Old 12-09-2014, 08:26 PM   #1
louis30th
Drives: 2015 Halo FR-S
Rear bumper parking sticker?
Hi guys, I'm new to this forum and I just got a whiteout 2015 FR-S. I would like to park my car on the street but they require a Residential Preferred Parking sticker affixed to the left rear bumper. How does the sticker affect your paint and what do you guys recommend me to do? I heard that parking officers will still give you a citation if you put the sticker inside your car. Have anyone tried doing a small piece of vinyl onto the car and then stick the sticker on top of that? Thanks guys!!!
louis30th is offline   Reply With Quote
Old 12-09-2014, 08:45 PM   #2
I would just do like you said and put a small piece of clear vinyl on first. No idea what the stickers are like but would bet they are meant to stick well (or else loads of people would have stickers that weren't issued to them) so may cause issues when you want to take them off.
NWFRS (12-09-2014)
Old 12-09-2014, 08:57 PM   #3
Phil_Marino
Drives: 2013 FRS (red)
Leaving a good coat of unbuffed wax before applying the sticker ( and then buffing off the wax around the sticker afterwords) might help to avoid damage when you eventually remove it.
Phil
Phil_Marino is offline   Reply With Quote
Old 12-09-2014, 08:59 PM   #4
Phil
Or it could fall off on it's own as wax is specifically made to repeal materials. Would be worth a shot though if you cant get clear vinyl.
Old 12-09-2014, 10:28 PM   #5
tyrantcf
Drives: '16 WRX, CBR1000RR
Ive had problems with these sorts of stickers in the past. What i started doing was putting a piece of clear box type tape on the most inconspicuous part of the bumper that you can get away with, then applying the sticker to the tape. When ready to remove, simply peel back off the tape and clean the area of any possible residue. Havent had an issue doing this, yet.
Some of these stickers are a true pain in the ass to remove if you simply stick them on as they direct.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 12-09-2014, 10:31 PM   #6
Koa
Beg to be able to put it on the windshield/front glass!
Old 12-10-2014, 12:29 AM   #7
FRSGT86
FRSGT86's Avatar
Drives: 2013 Raven FR-S, 2005 Dodge Ram
This or ask if the bottom corner of the rear window would do?
2013 FRS 6AT in Raven!
FRSGT86 is offline   Reply With Quote
Old 12-10-2014, 11:09 AM   #8
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
How about putting the sticker on a magnet and attaching it to the trunk lid next to the license plate.
Scenic Driver is offline   Reply With Quote
The Following User Says Thank You to Scenic Driver For This Useful Post:
Tcoat (12-10-2014)
Old 12-10-2014, 07:04 PM   #9
ninedice
ninedice's Avatar
Drives: Series 10 #177 M/T
I thought the trunk was aluminum (not magnetic).
ninedice is offline   Reply With Quote
Old 12-12-2014, 12:43 AM   #10
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
In Hawaii we have safety check stickers that have to be applied to the bumpers....But we're able to use brackets for the safety check sticker.
Maybe you could use a bracket like that for your parking sticker. The Scion dealership here put the bracket on my car. The bracket was $21.00.
86geek is offline   Reply With Quote
Old 12-12-2014, 12:48 AM   #11
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
just use vinyl cut to just a tiny bit larger than your sticker. that way it wont matter what color the vinyl is because it will look like just a border on the sticker.
also, if you for some reason cant get vinyl, just stick it on your tow hook cover lol
mrlewistan is offline   Reply With Quote
Old 12-12-2014, 03:56 AM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If you want something clear but would blend in easier with the paint, use the 3M Paint Defender.
Mask off a square area larger than your sticker, block off the rest of the bumper, and spray a liberal coat of it so it's relatively thick.
After it dries, then apply the decal.
I have leftover 3M product, if you are in SoCal I can probably just give you what's left in the can.
-alex
Old 12-12-2014, 03:29 PM   #13
louis30th
Thank you so much for your support and great responses guys I'll look into doing the vinyl, but how easy is it to remove the vinyl once you don't want it there anymore and does vinyl affect the paint of the area around the vinyl sticker?
Old 12-12-2014, 03:30 PM   #14
louis30th
Could you please provide more detail on the brackets? thanks a lot!!
Help. When is it too late to apply a sticker front bumper clear coat? DandoX Scion FR-S / Toyota 86 GT86 General Forum 7 08-25-2014 03:12 PM
Need a reality check - scraped underside of bumper on parking block 1Cor10:23 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 06-24-2014 01:01 PM
JDM Headlight Washer ”Sticker“ on Front Bumper Figo Cosmetic Modification (Interior/Exterior/Lighting) 31 04-04-2014 08:01 PM
Rear Scion Sticker Seungify Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 10-18-2013 01:43 AM
Rear Parking Brake Guard Rub (Meaty Rear Tires) console_cowboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-13-2013 03:39 PM
