#295 |
#296 |
Drives:
Sorta on the right track. Actually i was tying to look out for the "little kids" who try this "pedal dance" and drive off a damn cliff. Its not a bad idea it just needs to be done with caution not just every time you drive fast.
#297 |
Drives: 2015 Scion FR-S 6MT
Turning off traction control (3 sec press) has become part of my routine every time I get in the car. 7700+ miles and I bet less than 500 of those were with traction control on. But then again I learned to drive without ABS or any other nannies. The whole cutting power when getting some wheel spin (hard shift into second) makes me want to strangle whoever designed that particular "feature". If you're just a commuter then sure, leave it on but as for me I'm a driver.
| The Following 3 Users Say Thank You to Amaya For This Useful Post: |
#298 |
#299 | ||
I wonder how people did it, even 10 years ago, when most cars didn't have traction control. Oh, the pedal dance works on Automatics. Read instructions. Carefully. And learn to drive standard like a man. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | hmong337 (01-19-2015), Ultramaroon (01-19-2015) |
#300 |
Drives:
Actually yes i do need lessons lol help me with the pedal dance. no sorry standards not for me anymore its fun and all but as a daily driver i just dont want to deal with it. Paddle shifters pretty much gives me what i want in a manual and auto together.
#301 |
Umm I tried to save you but then you fell right into this one...
#302 |
1. Remove/replace all electronic nannies with manual stuff
2. Sell removed components 3. Profit 4. Drive happy
| The Following User Says Thank You to Amaya For This Useful Post: | CSG Mike (12-05-2014) |
#303 |
Drives:
Now that i know this is possible i may try it however i still need to see if the pedal dance truly does work for autobots
#304 |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
pedal dance not working on my 2015 brz. Is the pedal dance different on the
2015 brz/frs. Or can a flash tune be a possible problem. I would love to know the answer since i have had two instances this past weekend where the EBD screwed up a nice turn during AX.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#305 | |
#306 |
Do we know which temperature parameter it uses? I've wondered if it doesn't use the oil temp because it will lock out even when the water temp gauge hits "normal."
#307 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Ultramaroon (01-18-2015) |
#308 |
CAR-AHOLIC
yes sir, car is fully warmed up. I have tried it a half dozen times over the last few weeks. I always try it after I drive somewhere. Oh, but one problem I didn't think of. I have a mishomoto thermostat installed that definitely keeps my temps lower. Maybe that is not allowing the coolant temp to hit a proper level. Thanks for your help.
| Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 11:24 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
