#5699 |
Drives: 2013 SWP BRZ
I get squeaking and it seems to be coming from the alternator pulley. I confirmed this when I had the belt off swapping the idler pulley thinking it was that. I moved the alternator pulley by hand and replicated the sound - so check and see if it possibly is that.
#5700 |
Drives: ft86
anyone thinking about running a larger coolant tank for the blower? running the perrin intake, should allow a large enough opening to run a tank in place of the intake air box.. Last edited by blown; 12-08-2014 at 05:44 PM. |
#5701 | |
PhoneFlash by EcuTeK
Here is the latest revision of the tune 8.70 overlaying 8.64 (which is identical in power to 8.65). The only difference in 8.65 to 8.64 was the switch over on port to direct injection. The biggest improvement was on the low end, from a dead stop to about 5K RPM. We focused in a lot hear to improve throttle response and add more torque to have more of a table top look versus a slow ramp up in torque. We definitely notice that on that street and makes for a fun drive. This was tuned on the 75mm pulley (stock headers) and we are not verifying the tune on the 69mm, 91 octane and E85. ![]() Cheers, William Knose Delicious Tuning |
#5702 |
Senior Addict
Drives: 86 GT
Excuse my lack of understanding, but wouldn't the sharper rise in torque at the low end make taking off more "sudden/jumpy"?
#5703 |
Drives: 86
Any one experinced a leak in oil seals of the SC behind the pulley.
I lost half of the SC oil in less than 1500 miles Sent from my iPhone using Tapatalk
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#5704 |
Drives: GT 86
#5705 |
Drives: 86
Thank You for the info.
I will email SPRINTEX about this
#5706 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Doesn't mean that all bad, some just needed more work than the prior tuner was going to put in.All that aside no tuner is 100% on every setup 100% of the time (we did indeed have growing pains last year as everyone else did with the PD blower). Nor can one single tuner own the whole market. I think we can market and promote our products without such broad and completely unsupportable statements. That can be left for the tablet types who boast "advantages" over EcuTek
| The Following 3 Users Say Thank You to Xero-Limit For This Useful Post: |
#5707 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
#5708 | |
Drives: 86
Did they replace the whole unit or the oil seals only? On the other hand I didnt get a reply from Sprintex yet. Sent from my iPhone using Tapatalk
#5709 |
#5710 |
Drives: 13 BRZ Limited, 2000 Impreza Sport
Works for me
Innovate powered- Corn fed- FBM tuned
#5711 |
That Guy
Drives: 2013 asphalt FRS MT
#5712 | |
Drives: 86
The image is hosted on his site, which appears to be gone now. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
