12-12-2014, 10:51 PM | #2521 |
Awesome. I want super short lines on my cooler. Thanks
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
12-13-2014, 02:07 AM | #2522 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
A friend did a video for me and the run..
[ame]http://youtu.be/A4uPtvBhdgY[/ame] |
12-13-2014, 02:07 AM | #2523 |
12-13-2014, 10:49 AM | #2524 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Does this kit delete/modify whatever the car was using for a oil temp sensor? I Can no longer see oil temp from my OBD2 bluetooth connector.
12-13-2014, 12:02 PM | #2525 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
12-13-2014, 12:31 PM | #2526 |
Car Nut
12-13-2014, 03:31 PM | #2527 |
Car Nut
12-13-2014, 03:31 PM | #2528 |
Drives: 2013 Asphalt FR-S
Need a replacement belt, and would like to get a spare as well... Should I the sales or support email address?
Less than 2000 miles on the belt. Is that normal? |
12-13-2014, 05:12 PM | #2529 |
Drives: 2013 Ultramarine FR-S
The Following User Says Thank You to Freeman For This Useful Post: | myd_lyf_crysys (12-14-2014) |
12-13-2014, 05:21 PM | #2530 | |
Wow that's to soon for the belt. 9,000 plus miles SC'ed and going strong. I relate a very un-tolerable loud whine with the belt being to tight.
The Following 2 Users Say Thank You to zoth For This Useful Post: | Freeman (12-13-2014), myd_lyf_crysys (12-14-2014) |
12-13-2014, 08:41 PM | #2531 |
Hey question for you guys, at what psi does the diverter valve close? I'm told at 3psi but not sure.just curious...
12-14-2014, 08:38 AM | #2532 | |
Drives:
I can wiggle my belt up and down approx. 1/2 inch. Is that ideal, or should I go a bit tighter? @KraftWerks @moto-mike
My STX build thread
http://www.ft86club.com/forums/showthread.php?t=55616 |
The Following User Says Thank You to xDanger_208x For This Useful Post: | myd_lyf_crysys (12-14-2014) |
12-14-2014, 10:45 AM | #2533 |
Drives: White scion frs
@xDanger_208x this is where you want to have it. The belt should not be as tight as your serpentine belt. If it moves half an inch this is where you want it. I had asked the same question to @moto-mike when I had belt dust all over my engine bay.
The Following User Says Thank You to John92 For This Useful Post: | myd_lyf_crysys (12-14-2014) |
12-14-2014, 10:49 AM | #2534 |
Drives:
I snugged it up a bit. The .5" I was getting wasn't stretching or stressing the belt at all. That was the amount it could move freely.
Also, that was the measurement in and out from where it rested. So in reality I had an easy 1" of loose movement.
My STX build thread
Similar Threads | ||||
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
