Old 11-22-2014, 01:40 PM   #253
sdwagonjp
sdwagonjp's Avatar
Drives: 2015 Fr-s Firestorm
sdwagonjp is offline   Reply With Quote
Old 11-22-2014, 07:02 PM   #254
sdwagonjp
sdwagonjp's Avatar
Old 11-22-2014, 07:43 PM   #255
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
For the 4 flares plus the 4 bumper caps, I'd charge around $1300. Out of the box they need some help before paint to look really good. I had to prime and block the last kit I installed twice before paint. I'm guessing you are cutting your fenders, and cutting/welding/sealing your quarters yourself? You can spray or brush something over the bare metal and keep it under the flare line. I changed the color on the last car so I painted the full panels after cutting/welding anyway
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
sdwagonjp (11-22-2014), SkAsphalt (12-08-2014)
Old 11-22-2014, 07:44 PM   #256
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Is 1300 with cutting and all? Or is it just paint?
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 11-22-2014, 07:46 PM   #257
spitfire481
Drives: 2JZ FRS
That's just pant on the 8 pieces. I had 22 body labor hours in doing the cutting/welding/fitting the right way. So roughly $900. The rears take some time to weld up and seal like they would be factory
MoTeC
Build Thread
@spitfire481
Old 11-22-2014, 08:56 PM   #258
sdwagonjp
sdwagonjp's Avatar
Old 11-22-2014, 08:58 PM   #259
sdwagonjp
sdwagonjp's Avatar
Old 11-22-2014, 10:45 PM   #260
spitfire481
Drives: 2JZ FRS
Originally Posted by sdwagonjp View Post
Also the fenders alone are eight pieces. 12 including skirts, lip and diffuser.
Oh I know. I did a full version 2 install
MoTeC
Build Thread
@spitfire481
Old 11-22-2014, 11:01 PM   #261
sdwagonjp
sdwagonjp's Avatar
Old 11-22-2014, 11:08 PM   #262
spitfire481
Drives: 2JZ FRS
Anything I should look out for or any tips with install?
It was all pretty straight forward for me. I do this stuff for a living. The hardest part is cutting the rear and working the inner and outer quarter panel layers together and welding/sealing it up
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 11-23-2014, 12:20 AM   #263
AznKirby
Are you 20/20?
AznKirby's Avatar
Welp, 2k install seems about right.
2014 FR-S Monogram
IG: @MonKehC
Old 11-23-2014, 12:54 AM   #264
sdwagonjp
sdwagonjp's Avatar
Old 11-23-2014, 01:40 AM   #265
AznKirby
Are you 20/20?
AznKirby's Avatar
Originally Posted by No5ki View Post
Yup 17x9.5 +18 with adapters for the 114 bolt pattern. I think they were meant for evos
25 mm adapters? Is that too sunken in for the rear?
2014 FR-S Monogram
IG: @MonKehC
Old 11-23-2014, 02:41 AM   #266
sdwagonjp
sdwagonjp's Avatar
Rocket Bunny Kit ??? Cosmetic Modification (Interior/Exterior/Lighting) 29 04-01-2014 05:21 AM
Rocket Bunny kit (just lip) encity5 Cosmetic Modification (Interior/Exterior/Lighting) 8 11-01-2013 10:01 PM
Rocket Bunny ver.2 kit SnapOv3st3r FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 08-19-2013 07:29 PM
Oh hey, another Rocket Bunny! CanibeatNoel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 47 07-12-2013 11:08 AM
WTB Rocket Bunny kit Yamajee Exterior Parts (Aero, Lighting, Etc.) 5 05-21-2013 09:23 AM
