| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Señor Member
A 225/45/17 Mich PSS will be fine for that size wheel. They run very wide. The tread with on that tire is 8.2" wide.
http://www.tirerack.com/tires/tires....omCompare1=yes ^Click on specs^ |
#16 |
Señor Member
A 225/45/17 Mich PSS will be fine in that size wheel. They run very wide. The tread with on that tire 8.2".
http://www.tirerack.com/tires/tires....omCompare1=yes |
#17 | |
Drives: Wrb 2014 limited brZ
#18 |
Drives: 2012 Toyota 86
unless you want the look of a fatter tire, i would suggest the 225/45. its cheaper and will have more than enough grip. i run a 205 rs3 on a 16x7" and have more grip than most would imagine. some guys stateside have put down some smoking fast times on 225s.
#19 |
I want a tire size that doesn't stretch, that is most important.
#20 |
Señor Member
#21 |
Hisnamewasrobertpaulson
Drives: 2017 Golf R
I run a 245/40 MPSS on a 17x9 wheel and its only slightly stretched, on a 8.25 i'd try to find a 235 but you could run a 225 wide tire. You won't be able to find a tire that gets you better MPG than the stock primacies because they're Low rolling resistance tires. they're already engineered to give you better MPG than most tires. I used to average over 30mpg on the primacy, i'm down to around 27-28 on the wider super sports.
This is your life and it's ending one minute at a time.
#22 | |
Señor Member
The 225/45/17 is 8.2" wide and will have no stretch on a 8.25" wide wheel. He could go 235, but that will be more money and probably more tire than he needs. |
#23 |
I appreciate all the responses, they have been very helpful and it seems like 225/45 will be okay.
Are mss overkill for daily driving? I would like to think I drive aggressively during spring/summer /fall but I won't be tracking the car. |
#24 | |
Señor Member
I will be getting them for my new set of wheels for my FRS next year too in that same size. |
#25 | |
Drives: 2017 Golf R
| The Following User Says Thank You to RobertPaulson For This Useful Post: | STV3 (12-03-2014) |
| Tire size advice | Lost | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 11-28-2016 06:42 PM |
| tire advice | kosoku | Tracking / Autocross / HPDE / Drifting | 24 | 12-17-2013 11:51 AM |
| Need daily driver tire advice | bear89103 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-26-2013 01:15 PM |
| Wheel/Tire Advice | mrjester | Tracking / Autocross / HPDE / Drifting | 1 | 05-18-2013 11:48 PM |
| Starting out wheel/tire advice? | rainmonkey | Tracking / Autocross / HPDE / Drifting | 19 | 05-02-2013 01:44 PM |
