Old 12-04-2014, 03:24 PM   #1
DarkestBuddha
Drives: BRZ limited GBS
OFT tune still get O2 sensor light
i have the stg1 oft tune and i still get the O2sensor check engine light periodically,
just wondering if thats normal,
i know you just clear it but was just wondering if others also keep getting it.
i thought the tune would prevent it from even showing up again.
i also have catted headers
DarkestBuddha is offline   Reply With Quote
Old 12-04-2014, 03:39 PM   #2
Foobar
SLO NO MO
Foobar's Avatar
What's the code being thrown? The STG1 tune is designed for the stock headers. You don't have an aftermarket cat-free header do you?
Old 12-04-2014, 03:41 PM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
It's not the tune that is causing the o2. If you put the stock tune back in, you will get the same thing.
First step of troubleshooting is to take note of the code #. Do you know what it is?
Shiv@Openflash is offline   Reply With Quote
Old 12-04-2014, 03:48 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
Wait - which catted headers? Aftermarket and do you have other intake/exhaust mods? If so, you're going to need to disable the DTC for the code you're getting (probably P0420). The catted aftermarket headers out there are designed to be CEL-free only with stock intake/exhaust. Make the system more free-flowing than that, and you need to do something about the O2 sensor.
Old 12-04-2014, 03:49 PM   #5
DarkestBuddha
i have the ft86speedfactory catted headers with perrin Op and 3"perrin catback
code is P0420
Old 12-04-2014, 03:52 PM   #6
Foobar
SLO NO MO
Foobar's Avatar
code is P0420
You're going to need to disable P0420 DTC on your tune to get around that. As Jeremy from FT86SF has said himself, they designed the catted header to not throw CEL only on the stock intake/exhaust. While you might get away with it, it's likely only a matter of time before P0420 pops up.
Old 12-04-2014, 03:54 PM   #7
DarkestBuddha
yea thats what i thought, its more just an annoyance then a problem atm.
i just thought once had a tune it wouldn't show up again.
i have a dropin filter.
Old 12-04-2014, 04:00 PM   #8
Foobar
SLO NO MO
Foobar's Avatar
The Stg1 tune doesn't disable the DTC for P0420 but Stg 2 does. Otherwise, you can make this change yourself with Rom Raider and the appropriate definition file for your CALID. Do you have experience in that?
Old 12-04-2014, 04:05 PM   #9
DarkestBuddha
no, but i dont mind looking into it.
oh, didnt know that
Old 12-04-2014, 04:06 PM   #10
STV3
Señor Member
STV3's Avatar
Sub'd because I have the same header with the same code and my OFT will be here in the next few days.
STV3 is offline   Reply With Quote
Old 12-04-2014, 04:14 PM   #11
Foobar
SLO NO MO
Foobar's Avatar
oh, didnt know that
You can either hex edit the bin file directly and 00 out the right address, alternatively, using Rom Raider, you're going to go into Diagnostic Trouble Codes, and find the option for (P0420) CAT EFFICIENCY BELOW THRESHOLD, and set the value to "off". Just like making a Registry edit in Windows.
That said, the harder part is making sure you've got the right XML definition file for your CALID, and it contains the mapping information for the P0420 flag. I don't know if all of the OFT definition files have that or not, so if it's not showing up as an option for you in Rom Raider, you're going to need to add the mapping info to the XML file. The information you put in there is going to depend on your CALID and whether you're on the OFT 1.x or 2.x tune file. The 1.x file uses the definitions that are for your exact CALID, the 2.x file uses one based on B01 I believe.
The Following User Says Thank You to Foobar For This Useful Post:
raven1231 (12-04-2014)
Check engine light... Map sensor cjsporl1996 Issues | Warranty | Recalls / TSB 4 03-29-2014 05:37 AM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
AVO STG1 Turbo Kit New in the Box w/Visconti map sensor upgrade and tune JMPoole Engine, Exhaust, Bolt-Ons 8 04-04-2013 04:47 PM
