Old 11-29-2014, 03:09 PM   #1
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Racer X Fabrication catch can development/prototype!!
....Most of you must be thinking not another Catch can/AOS thread!! I have seen at least 4 or 5 catch can threads. Well with that out of the way, I will say that we have thrown our hat in the ring as well. For your viewing pleasure the Racer X Fabrication catch can!! The Racer X catch can is 2 cans built into 1. We opted for a more OEM location/appearance, directly if front of the fuse box and the catch can will be anodized black when it is ready for sale. Currently we have the prototype on our shop car for testing.
Why a catch can?? Well if you don’t already know from the other threads I will sum it up in short. I’m not a sales person and for me its difficult to have multiple paragraphs that regurgitate the same knowledge that enthusiasts already know. The FR-S / BRZ have two locations that would make a catch can helpful, these locations are the PCV and the crank case. These two locations would be the lines going into the catch can. The outlet of the catch can would be to the nipple on the side of the intake directly before the throttle body and the back of the intake manifold. For NA applications both of these sources would be under vacuum, for forced induction applications both of these sources would see pressure.I make these notes because the Racer X Fabrication is a sealed unit and is suitable for both applications assuming it does not get in the way of the charge pipes for the intercooler. The purpose of the catch is to separate air from oil or as you see commonly air oil separator (AOS). The intake and intake manifold are subjected to oil residue from the crank case vent and PCV. The oily residue can hurt performance by degrading the octane rating of fuel, and decreasing the quality of the intake air. The oily residue over time will build up on the intake track as well as the intake manifold walls.
Enough with the writing of words.
Here are a few pics of the 3D printed catch can and our prototype assembly. I will provide more updates as we move along with the project.
Jeff@Racer X Fab is offline   Reply With Quote
The Following 4 Users Say Thank You to Jeff@Racer X Fab For This Useful Post:
alexand3r (12-20-2014), Black Tire (01-16-2015), JonAvalon (12-18-2014), xwd (11-29-2014)
Old 11-29-2014, 03:17 PM   #2
xwd
Looks nice, any idea when you might be releasing them?
Old 11-29-2014, 04:03 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
Are you planning to use anything to deaerate the oil?
The Following User Says Thank You to Calum For This Useful Post:
mad_sb (12-19-2014)
Old 11-30-2014, 04:17 AM   #4
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I want this now. Make it now! But seriously this is the best looking one I've seen on this car. Suits RHD as well so that's a bonus!
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Jeff@Racer X Fab (11-30-2014)
Old 11-30-2014, 10:13 AM   #5
Jeff@Racer X Fab
We are testing now, and will be releasing in the next few weeks. We are looking to release around December 15th.
Yes, we are testing two different methods for deaerating. I will provide more information on this when we settle on the solution that is best.
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post:
Calum (11-30-2014)
Old 11-30-2014, 11:40 AM   #6
abraxis
Drives: many
So inspection and evacuation would involve complete removal and disassembly?
abraxis is offline   Reply With Quote
Old 12-01-2014, 10:23 AM   #7
Jeff@Racer X Fab
The catch can does have drain plugs on both sides, that can be used to evacuate fluid. Cleaning or inspection would require disassembly.
Old 12-01-2014, 07:50 PM   #8
boomslang
Drives: Toyota
I'll take one.
boomslang is offline   Reply With Quote
The Following User Says Thank You to boomslang For This Useful Post:
Jeff@Racer X Fab (12-05-2014)
Old 12-04-2014, 03:48 PM   #9
kbye
kbye's Avatar
Drives: 2014 FR-S
Any updates on when this will be released?
kbye is offline   Reply With Quote
Old 12-04-2014, 03:50 PM   #10
Koa
BEAUTIFUL! +3 I want one as well
The Following User Says Thank You to Koa For This Useful Post:
Old 12-04-2014, 05:02 PM   #11
Foobar
SLO NO MO
Foobar's Avatar
Scroll up
Are the plugs shown in any of those pictures? I'm trying to picture how easy it would be to drain it while everything's mounted in the car. Reach in from the engine side underneath the unit? Any chance you could build in some kind of visual indicator method that we could easily see how much liquid is caught by the device at a glance? Maybe just a simple dipstick type of device to keep things simple?
Old 12-04-2014, 05:10 PM   #12
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
It is so pretty...damn
Old 12-05-2014, 11:32 AM   #13
Jeff@Racer X Fab
We are looking to have this project finished around December 15th.
Originally Posted by Foobar View Post
Scroll up
The plugs are closer to the outlets at the bottom of each side on the catch can. We plan to incorporate a drain with a simple ball valve this would allow you to reach in from the side and drain the can. We have been thinking about some kind of visual indicator or a dip stick, this would be a nice feature.
Old 12-17-2014, 08:20 PM   #14
Jeff@Racer X Fab
Design finalized, raw material is in!!
We have finalized the catch can design, and made a few tweaks but the design has stayed mostly the same. We have added internal baffles, as well as additional features to aid in separating the oil from the air. One additional benefit of the location is its indirect airflow from behind the head light, this has aided in condensing the oil.
We will be making chips for the next few days on these catch cans and then it will be out to the anodizing shop. Questions and comments welcome.
Here are a few pics of the current prototype installed, please ignore the hose routing. The hoses can easily be routed for a cleaner appearance.
Racer X Fabrication air intake design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 45 08-01-2019 01:29 PM
Racer X Fabrication suspension parts, and development Jeff@Racer X Fab Suspension | Chassis | Brakes -- Sponsored by 949 Racing 134 09-01-2016 06:02 AM
Racer X Fabrication oil pan design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 87 06-03-2015 12:10 PM
Racer X Fabrication heat shield, help us to help you Jeff@Racer X Fab Engine, Exhaust, Transmission 31 07-17-2014 10:20 AM
Racer X Fabrication, New vendor intro Jeff@Racer X Fab Announcements, Contests, Giveaways 0 03-12-2013 12:50 PM
