Old 12-10-2014, 03:58 PM   #5713
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by TemeCal View Post
It worked for a bit after he posted it, but it's no longer working. Tapatalk, Chrome, Safari, Firefox...none of them are showing now. If it's working for some of you, you must have it cached.
The image is hosted on his site, which appears to be gone now.
The site still works for me. I don't think I've ever been to it on this phone so it wouldn't be cached.
Old 12-10-2014, 04:01 PM   #5714
Calum
That Guy
Old 12-11-2014, 11:00 AM   #5715
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Probably dumb question, but how do you upload a new version of the tune if you don't have any more licenses available? Do you have to pay for each new version and license?
CarzCarzCarz is offline   Reply With Quote
Old 12-11-2014, 12:10 PM   #5716
olorin
olorin's Avatar
Drives: GBS Premium
License is per ECU, you can flash the ECU with as many tunes as you want. Also note the tune is specific to a license. At least when you are talking about EcuTech.
olorin is offline   Reply With Quote
Old 12-11-2014, 12:58 PM   #5717
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
I wonder what kind of gains I can hope for with e85, headers, and 69mm pulley.
JesseE is offline   Reply With Quote
Old 12-11-2014, 04:46 PM   #5718
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We reached 314-316whp on DSPORT's Dynojet on E85, with a full Tomei exhaust utilizing their EL header and the Type 80 exhaust, topping it off with the 69mm pulley.
Sincerely,
Zach
Old 12-11-2014, 05:32 PM   #5719
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
40 - 50whp
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 12-11-2014, 05:37 PM   #5720
CarzCarzCarz
Thanks for the info. So to upgrade from 8.65 tp 8.70 you have to buy another tune, or are updates included if you bought your tune from Delicious? (which I did)
Old 12-11-2014, 05:50 PM   #5721
brianhj
Drives: 2017 Camaro 1SS
Sincerely,
Zach
On tomei's site they show the UEL header doing a better job of removing the torque dip. Does this matter since we're S/C and the torque dip is basically gone anyway?
brianhj is offline   Reply With Quote
Old 12-11-2014, 07:26 PM   #5722
Calum
That Guy
Updates are included.
Old 12-11-2014, 07:44 PM   #5723
DeliciousTuning
That is true that the UEL does a better job at removing the torque dip, however, the Innovate kit does that for you. Where the Innovate kit lacks is top end, and that is why the Tomei EL compliments it so nicely. In my personal opinion, if you have an Innovate kit and you're adding a header because you desire more power, it would be silly to get an UEL design as it won't help you at all on the top end; at least not nearly as much as a quality EL design will.
Sincerely,
Zach
Old 12-12-2014, 12:40 AM   #5724
brianhj
Sincerely,
Zach
What if I don't care about the top end? I never go faster than 80 or so and I doubt I ever will. Should I go UEL? Would UEL give better mid and lower gains than EL?
Old 12-12-2014, 12:55 AM   #5725
8686
8686's Avatar
Drives: 86
Originally Posted by 8686 View Post
Did they replace the whole unit or the oil seals only?
On the other hand
I didnt get a reply from Sprintex yet.
thanks @SprintexUSA for the awsome support.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 12-12-2014, 12:57 AM   #5726
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
What did they tell you? I called them today and they told me a little oil consumption was normal but mine has eaten a good bit in only about 1500 miles....
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
