Old 12-09-2014, 04:07 AM   #71
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
Originally Posted by lukey86 View Post
Which screw are you talking about?
Also I'm gonna have a play around with different pre-load/dampening settings this week sometime to try and find the butter zone for ride quality without rub, I'll let you know how I go
Watch this video...I feel dumb not noticing this lol.
[ame="http://vimeo.com/28478078"]BC Racing Coilovers Camber Adjustment on Vimeo[/ame]
Celigts is offline   Reply With Quote
Old 12-09-2014, 04:20 AM   #72
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
Yeah mine are pre much the same as that
As far as lowering the car is concerned you're gonna be limited by your tyre size, a wider tyre means the wall pokes out more so with 235's you'll never get quite as low as i can with 225's, especially considering that without adjustable LCA's the only way to achieve a decent amount of rear camber is to lower the car so it's abit of a catch-22
lukey86 is offline   Reply With Quote
Old 12-09-2014, 06:03 PM   #73
Celigts
Celigts's Avatar
Redid the preload on all coils...maxed low on rears. Front can go lower but it seems ok. About 1 finger gap on both front and rear. Ordered stance rear lower control arms. So it's a bit of camber time...but HONESTLY the cars already tooooo low to drive safely...it hits every damn thing. Any pothole or driveway grinds against the exhaust. Damn socal shifty streets...
Old 12-09-2014, 10:04 PM   #74
lukey86
Built Not Bought
lukey86's Avatar
Haha yeah you don't really appreciate a good smooth road until you drive a car like this, same problems here, potholes, dips in the road, speed bumps and about 1 out of every 3 driveways become no-go zones, the price we pay for that perfect stance...
Old 12-11-2014, 02:35 AM   #75
Celigts
Celigts's Avatar
I feel vibration aat around 80 mph and higher. As if a wheels loose...maybe hub centric rings would help? Or maybe I should check the studs on the wheels lol
Old 12-11-2014, 02:46 AM   #76
lukey86
Built Not Bought
lukey86's Avatar
Yeah sounds like a slight balance issue, only slight if it's 80mph or more
I'm not sure if hub centric rings would help, XXR wheel fitment is usually pretty tight, don't have them on mine and I've been waaay over 80mph with the new wheels without a problem
it could be something as simple as a wheel out of balance, best thing to do is take wheels off, check fitment as you loosen them, check each rim for missing counterweights, then once the wheels off check all bolts that were loosened to fit your coils, sway-bar links, top and bottom coil mounts etc, chuck the wheels back on and go for a spin, if it's still there then you'll have to go to a good wheel/suspension shop (maaaaybe not the last one you went to loool) and get them to check it out, could just need a wheel alignment (which is actually recommended after coil-over installation anyway)
hows it all going anyway? any rub issues anymore?
Old 12-11-2014, 04:24 AM   #77
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Could also be a crappy tire. I've had vibrations like that with a tire that is not running true. Wheel was balanced but tire at certain speeds meant it was bad. I did by trial and error as had a spare and kept swapping wheels until it went away so knew which one it was then went back to tire shop.
Tire was going up and down and side to side and was new. Swapped for another and vibrations stopped.
nzer is offline   Reply With Quote
The Following User Says Thank You to nzer For This Useful Post:
lukey86 (12-11-2014)
Old 12-11-2014, 04:55 AM   #78
nzer
nzer's Avatar
A check you can do yourself is as follows:
1. Jack car up and out on axle stands and make sure very secure
2. Start car and put in first.
3. Leave car idling (no more - don't rev it!)
4. Rear wheels will spin slowly so you can visually see if and issues.
5. If no issues, turn car off and swap front wheels onto back
6. Repeat steps 2-4 for these two wheels
This may at least isolate which wheel/tire is the issue.
There's a youtube clip of the above process but can't find it and it's now 10.54pm here in New Zealand so I'm going to bed!
Celigts (12-13-2014)
Old 01-07-2015, 02:36 AM   #79
VakaGT
VakaGT's Avatar
Drives: None
any fender mods for 18x9.75? ill be getting xxr 530 with 8.75 in front and 9.75 in rear if all goes well
im on sportlines curretly -_- or should i stick to 8.75 all around?
My Build Thread
Instagram: neel.vaka
VakaGT is offline   Reply With Quote
Old 01-07-2015, 02:44 AM   #80
lukey86
Built Not Bought
lukey86's Avatar
Not completely neccessary. depends how low you wanna get.
I pulled my guards about 10mm, it still scrubs a little on the point where the rear bar meets the body.
Adjustable LCA's and PBM's would be handy though, a tiny little bit more camber would stop the scrubbing
Old 01-07-2015, 02:51 AM   #81
VakaGT
VakaGT's Avatar
Drives: None
im just on sportlines. so its about 1.5 inches low. hope that'll work. maybe i should go 9.75 all around
My Build Thread
Old 01-07-2015, 02:56 AM   #82
lukey86
Built Not Bought
lukey86's Avatar
Its hard to make aggressive wheels fit without fully adjustable coil-overs, my setup is max low, about 3 inches lower than standard which, without adjustable LCA's, is the only way to acheive enough natural camber to tuck these wheels in. Front camber plates are maxed too
Old 01-07-2015, 03:04 AM   #83
VakaGT
VakaGT's Avatar
Drives: None
damn so no. guess ill stick to 8.75
My Build Thread
Old 01-07-2015, 03:10 AM   #84
lukey86
Built Not Bought
lukey86's Avatar
Unfortunately stance is all $$$$...Hellaflush is more like Hellabroke lol
Plus the major downside of my setup is the fact that having fun on bumpy backroads is over. Scrubbing, hitting the bump stops, exhaust being smashed into the road. Low and slow is now the only way to go.
Not that I'm trying to deter you but it's advice that I never had when deciding to go with the stance option. At the end of the day it's all about whether you prefer looks or performance
Finally ! she's here ! Christina_Marie Scion FR-S / Toyota 86 GT86 General Forum 44 09-12-2012 03:58 PM
YES! finally here! :) HELP Obja Scion FR-S / Toyota 86 GT86 General Forum 58 09-07-2012 01:30 PM
Finally here!! _F-R-S_ Scion FR-S / Toyota 86 GT86 General Forum 3 08-26-2012 11:13 AM
Finally geb2391 Northwest 11 07-24-2012 02:12 PM
Finally got it!! percyng CANADA 21 06-17-2012 01:50 AM
