Old 12-04-2014, 02:05 PM   #15
Unless you are in a closed garage, and not ready for a nap.
The "Napping in your car" instructions in the manual are very clear on that point!
Old 12-04-2014, 02:08 PM   #16
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
While still coasting to a stop, hit the start button three times quickly, this will kill the engine and put you in acc mode without cutting power to the head unit, but you need to be moving slightly for this to work. I wouldn't recommend trying it for the first time in your driveway, find an empty parking lot so you understand what it's doing. It's a fail safe for the engine should you need to shut it down in an emergency while moving (ie, oil light comes on). I know this works cause I've used it numerous times while coming to a stop....that is while parking.
Gords_zenith is offline   Reply With Quote
Old 12-04-2014, 02:10 PM   #17
Koa
I believe you guys are all falling for a troll. my radar is pinging hard today
Old 12-04-2014, 02:17 PM   #18
No I don't think so (read their one other post). Just has really weird priorities!
Old 12-04-2014, 02:29 PM   #19
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Ok, turning the car off, but keeping 'ACC Power' on is possible. The trick is to be rolling at least 2 mph. Then quickly press the start/stop button 3 times. Engine will stop, electronic will stay on. Voilà
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 12-04-2014, 02:58 PM   #20
jvincent
jvincent's Avatar
Problem solved.
Just need a good mount for it.
The Following 4 Users Say Thank You to jvincent For This Useful Post:
Jrryjms07 (12-04-2014), Pacific (02-26-2015), Tcoat (12-04-2014), Ultramaroon (02-26-2015)
Old 02-25-2015, 09:13 PM   #21
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
I didn't have time to read that part, could you summarize it for me?
Amaya is offline   Reply With Quote
The Following User Says Thank You to Amaya For This Useful Post:
Old 02-25-2015, 09:25 PM   #22
Don't do it in an enclosed area with car running.
Ensure parking brake fully engaged.
Recline seat!
(Not in book but advisable anyway: Don't do it in downtown Detroit!)
Amaya (02-25-2015)
Old 02-25-2015, 09:49 PM   #23
RoadKillGrill
Drives: FR-S 10 Series M/T
This is one of the things that really annoys me with pushstart too. Is there any fix?
RoadKillGrill is offline   Reply With Quote
Old 02-26-2015, 01:20 AM   #24
H-KYD
Drives: gt86
Press the Start engine button twice....
H-KYD is offline   Reply With Quote
Old 02-26-2015, 02:31 AM   #25
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Originally Posted by extrashaky View Post
Doesn't work with a manual transmission.
People have asked this same question repeatedly since this car first came out, and there doesn't appear to be any reasonable way to do it. Killing the engine by dumping the clutch with the car in gear? Don't do that.
Why do you want to shut off the engine so badly? Keep the transmission in neutral and apply the hand-break. When you're done, simply turn the car off and switch into 1st or neutral for safekeeping.
carma143 is offline   Reply With Quote
The Following User Says Thank You to carma143 For This Useful Post:
Tcoat (02-26-2015)
Old 02-26-2015, 03:22 AM   #26
Recline seat!
OMG, Tony, you just got Squaddied.
Amaya (02-26-2015), brandonblt2 (02-26-2015)
Old 02-26-2015, 03:32 AM   #27
Amaya
Amaya's Avatar
Hehe
Old 02-26-2015, 03:33 AM   #28
Hehe
Shame on you.
haha.. nice
Running e85? HSayaovong Engine, Exhaust, Transmission 16 04-25-2014 12:05 AM
Something running while car is off. grostoine Issues | Warranty | Recalls / TSB 5 04-11-2014 09:56 PM
Noticeably low and sharp volume with AM radio stations with stock BRZ radio tracerit Electronics | Audio | NAV | Infotainment 0 07-24-2013 03:38 AM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 03:45 PM
Radio, Iphone?? Radio cuts out when surfing the web Fugazi Electronics | Audio | NAV | Infotainment 5 07-30-2012 12:24 PM
