Old 06-20-2014, 11:38 AM   #57
DarkSunrise
DarkSunrise's Avatar
Might be a stupid question, but what is the benefit of having a twin turbo setup? Seems like a lot of extra work, weight, complexity and cost.
Respect for being bold enough to try something new/different!
2022 BRZ Build
2013 FR-S Build
Old 12-01-2014, 04:54 PM   #58
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
typically a twin turbo...
Twin turbo allows you to use smaller turbos but get the same (combined) airflow at the same boost levels as a single bigger turbo.
This means quicker spool times usually and will give you a broader power curve.
The downsides are complexity and more points of failure.
Jaden
Jaden is offline   Reply With Quote
Old 12-01-2014, 05:02 PM   #59
Dipstik-sportech
Dipstik-sportech's Avatar
So if you're spooling at 3800-4000rpm and making 300ish HP why go through the complexity of a twin setup when there's other kits that build boost sooner but make the same power? Because racecar?
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Brody602 (12-04-2014)
Old 12-01-2014, 05:13 PM   #60
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Better transient response? Twincharging is better for actual performance. More usable and broader torque. Supercharger for mid-range and turbo up high is the way to go. Just ask Enmo Racing.
Twin Turbo Kit ? SalM Forced Induction 77 07-03-2016 02:16 PM
Twin Turbo FR-S/BRZ? KidWonder Scion FR-S / Toyota 86 GT86 General Forum 44 06-27-2014 01:22 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
Super plus Turbo PLEASE MOVE TO FORCED INDUCTION Captain Snooze Forced Induction 2 01-24-2014 07:21 PM
Twin Turbo BRZ xn7485 BRZ Photos, Videos, Wallpapers, Gallery Forum 10 08-23-2013 07:13 PM
