Old 12-08-2014, 12:27 PM   #5699
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by Ethan View Post
Bob, when you replaced the pulley, did you need to replace the belt too? I am getting a squeak and the guys at HG thought it was just the belt making the noise due to the rain/humidity we have now. But perhaps it could be the pulley.
I get squeaking and it seems to be coming from the alternator pulley. I confirmed this when I had the belt off swapping the idler pulley thinking it was that. I moved the alternator pulley by hand and replicated the sound - so check and see if it possibly is that.
xxscaxx is offline   Reply With Quote
Old 12-08-2014, 12:45 PM   #5700
blown
Drives: ft86
Originally Posted by blown View Post
anyone also think about adding a larger coolant tank??
anyone thinking about running a larger coolant tank for the blower?
running the perrin intake, should allow a large enough opening to run a tank in place of the intake air box..
blown is offline   Reply With Quote
Old 12-08-2014, 04:53 PM   #5701
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by DeliciousTuning View Post
Just throwing this out there. For the remainder on the 2014 calender year Delicious Tuning is offering a 100% money back guarantee on any new Innovate Supercharger tunes. We are confident you will not find a better tune from anyone in the world using EcuTeK and we will even state you will not find a better tune even from your local EcuTeK dyno tuner.
It is a big statement but we know the drivability is key to any tune on any car.
Cheers,
William Knose
To let everyone know I have updated our tune a bit more. Over the past weekend we were up at Mann-Engineering doing some tunes and testing and spent half a day refining the Innovate Tune even further. We worked on a few more things in the tune to see if there might be room for more power, well guess what their was. If you ask what it is we did, well we prefer not to say because we have been working on it for some time and it takes a moment to even wrap out head around it, but it works well and we are applying these techniques to all our tunes.
Here is the latest revision of the tune 8.70 overlaying 8.64 (which is identical in power to 8.65). The only difference in 8.65 to 8.64 was the switch over on port to direct injection.
The biggest improvement was on the low end, from a dead stop to about 5K RPM. We focused in a lot hear to improve throttle response and add more torque to have more of a table top look versus a slow ramp up in torque. We definitely notice that on that street and makes for a fun drive.
This was tuned on the 75mm pulley (stock headers) and we are not verifying the tune on the 69mm, 91 octane and E85.
Cheers,
William Knose
The Following 7 Users Say Thank You to DeliciousTuning For This Useful Post:
brianhj (12-09-2014), CK_Bladesmith (12-08-2014), Fizz (12-08-2014), Lawnik (12-08-2014), MINOCIN (12-08-2014), poorsche (12-09-2014), TemeCal (12-08-2014)
Old 12-09-2014, 01:35 AM   #5702
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Excuse my lack of understanding, but wouldn't the sharper rise in torque at the low end make taking off more "sudden/jumpy"?
Fizz is offline   Reply With Quote
Old 12-09-2014, 04:09 AM   #5703
8686
8686's Avatar
Drives: 86
Any one experinced a leak in oil seals of the SC behind the pulley.
I lost half of the SC oil in less than 1500 miles
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 12-09-2014, 04:26 AM   #5704
sam69
Drives: GT 86
Yes, they had a bad batch of seals so I'm lead to believe .
sam69 is offline   Reply With Quote
Old 12-09-2014, 04:44 AM   #5705
8686
8686's Avatar
Drives: 86
Thank You for the info.
I will email SPRINTEX about this
Old 12-09-2014, 03:51 PM   #5706
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
How'd I miss this...big statement indeed, backed up with what? We have dozens of folks world wide running the sprintex/innovate tune (among nearly every other FI combo) and without melted pistons, plugs, or bad bearings (though nobody is immune). Indeed you do good work from what we hear, but I think your statement over reaches a bit. We've had the innovate setup on our car since the kit was released, and I doubt any other pro tuner has the miles, dyno time, and flash count of our vehicle in tuning this setup. I think the difference at this point is not so much tuner ability, but having the time to fine tune these setups remotely. I think for this reason alone we do "re-tunes" from other tuners more than initial tune sales by a ratio of 3:1 if not more. That means we've "fixed" a tune from just about EVERY vendor on here and elsewhere, even the "world class" ones. Doesn't mean that all bad, some just needed more work than the prior tuner was going to put in.
All that aside no tuner is 100% on every setup 100% of the time (we did indeed have growing pains last year as everyone else did with the PD blower). Nor can one single tuner own the whole market. I think we can market and promote our products without such broad and completely unsupportable statements. That can be left for the tablet types who boast "advantages" over EcuTek
Xero-Limit is offline   Reply With Quote
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
Dammod (12-10-2014), olorin (12-10-2014), Toyota86.ir (02-28-2016)
Old 12-10-2014, 01:16 AM   #5707
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I had this problem Sprintex replaced. Was using all oil every 5000km
Ryan86 is offline   Reply With Quote
Old 12-10-2014, 01:23 AM   #5708
8686
8686's Avatar
Drives: 86
Did they replace the whole unit or the oil seals only?
On the other hand
I didnt get a reply from Sprintex yet.
Old 12-10-2014, 01:14 PM   #5709
R2
Cheers,
William Knose
Is this image not loading for anyone else? I'd love to see this graph.
R2 is offline   Reply With Quote
Old 12-10-2014, 01:43 PM   #5710
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Works for me
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 12-10-2014, 02:29 PM   #5711
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by poorsche View Post
Works for me
It works for me in tapatalk, but not in firefox. Very weird.
Old 12-10-2014, 03:01 PM   #5712
TemeCal
Drives: 86
It worked for a bit after he posted it, but it's no longer working. Tapatalk, Chrome, Safari, Firefox...none of them are showing now. If it's working for some of you, you must have it cached.
The image is hosted on his site, which appears to be gone now.
TemeCal is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
