Old 11-03-2014, 10:07 PM   #29
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Originally Posted by mav1178 View Post
I test-fitted the wheels last night on my car, without tires the inside of the rim hits the brake bracket at full lock.
It may be slightly different with the car lowered, I will see once I get the tires on.
-alex
I'll double check my car aswell. Prior to this setup I ran 18x10 +38 up front. Only clearance issues I've ever had was in the rear. (Have to bend ebrake line brackets)
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
raytrix (11-04-2014)
Old 11-04-2014, 04:44 PM   #30
raytrix
Drives: Series 10 FR-S
Exactly what OmarGC said. I had to bend my rear brake line bracket because the wheel was rubbing it. The front I have zero issues with the brake line before and after the 7mm spacer. My reason for the 7mm spacer is because of the CUP system I have on my coilover. Other than that you are safe to run a 18x10 +40 up front with no spacers.
raytrix is offline   Reply With Quote
Old 11-25-2014, 03:26 AM   #31
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
So I just put everything on, and there's two points:
1) rear does not require e-brake bracket bending. The wheels fit without any modification in the rear
2) fronts: at full lock, the wheels hit the stock sway bar in the back, and hits the brake line bracket in the front.
Pics to follow shortly, too tired to resize.
Setup:
18x10 +40 ZE40
Falken Ziex FK453 255/35-18 all-around.
-alex
Old 11-25-2014, 09:30 AM   #32
ISDriven
ISDriven's Avatar
Drives: chill
Good balance between aggressiveness and elegance, great build! But, I liked it better before the wing.
What rear and spats are those?
ISDriven is offline   Reply With Quote
The Following 2 Users Say Thank You to ISDriven For This Useful Post:
raytrix (11-25-2014), SStratos (09-20-2016)
Old 11-25-2014, 11:03 AM   #33
raytrix
Setup:
18x10 +40 ZE40
-alex
Dang that's crazy. Are you on coilovers or stock struts? Secondly if you have coilovers, did it come with shorten end links for your sway bar up front?
At full lock, non of my wheels or tires contact the front sway bar. This is while sitting on the alignment rack with full weight of the car set on the wheels/tires. Could it be possible that when unloaded, the geometry of the wheel fitment has an impact on your sway bar.
Old 11-25-2014, 11:11 AM   #34
raytrix
Full Varis Arising 2 kit.
Old 11-25-2014, 01:28 PM   #35
mav1178
mav1178's Avatar
Ohlins, stock endlinks.
I tested out fitment both with suspension unloaded, as well as on alignment plates to move around with suspension loaded. The wheels do hit the front brake bracket at full lock, even if the sway bar wasn't in the way.
It's not a huge deal, just need to be careful when parking, that's all.
-alex
Old 11-25-2014, 02:40 PM   #36
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Lol can you take a pic of where it will hit? I'm absolutely clueless as to where you're hitting when you say brake bracket.
Omar GC
Instagram: 2jzus
Old 11-25-2014, 04:53 PM   #37
raytrix
I'm with Omar on this one. Brake bracket on the front wheel section????? My Stance coilovers came with replacement endlinks for the sway bar.
Old 11-25-2014, 05:14 PM   #38
mav1178
mav1178's Avatar
http://www.ft86club.com/forums/showp...19&postcount=3
"Hardline to softline connection" bracket is where it hits.
It might be an alignment issue, but I'm not running anything crazy other than maxing out caster adjustment on my Raceseng CasCam uppers.
My Ohlins did not come with replacement endlinks.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
OmarGC (11-25-2014), raytrix (11-25-2014)
Old 11-25-2014, 06:01 PM   #39
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
-alex
Hmm... What's your caster at? I'm set right at 6.5 degrees
-1.7 camber, 0 toe, 6.5 caster
Omar GC
Instagram: 2jzus
Old 11-25-2014, 06:06 PM   #40
mav1178
mav1178's Avatar
7 caster, - 2.5 camber.
-alex
Old 11-25-2014, 06:17 PM   #41
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
-alex
I'll kick my caster up when I get the chance, see if I can make it happen...
Have yet go to an event since I had this specific set of wheels in which forces me to max it out and kick my camber down to -2.4 or less. However I had a set of 18x10 +38's with 245/35's in which I ran essentially your current alignment specs and did get an occasional "grind/rub" at full lock under compression and never really looked into it but kinda makes sense... If it's close I'm likely going to relocate that bracket location while my car is still down for the winter. Thanks!
Omar GC
Instagram: 2jzus
mav1178 (11-25-2014)
Old 11-29-2014, 12:48 AM   #42
pleong
Drives: 2013 Whiteout FR-S
Here's my setup.. I'm on 285/30's I have a big poke at the rear.. Going to have to pull the fenders some more
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
hankook, touge factory, varis, volkracing, ze40
Wheel Directory: Volk Racing TE37 18x10.0 +44 Jesse@JDLAutodesign Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 59 12-14-2017 07:04 PM
245 square setup... Need advice cjsporl1996 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-22-2014 04:06 AM
Which square or staggered setup should I go with? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 01-07-2014 11:51 AM
FS/T: 18x10 Square Candy Teal XD9's OmarGC Wheels and Tires 30 09-01-2013 02:31 PM
Wheel Directory: Volk Racing TE37 17x9.5 +40 / 18x10.0 +44 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 04-16-2013 07:28 PM
