Old 07-09-2013, 04:54 PM   #15
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
Thanks guys! Looks great!
One sad thing though, I realize Speed Element's FRS is a lot lower than 1.25" But thank you all for your pics, without them I would have no idea at all.
Brian
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
Old 07-09-2013, 04:57 PM   #16
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
Yeah it looks a lot lower. A friend on BC's is lower than me for sure, I think he is at 1.75".
UnOvertime is offline   Reply With Quote
Old 07-09-2013, 04:59 PM   #17
Racecomp Engineering
Yes, use the OEM bolt up front and you can adjust camber via the slotted strut mount as others have said.
You should be able to get close to that drop...however I would stick with 1.5" or higher. 1 to 1.25" is a sweet spot.
- Andy
Originally Posted by brianlo622 View Post
Thanks guys.
So this is the ride height I am trying to achieve (This is speed element's FRS, on the same spec wheels and tires, but running some form of prototype coilovers)
How low do the RCE tarmac 0's go? Is this height achievable with the tarmac 0s? By all means, I want to go with RCE/KW over stance or BC if possible.
Thanks in advance.
Brian
brianlo622 (07-09-2013)
Old 09-25-2013, 01:02 PM   #18
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Can I used whiteline camber bolt?
Iv already order these bolt and KW V3...
- Andy
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-25-2013, 01:22 PM   #19
I think you can, you don't really need to and I wouldn't.
- Andy
Old 12-07-2014, 09:37 PM   #20
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
- Andy
Sorry for bringing up an old thread but just wanted to make sure. We are supposed to use the oem crash bolts (Subaru part #901000394) over SPC camber bolts right?
eSOLOR is offline   Reply With Quote
Old 12-08-2014, 09:04 AM   #21
Yes use OEM bolts.
Old 08-03-2015, 12:35 PM   #22
ChrisSC300
Drives: 2014 SWP BRZ
How much negative camber is everyone getting up from with the slotted strut and OEM crash bolts? Im hopeing for -2. Still debating between the B8/RCE Tarmac springs or the Tarmac T0 with the 350 rates. If I dont have to buy Top Hats with the T0's to get the camber I want then the price wouldnt be too much different.
ChrisSC300 is offline   Reply With Quote
Old 08-03-2015, 01:32 PM   #23
You can get -2 easy.
- Andrew
CSG David (08-03-2015)
Old 08-03-2015, 04:55 PM   #24
ChrisSC300
- Andrew
Excellent
Old 05-10-2016, 07:18 PM   #25
n0thing
Drives: Subaru BRZ
Yes use OEM bolts.
Just to confirm, while keeping the factory OEM bottom 14mm bolt, it is OK to use another OEM bolt 14mm (not SPC/WL camber bolt) on the top slotted hole without slippage?
Also, you think I'll be able to archive -2.5?
Thanks
n0thing is offline   Reply With Quote
Old 05-16-2016, 01:13 AM   #26
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Thanks
I use the 14mm crash bolt top and bottom. I can get up to -3 camber just doing that. I torque both bolts at 129 ft-lbs and have not had them slip.
smg1138 is offline   Reply With Quote
The Following 2 Users Say Thank You to smg1138 For This Useful Post:
Racecomp Engineering (05-16-2016), wparsons (05-16-2016)
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 589 11-21-2021 04:13 PM
***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** FT-86 SpeedFactory Brakes, Suspension, Chassis 208 09-30-2016 03:43 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 05:31 PM
SPC/Whiteline front camber bolts in GTA? f0rge CANADA 2 03-20-2013 10:56 PM
