#9087 | |
No Money, No Problems
Anyways, I just got word from the guy making my T3Q retro logos. He said he started cutting them over the weekend. Can't wait to swap out the Scion logo for something a bit more special
#9088 |
Drives: FRS-RS1, Triumph Speed Triple, Lola
Installed KartBoy shifter today. Taking my time it was 90 min. could be done in 45-60. Makes more of a difference than I expected. Installed shifter only. Shifter bushing and trany mount insert next. I would rate it as a must do. Excellent service from Kartboy.
#9089 |
gotta go slower
Drives: 2014 FR-S
Changed the 2014 dash panel to the 2015 version.
I like it a-loootttttt |
| The Following User Says Thank You to Datcrazyeric For This Useful Post: | LucidMomentum (12-08-2014) |
#9090 |
Drives: 86 & GRB
Installed
A: TRD quad muffler B: R-Magic rear crossmember collar C: Cusco Rear cross member brace D: STi ts bolts for crossmember and ts reinforced bolts and nuts for rear shock.. ![]() ![]() ![]() ![]()
#9091 |
Road-hole
Drives: 2013 Whiteout FR-S
Well...let's see...
If the what did you do to your FRS today is literal, then I installed a spec-d cat back. Although to be honest, I was surprised I was able to.
It's been dark before I leave work since the time change and I have limited light at my house and a sloped driveway. Ideally for this job, I would've wanted to put it up on four jacks stands, but that isn't feasible on my driveway for safety reasons. If not on four jack stands or a lift, then two jack stands in the rear with blocks in the front. Sloped driveway takes away the feasibility of that too. So I had to manipulate my car so it was sideways in the driveway, put on the parking brake and put jackstands on one side of the car in the front and in the back. Getting the stock exhaust off the hangers is a bitch this way, let me tell you, but I got it all done in about an hour anyways and it sounds awesome. It's basically an invidia N1 so it sounds almost identical to the N1. If you count the last several days, I squared away and finished a band pass box with two tens and two 200W amps powering each sub in bridged mode, I installed tein S-Tech stock shocks and 20mm spacers in front and 25mm in back. All in all for a few days work and $500 bucks, I would say it's been a good week for my car. The difference in the sound, the Sound and the look and feel of the car is astoundingly different for just a few days. No time tonight for a video or pics, but I'll try to get some up tomorrow. Jaden |
#9092 |
Ordered the Supertek hood damper kit and the frameless mirror. Also talking to a guy in state about getting the INGS vented front fenders. Fingers crossed.
#9093 |
Got my custom tag today.
| The Following 4 Users Say Thank You to Caspeed For This Useful Post: |
#9094 |
Drives: 2015 FRS Asphalt
Picked up my license plates today from the dealer.....then immediately ordered personalized plates online....
#9095 |
Drives: 2013 FR-S/C
Ran over the equivalent of a caltrop and destroyed a rear Prius tire. Used it as an opportunity to upgrade to 225/45/17 Kumhos.
#9096 |
Drives: 2013 Firestorm FR-S AT
Nothing spectacular. Installed the GrimmSpeed Hood Strut Kit. A job that should have taken 30 minutes tops took 1 1/2 hour because whoever packed my kit can't count beyond 3. One of the 4 nuts were missing and I had to pick one up at my local Ace Hardware. Thanks GrimmSpeed.
Other then that the kit works really well and fits perfectly. Their installation video needs updating. At about 3:33 on the video instead of using the longer 10mm bolts supplied with the kit to install the lower end of the strut they re-use the original bolt. [ame="https://www.youtube.com/watch?v=5py1C4Q4TD8"]https://www.youtube.com/watch?v=5py1C4Q4TD8[/ame] I got it from PhaseTekSport for $108.67 shipped. Their 5% off coupon, TAX14, still works. http://www.phasteksport.com/2013-FR-...brz-097001.htm ![]()
| The Following User Says Thank You to RickyBobby For This Useful Post: | sirwiggles (12-13-2014) |
#9097 |
Drives: 2015 Scion FRS Relese Series 1.0
Drove mine to the shop to get winter tires put on.
#9098 |
Built Not Bought
Drives: 2012 Toyota 86 ZN6
Pulled my guards today, well when I say pull I mean took to it with a hammer and rubber block
![]() Sent from my iPhone using Tapatalk
Insta: @8_sixer
My build: http://http://www.ft86club.com/forum...ad.php?t=80284 |
| The Following User Says Thank You to lukey86 For This Useful Post: | Jrryjms07 (12-13-2014) |
#9099 |
Drives: ‘16 4Runner, ‘19 Corolla HB
It made friends with a Monogram while I was at work. Sent from Tandy 400 |
| The Following User Says Thank You to Quentin For This Useful Post: | Tcoat (12-12-2014) |
#9100 | |
One & Done (AOZORA)
Drives: '15 Series.Blue BRZ (WRB)
"I have the need....the need for speed! - Maverick (Top Gun)
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 01:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 05:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 07:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 02:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 11:19 PM |
