Old 11-02-2014, 11:18 AM   #29
Jigglybus
Drives: fR-S
Originally Posted by Shutter View Post
Okay, so I crunched the MPG numbers tonight
The car trip/mpg were reset at EVERY fill up.
I installed the underbody panels and new wheels/tires in the same week, so unfortunately this is not completely reflective of underbody panels only.
Also, keep in mind that the car was purchased brand new, so MPG going up could also be attributed to break in.
I almost(of all 32 fill ups, I've used the same pump/station 25 times) fill at the same station and pump.
Reported MPG is what the car says on the dash, Actual is my trip meter divided by how many gallons were put in.
Wheels and tires are Yoshihara DY-12C(21lbs-I weighed them myself) and Michelin Pilot Sport 3 tires(245/40/18)-no weight, sorry.
12 Fill ups BEFORE underbody panels/wheels and tires:
Reported by car: 30.24 MPG
Actual: 29.16 MPG
20 Fill ups AFTER underbody panels/wheels and tires:
Reported by car: 29.87 MPG
Actual: 30.08 MPG
Average of all 32 fill ups is 29.73 MPG(actual)
So, since the underbody panel install and wheels/tires, my MPG has INCREASED.
Plus, your tire circumference is 4.48% larger, so your odometer is off by that amount. So, the real numbers are actually 1.3mpg higher than you thought.
Jigglybus is offline   Reply With Quote
Old 11-02-2014, 05:55 PM   #30
Shinobu's Smile
Drives: 2010 Tacoma, 2015 BRZ AT Limited
anyone notice any difference in wind noise with these panels on?
Shinobu's Smile is offline   Reply With Quote
Old 11-05-2014, 07:22 AM   #31
cawith
Drives: Toyota GT86 6M/T
Great DIY!
I'm really considering doing this on my car, but I am a bit worried. I live in Denmark, Scandinavia, where we have a lot of salt on the roads every winter.
Those of you, who have installed these underpanels, do you think this would protect the underneath of the car better than stock, or would it still allow lots of dirt and salt in and just hide it until it's too late?
Thanks in advance!
cawith is offline   Reply With Quote
Old 11-05-2014, 08:28 AM   #32
Die$eL
Die$eL's Avatar
Drives: Toyota MR2 Spyder Turbo
Nice write up
Just one thing i would add.
Where you removed the plastic clips which were painted, there is bare metal showing once those are gone. I'd spray on some sort of rust proofing/paint those.
Die$eL is offline   Reply With Quote
Old 11-05-2014, 09:23 AM   #33
cawith
Originally Posted by Die$eL View Post
Nice write up
OP stated that in the DIY just above the pictures regarding that
Old 11-05-2014, 08:27 PM   #34
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by cawith View Post
Great DIY!
Thanks in advance!
I dont live somewhere where we have snow/salt, but I think it would do a decent job of protecting the underside.
Since you could remove the panels, it might be beneficial to install for a winter and remove after to see if anything made it on the inside.
Anyone else?
Old 11-06-2014, 06:06 AM   #35
Die$eL
Die$eL's Avatar
oops... my bad
Old 11-06-2014, 01:39 PM   #36
manonastick
Drives: WRB ZC6
I only realized you guys dont get these standard. . .and there i was thinking it was standard all around
manonastick is offline   Reply With Quote
Old 11-09-2014, 02:03 AM   #37
troek
troek's Avatar
Drives: 2012 Toyota 86
in japan the 16" models dont get these standard.
troek is offline   Reply With Quote
Old 12-02-2014, 05:56 AM   #38
Teknian_Culprate13
Teknian_Culprate13's Avatar
Drives: Scion FR-S
where can i get this kit?
Teknian_Culprate13 is offline   Reply With Quote
Old 12-02-2014, 01:06 PM   #39
Gunman
Drives: 2019 Mazda Miata RF
Subaru, these parts come stock on the "Blue" series now.
Old 12-02-2014, 01:41 PM   #40
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Excellent diy Shutter
Great part numbers Gunman
Two years ago I installed these on my daughters car and proclaimed they improve fuel economy, I was shredded for it.
Thank you for proving it makes a difference
The car also has a Type 2 diffuser from DWL as well, it's definitely quieter and smoother than a stock one
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
continuecrushing (12-02-2014)
Old 12-02-2014, 01:43 PM   #41
tonystewart
Now I just need the part number for the larger underhood pad
Old 12-02-2014, 08:22 PM   #42
Gunman
I need to get them myself, to go with my diffuser.
skid plate, underbody, underpanels
SoCal JDM Underpanels Set Groupbuy JDKane527 Southern California 109 10-31-2013 09:29 PM
FS: JDM OEM Underpanels (LI Local Pickup) Perihelion NY / NJ / CT / PA 30 07-26-2013 08:20 AM
SoCal JDM Underpanels Groupbuy Round 2 Trojan_SC Southern California 99 06-21-2013 01:35 AM
FS: JDM OEM Underpanels (LI, NY Local Pickup) Perihelion Exterior Parts (Aero, Lighting, Etc.) 8 05-09-2013 03:45 PM
Interest in JDM underpanels GB? sittinSideways Northwest 3 04-04-2013 01:57 AM
