#29 |
Drives: 13' Subaru BRZ Limited SWP 6MT
I'm running FA500's, lowered 1.75" (44mm) square. I started with them bottomed to see my maximum drop, and then moved up from there for the visual drop I wanted, which was the top of the tire (225/40/18) flush with the fender; also knowing being lower would reduce clearance and affect my handling.
FA500 max lowering - Front: ~3" - Rear: ~2" As FT86SpeedFactory stated, put lower rear LCAs like Stance, and you'll be dropped 3" square. Disclaimer: Once you go below 1.5" drop, be prepared to buy rear LCAs or camber bushings, Toe-Arms, and for you handing to be potentially degraded. Great read on our cars suspension: http://www.ft86club.com/forums/showthread.php?t=10643 "I've also found that 20mm drop is ideal for dynamic alignment (as designed), and 35mm still retaining pretty good alignment as well."
| The Following 2 Users Say Thank You to mwjcyber For This Useful Post: | Freshfrs86 (12-08-2014), JordanWho (07-27-2014) |
#30 |
Drives: '14 BRZ Todoroki/OriginLabo
Sorry for this half-year bump, but has it been determined if the Swift spring upgrade sits lower than the FA springs?
#31 | |
Ridge Racerrrrrrrrr
#33 |
fastest frs in sbg
Drives: sick ass ultramarine frs
Wheel specs?
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
#34 |
SCBYD0
Drives: 18 BRZ (WRB)
I believe the one in the picture is when they ran them in 17x9 +35.
http://www.ft86club.com/forums/showp...6&postcount=99 They also did 18x9.5 setup. http://www.ft86club.com/forums/showp...&postcount=208 |
| The Following User Says Thank You to JonAvalon For This Useful Post: | sosick (05-10-2015) |
#35 |
Drives: '15 Halo FR-S
I have the DSG Special Edition 500's. The rears do not in fact go very low. It makes it even worse for me since I have a small sidewall on 17' wheels. Considered selling them and then buying the BC extreme lows, but that's totally not worth it. Rather just go the option of buying the Stance LCA's. For next year, looking at having a 18x9.75 set up so hopefully that'll fill in the rear tire gap in addition to having the Stance LCA's.
However, I can say that regardless of them not going as low as I'd have liked, they ride absolutely AMAZINGLY. My girlfriend rode in my car after I went from my previous coils to the FA 500's and she mentioned how "her girls were bouncing around less" and she didn't know that I changed suspension. So I think that speaks much more than anything I could possibly say about them. |
#36 |
Drives: 2014 WRB BRZ Limited
Just found this.
Put my rears on tonight. After the first try I found I was 1 inch higher than stock.... lowered it some, and now I'm back to STOCK ride height, but looks like I only have about an inch more that I can lower before I'm maxed out... Something seems seriously wrong... thoughts? These pics are at stock ride height, about 26.5" from the ground to the fender. This is with SPC LCAs and 9k swift springs. |
| Wheel Directory: Phat Fux Ballzy 18x9.0 +35 | Future | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 210 | 01-22-2015 09:53 PM |
| Fortune Auto Coilovers | doriNIGHTS | Brakes, Suspension, Chassis | 17 | 12-24-2012 04:05 AM |
| Fortune Auto Gen 4 500 Series Coilovers! | Lisa@TrueStreetIndustries | Brakes, Suspension, Chassis | 29 | 12-05-2012 05:46 PM |
| **Echelon Autosports** -- New V4 Gen Fortune Auto Coilovers NOW AVAILABLE! | Echelon Autosports | Brakes, Suspension, Chassis | 8 | 07-28-2012 01:27 PM |
