM   #35
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
It is not a vacuum leak, if it was it would have to very large and therefore obvious. It's going to be a sensor or wire that is damaged or not connected. Check the throttle connection and wires, then MAF/MAP sensors and associated wires. Also check the pins in the connectors, sometimes they get damaged when disconnecting/connecting them.
Amaya is offline   Reply With Quote
The Following User Says Thank You to Amaya For This Useful Post:
Old 12-13-2014, 09:09 PM   #36
steve99
Drives: FT86
with ignition in "on" position check that when you depress throttle buttlerfly in throttle body moves. you will need an assistant.
The last guy with similar problem had a mouse chew throgh his airfilter and bits of filter got stuck in MAF sensor in intake tube causing car to stall after start.
Old 12-14-2014, 12:05 AM   #37
wootwoot
Drives: FRS
Success. Read first post.
Old 12-14-2014, 12:30 AM   #38
Amaya
Amaya's Avatar
Awesome!
Old 12-14-2014, 08:22 AM   #39
D K
Stig's dark passenger
Did you call the fire department?
D K is offline   Reply With Quote
Old 12-14-2014, 09:28 AM   #40
akyp
Drives: 2012 86
My anger toward Crawford was due to their instructions. They are aweful. And this install is a compete pain in the butt. In any event, lesson learned. Carry on.
Agree with bolded part. Been reading up on BPBs since they were released, but still hesitant to buy them as their instructions don't give me any confidence in doing the installation myself.
akyp is offline   Reply With Quote
Old 12-14-2014, 10:34 AM   #41
wootwoot
Drives: FRS
Ya. I will likely make a new thread this weekend outlining some tips for the install as I just got done with it. There is a lot that can go wrong with this one...
Old 09-07-2019, 08:23 PM   #42
Grips&slips
Drives: 99 mazda miata sport
Having this exact problem but I have triple checked everything including the grounding bracket. Any other thoughts?
Grips&slips is offline   Reply With Quote
OpenFlash Tuning Tutorial: Crawford Billet Power Block Mapping changes Shiv@Openflash Software Tuning 209 12-28-2022 09:21 AM
Scion FR-S Crawford Performance Turbo/Block Build newfienorthca CANADA 12 11-29-2014 10:24 PM
BRZ, FR-S, GT86 | Power Block Manifold Riser by Crawford Performance | UP TO 25% OFF! iA Performance Groupbuys 18 11-04-2014 04:25 PM
Crawford Power Blocks like new oTaGGeDo Engine, Exhaust, Bolt-Ons 0 07-27-2014 09:22 AM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 11:18 AM
