Old 02-12-2014, 09:52 PM   #1
MysteryMachine
MysteryMachine's Avatar
Drives: 2014 SWP BRZ, 2002 Bugeye OBS
Hum/hiss when audio off? (BRZ)
Hello everyone,
I have a buzz/hiss/hum coming from the speakers whenever the head unit is on (about half way through the splash screen it starts). Its not noticeable when actually driving. Its a constant so not tied to volume. Its not a big deal but I still want to troubleshoot if its normal since OEM Audio Plus told me it should be completely silent.
Can anyone comment if they have buzz/hiss? Especially those with aftermarket amp/speaker but stock head unit? I also notice its tied to the day/night setting of the nav display. In night, with the much darker UI, its just a slight hiss and not noticeable but when in day mode it has quite a buzz.
EDIT: I swapped back to stock temporarily just to test... exact same buzz/hiss except quieter (which makes sense since the amp is more powerful hence louder hiss/buzz). Crappy stock head units... grumble grumble
MysteryMachine is offline   Reply With Quote
Old 02-17-2014, 01:51 PM   #2
Chimera
Drives: FRS
I have the exact same thing in my frs when I upgraded the amp. Tried everything. I used a ground loop isolator, which quieted it to about the same as before amp upgrade.. About to do hu upgrade.. Hopefully this will solve permanently
Old 02-17-2014, 01:53 PM   #3
sshole
I've had the same thing since day 1 of ownership. No idea how to make it go away, but it really doesn't bother me since most of my time in the car is at 70+ mph...
sshole is offline   Reply With Quote
Old 02-17-2014, 04:44 PM   #4
MysteryMachine
Thanks much, Can you give some more details on your ground loop isolator?
Old 02-18-2014, 08:19 AM   #5
Chimera
Drives: FRS
It's a.. Bad.. Fix, I did it to see if it would work, but I spliced mine directly into the input of the amp.. I'll take a photo later this week
Old 02-19-2014, 01:51 AM   #6
labskaus
labskaus's Avatar
Drives: Toyota GT86
I have the same poblem ... I think the leyless system is resonsable for the dissortion
labskaus is offline   Reply With Quote
The Following User Says Thank You to labskaus For This Useful Post:
MysteryMachine (03-06-2014)
Old 02-19-2014, 02:19 AM   #7
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Haven't heard it yet. Driving a Limited, so it's keyless.
^GT5 Replay Photo Mode^
Old 02-19-2014, 11:02 PM   #8
kludger
kludger's Avatar
Drives: '13 Boxter S, '13 BRZ(gone)
I have the same hiss on a BRZ limited with OEM Audio+ and similarly I only notice it when listening with loud volume while the car is stopped and the music is some acoustic music with quiet section.
Not a deal breaker for me since I don't notice it most of the time and the systems sounds awesome otherwise, but would be cool if there was a reasonable fix.
kludger is offline   Reply With Quote
The Following User Says Thank You to kludger For This Useful Post:
MysteryMachine (03-22-2014)
Old 12-12-2014, 12:42 AM   #9
rdrdtheta
rdrdtheta's Avatar
Drives: 2017 Subaru BRZ Limited 6MT
Did changing out the head unit solve any of the hissing issue?
rdrdtheta is offline   Reply With Quote
Old 12-13-2014, 07:58 AM   #10
Chimera
Drives: FRS
Primary culprit for me was too much gain. I don't have this anymore, but I also replaced speakers, amp and hu.
My FR-S Audio Set-up...Need help afsefo Electronics | Audio | NAV | Infotainment 0 12-30-2013 05:25 PM
Air/hiss sound when depressing brake petal TM Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-10-2013 10:29 PM
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 04:34 AM
Need some audio help jpit Electronics | Audio | NAV | Infotainment 7 03-15-2013 05:09 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
