| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 14 Brz
Climate Control Issue
Hey everyone, new here. I have the dual climate control option on my BRZ. Every time I turn on the heat or cooling, my AC turns on. I cant figure out how to turn that option off. It seems like the "Auto" mode is stuck on? Any ideas? Thanks!
#2 |
A.K.A. Starlord
Drives: 2015 Series.Blue
It's normal. Remember what "A/C" stands for (Air Conditioning, not just cooling). In this case the car is using the A/C system to de-humidify the air, which keeps the windows from fogging up. It's conditioning the air!
#3 |
Drives: 14 Brz
Is there a way to disable it so that every time I turn on the unit, the ac doesn't automatically come on?
#4 |
A.K.A. Starlord
Not that I am aware without something drastic like permanently disabling the A/C system. Why don't you want it on? Are you looking for that extra few HP?
#5 |
Drives: 14 Brz
95% of the time I turn it on, I immediately turn it back off. Im just afraid of damaging something in the process of turning it on and off quickly.
#6 |
Drives: brz
#7 |
Drives: 14 Brz
I tend to over think things......
#8 |
A.K.A. Starlord
You won't damage anything. Older vehicles had A/C right next to the off position so that you had to pass through A/C mode when you wanted to use the heat or anything, which bumped the compressor and kept it from freezing in an unused position.
Again, though, why do you need to turn it off? Just leave it on and enjoy the nice air...? |
#9 |
Drives: CSB 6MT
The dealer can change that setting with the techstream tool
#10 |
Leave it alone. The system is dehumidifying the cabin.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#11 |
I always hit AUTO and turn the AC off if it wants to come on. The rest of the system continues to function the same.
Not sure if performance drop is same in winter, but I definitely feel it in summer, and only run AC when in cruise control on the highway. |
#12 |
Drives: 2017 WRB BRZ w/ PP
I turn off the a/c to prevent condensation from forming in the system and causing that moldy smell. Only leave the a/c on when I really need it, like in the summer or when my windows start fogging up.
#13 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Why does the AC always come on with auto mode? Normally it's only for defogger and actual cold air conditioning. Kind of annoying.
#14 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
The reason the A/C comes on when you press auto is because while its warming the car, its also dehumidifying the air. It does that to keep the inside comfortable, but mainly to keep your windows from fogging up.
| Climate Control | Magiclow | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 10-05-2014 05:46 AM |
| Is there a way to turn on climate control without the AC being on? | chenshuo | BRZ First-Gen (2012+) — General Topics | 48 | 01-27-2014 01:12 PM |
| Climate control Panel for the FRS. | Mrqb22 | Electronics | Audio | NAV | Infotainment | 6 | 02-13-2013 08:03 PM |
| Climate control bezel | Surok | AUSTRALIA | 7 | 10-25-2012 05:34 AM |
| Auto climate control | Daemione | Electronics | Audio | NAV | Infotainment | 37 | 06-05-2012 09:19 PM |
