Old 12-11-2014, 04:27 PM   #1
toby714
Drives: whiteout
How many quarts of engine oil for cars with oil coolers
I was wondering how much engine oil is needed for cars with oil coolers. I have the perrin one. in a review for the perrin oil cooler, the writer stated 7quarts, seems like a bit much.
toby714 is offline   Reply With Quote
Old 12-11-2014, 04:49 PM   #2
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Usually you'll want to add 1 additional quart for the PERRIN oil cooler. The car takes 5 quarts for a normal oil change, so be sure to have 6 quarts handy if you're doing an oil change, thanks!
PERRIN_Chris is offline   Reply With Quote
Old 12-11-2014, 05:04 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://techinfo.subaru.com/proxy/712...316DSTIS_8.pdf
5.5-5.7 quarts depending on if you are doing filter change.
I usually do 6 quarts outright and it has been fine for 25k miles with many track events.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Teseo (12-11-2014), toby714 (12-11-2014)
Old 12-11-2014, 05:11 PM   #4
PERRIN_Chris
You're right! I just did an oil change this last weekend, and it took 5 with a filter. YMMV I guess.
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
Old 12-11-2014, 05:41 PM   #5
toby714
Drives: whiteout
-alex
thanks guys! man the dip stick for this car is so frustrating to read. ill try 6 with the oil filter.
Old 12-11-2014, 05:52 PM   #6
mav1178
mav1178's Avatar
You can make the dipstick easier to ready by sanding down the end where the oil is, all the way up to the "Full" level.
I should caution that 6 quarts is a bit on the full side, if you are doing everything by the book please try to add what is needed to fill up, but nothing more. Part of the fluid capacity assumes a dry crankcase; actual experience will tell you that you usually drain most, but not all the oil in the engine.
-alex
rb6freak (12-11-2014)
Old 12-11-2014, 06:32 PM   #7
JoeC
Drives: Subaru BRZ Limited
I agree. That 0w-20 is so watery thin and clear that when it's new it's really hard to read on the dipstick.
JoeC is offline   Reply With Quote
Old 12-11-2014, 06:41 PM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Depending on the oil cooler, it's possible that the added capacity will NOT drain. So an oil change will be the same as a car without a cooler.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
mav1178 (12-11-2014), toby714 (12-11-2014)
Old 12-11-2014, 07:16 PM   #9
PERRIN_Chris
That's right, for a new install, you'll want an extra quart though.
future engine configurations...and the cars they go into cdrazic93 Other Vehicles & General Automotive Discussions 1 10-07-2014 11:42 PM
WTB 6-quarts of Eneos Sustina 0w-20 FR-S Matt Want-To-Buy Requests 3 09-22-2014 11:48 PM
7 Quarts of Eneos 0w-20 OMNOM Mechanical Maintenance and Tools 3 04-12-2013 08:41 AM
5.8 quarts too much? Brimford Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-08-2012 10:36 AM
Engine Swaps and Kit Cars! merlin2111 Other Vehicles & General Automotive Discussions 27 01-27-2012 05:18 PM
