Old 11-28-2014, 11:40 PM   #1
MikeyBatz
MikeyBatz's Avatar
Drives: Scion FR-S
100 Octane (Race Fuel)
Hey Everyone,
I ran into something interesting today. A Sunoco near me seems to sell SS100 or 100 octane "race" fuel. Has anyone ever try running this high octane fuel? Any interesting effects or problems?
MikeyBatz is offline   Reply With Quote
Old 11-28-2014, 11:46 PM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
On a stock FA20 motor with a factory tune, the 100 octane would be a waste of money (of no real benefit....and it would probably hurt your gas mileage). Anything above 94 octane on the stock tune would seem to be overkill unless you were boosted or tracking the car in 100 degree heat.
The Following User Says Thank You to Lonewolf For This Useful Post:
strat61caster (11-29-2014)
Old 11-29-2014, 12:11 AM   #3
DarkSunrise
DarkSunrise's Avatar
I've been running 100 octane on the track for the extra protection against detonation. Would highly recommend it for that, but not needed on the street for a stock engine.
2022 BRZ Build
2013 FR-S Build
Old 11-29-2014, 12:31 AM   #4
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Could you please elaborate on why this is the case? Is it due to the electronics pulling back to provide a certain performance output?
I asked because I've read the electronics keep a tight leash on the engine parameters and wonder if it would self regulate output regardless of the energy level provided by the fuel. ie - pull back for higher octane fuel and kick it up for lower grade fuel.
jeepmor is offline   Reply With Quote
Old 11-29-2014, 12:39 AM   #5
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
The ecu will pull timing if it senses knock. If there is no knock it leaves the timing where the factory set it. If you put in a higher octane fuel that doesn't make more power. You would have to add timing to make more power. You just made it less likely to see detonation.
The Following User Says Thank You to Reaper For This Useful Post:
Lonewolf (11-29-2014)
Old 11-29-2014, 12:40 AM   #6
Reaper
Reaper's Avatar
Drives: violent
Why not run an e85 tune?
Old 11-29-2014, 10:00 AM   #7
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Higher octane fuel does NOT contain more energy or make more power...it only has a higher detonation threshold.
BTW, I think you'll find that the 100 octane is LEADED fuel, an absolute no-no for catalyst equipped engines.
billwot is offline   Reply With Quote
Old 11-29-2014, 10:08 AM   #8
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
The sunoco here that sells 100 octane is unleaded. And quite expensive
Freetime is offline   Reply With Quote
Old 11-29-2014, 10:37 AM   #9
Shit Luck
Drives: red frs
the Sunoco down the road has 100 at the pump. its great for when you know you are gonna go beat on a boosted car.
Shit Luck is offline   Reply With Quote
Old 11-29-2014, 01:38 PM   #10
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
Since I can't get 93 here I just mix 100 with 91 to achieve 93, quiets the crickets just a bit
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
100 octane, race fuel
high octane fuel + FI, tune not needed? BRZPDX Forced Induction 6 09-30-2014 12:41 AM
OFT 93 octane fuel economy vs stock map CaptainSlow Software Tuning 10 07-24-2014 02:32 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
93 Octane Fuel KapteinBos AFRICA 3 01-29-2013 02:10 PM
91 octane fuel EN2_Squirrel Forced Induction 1 10-04-2012 11:13 PM
