Old 12-11-2014, 02:33 AM   #2255
CSG Mike
CSG Mike's Avatar
Originally Posted by JZA View Post
Hi all,
I am a new FRS owner. I'd like to know a recommended alignment for a stock FRS with TRD springs. If I am going to get the alignment bolts and plates, where should i start with alignment?
Thanks for your input!
What are you doing with it?
Old 12-11-2014, 02:48 AM   #2256
JZA
Drives: AP2
Sorry. I meant tracking the car. Mostly in Norcal and maybe a few times in SoCal in the future.
JZA is offline   Reply With Quote
Old 12-11-2014, 05:21 AM   #2257
CSG Mike
CSG Mike's Avatar
You'll need camber plates and rear lower control arms.
Try starting at -2.4 all around, with 1/16" total toe-in on both axles.
Old 12-11-2014, 08:31 AM   #2258
OkieSnuffBox
Drives: '23 BRZ Limited
I don't see anything mentioned about the Ground Control setup, has anyone used it? I had very good luck with my custom valved Koni's from Ground Control on two different E30s (84-91 BMW 3 series).
$2100 gets you a full setup with camber plates.
If I had the $3500-4000 for a setup, I'd go straight to MCS or HVT w/ Vorshlag CC plates and call it a day. Especially since you can buy a set of MCS for $2800 from Stuart Maxcy with custom rates and valving.
Old 12-11-2014, 09:08 AM   #2259
ja1217
Drives: 2004 Toyota RAV-4 5M
Originally Posted by Campo View Post
That's not a bad idea, but I'm afraid that like you, I'll want to make changes in the future that a single adjustable won't allow. I know I'm not good enough yet, but the idea is to grow as a driver and car together. It sounds like you're doin great!
I wish I had the points available for Hoosiers, but we're starting with a 6 point car because it's auto. Technically it was a 10 point car when we drove it off the lot because we have a factory spoiler that adds 4 points too, but we'll probably remove that in favor of a diffuser or just nothing or a big wing that's worth the points.
Sent from Tapatalk
EDIT: Removed incorrect information
ja1217 is offline   Reply With Quote
Old 12-11-2014, 09:37 AM   #2260
enivid
enivid's Avatar
Drives: WRB JR BRZED
You'll also probably want rear LCAs for camber adjustment in the back, and a LSD to put the power down (and promote controllable rotation, as per your preference, beyond what the spring rates do).
Why did you reconfigure your lsd? That did you change?
enivid is offline   Reply With Quote
Old 12-11-2014, 11:14 AM   #2261
THEmailman
Drives: Raven 6MT
Originally Posted by ja1217 View Post
Well, I have good news for you - You do have enough points to run hoosiers! I'm 99% sure that you don't need to take any points for the automatic. In the rules you only have to take points if you "added" paddle shifters to the automatic, as in they weren't available from the manufacturer. Same thing with the LSD. Feel free to post the question up on the NASA TT forums though to be 100% sure.
So your car should be starting out with just +4 for the OEM wing, which I would remove. Also, I would make the diffuser a pretty low priority and only use it if you happen to have 2 points laying around after all your other mods. Also, I wouldn't run any wider than a 225 Hoosier R7, which in reality is as wide as most 245 street tires and this way it will only cost you 6 points.
The manual transmission is considered the base, thus the automatic with the paddle shifters is considered an addition. Its in the exact same way way with the oem spoiler example you mentioned. If it is not the domestic base trim than ot take points. Basically, anything above the most bare bones car in non-btm.
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
Old 12-11-2014, 12:04 PM   #2262
CSG Mike
CSG Mike's Avatar
Wanted/needed more lockup.
Old 12-11-2014, 12:06 PM   #2263
CSG Mike
CSG Mike's Avatar
"custom" doesn't mean "better". Unless someone's already done the footwork with a particular setup, it just means custom.
GC's stuff had a pretty bad reception in 2012 for performance use; strut knowledge from other strut platforms, including the WRX, does not carry over to this platform.
Old 12-11-2014, 12:14 PM   #2264
OkieSnuffBox
True, but valving to at least the spring rate and specific motion ratio is better than just the generic stuff.
Just trying to keep the suspension in the reasonable price range since it will only occasionally see HPDE/Auto-X and I'm not trying to be competitive in Auto-X or TT or anything like that.
Just have some fun.
Old 12-11-2014, 12:40 PM   #2265
enivid
enivid's Avatar
This recommended for all of us? Will CSG configure it before sending it out for some extra $$$?
Old 12-11-2014, 12:54 PM   #2266
buddy32
Drives: WRB Subaru BRZ Limited
http://www.ft86club.com/forums/showthread.php?t=68310
buddy32 is offline   Reply With Quote
The Following User Says Thank You to buddy32 For This Useful Post:
CSG Mike (12-11-2014)
Old 12-11-2014, 12:56 PM   #2267
CSG Mike
CSG Mike's Avatar
We haven't done enough testing with the OSG unit yet to determine if we want to offer a CSG-spec differential yet. Custom configuration on a OSG starts at $150, and goes up, depending on the labor and parts involved.
For the Cusco units, we know exactly how to set it up based on driving style and setup; we have much more experience with these. The Cusco unit also happens to be cheaper as well. Currently, we configure the Cusco unit for free if the requested/recommended changes are within the capability of the LSD without needing to swap parts.
Old 12-11-2014, 12:58 PM   #2268
Campo
Campo's Avatar
Drives:
Unfortunately, I already asked the NASA TT National Director about the paddles, and he said I had to take the +3. He said he had more bad news about the auto: I have to take +3 for non-standard gear ratios...
Makes getting this little sucker competitive a tad challenging - but that's what's so fun!
Yeah, the diffuser is definitely at the bottom of the list. Good thoughts on the Hoosiers though, thanks!
Yeah, and +3 for the gear ratios in the auto...
I'm not totally familiar with the rules around dyno reclassing, but might it be worthwhile to ask after I actually start competing (again, this is like 2016 I'm thinking)? The stock auto dynos around 163 at the wheels as far as I've seen. I'm guessing that with my e85 tune I'm maybe 185-195 at the wheels. I've done zero weight reduction yet and no dyno yet, so I'm not 100% sure where my lb/hp ratio is, but I might benefit from a dyno reclass, no?
"Fuck, you've gone completely sideways, man."
~Raoul Duke
Gas is pretty cheap considering you're buying liquid explosive dinosaurs.
Campo is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
