go_a_way1
Old 11-21-2014, 02:45 PM   #7967
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by robwbright View Post
Yes, it would!
BTW, I drove the car 25 miles each way last night, getting home at about 8:15. 12.90 when I got home. The car sat overnight with amp unplugged and ESC off.
12.55 a few minutes ago and it started at 32 degrees F. I checked the battery with the car running. 14.50.
I assume that 12.90 to 12.55 overnight in 20+/- degree F temps means I either have an unknown drain or a bad battery..?
Similar experience here. Measured it in the morning after sitting overnight for 10 hours.
It rose a little every few times I measured it:
12.36v
12.44v
And seems to stay at 12.58v
It was 19F and started up.
TM is offline   Reply With Quote
Old 11-21-2014, 03:21 PM   #7968
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
12.36v
12.44v
I had a high school physics teacher who believed that the dome light in a car helps the car start on a very cold day. Here's how he came to this conclusion...
By opening and closing the car door we place a very small, short-term demand for current on the battery. This current demand that only lasts a few seconds acts to "wake-up" or excite the battery, causing the internal temperature to raise and the available current to increase - preparing the battery for the large starting demand. I had/have no reason to doubt him and have believed his theory for 30+ years.
Attaching the volt meter also creates a small load on the battery. Your experience proves his theory.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 11-21-2014, 03:24 PM   #7969
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
So I set the dome light to come on when the car door opens but turn everything else off? LOL
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 11-21-2014, 05:38 PM   #7970
FingR-S
I got sucked into boost..
FingR-S's Avatar
Drives: Whiteout FR-S & Supercharged BRZ
I wonder if running LED's help take any load off the battery? Probably not a noticeable amount. The coldest nights here are max 28F, so I've never encountered any starting problems.
I did notice my battery terminal had come loose. The voltage meter was dropping today. It had gone up to 28.8 max this last week, but today it started at 28.7, then after an up hill pull about 10 seconds, it stayed at 28.5, then dropped to 28.3.. so I looked at my battery and saw the could-be culprit. I'll tighten that and check it later.
For sale: 2013 BRZ Vortech Supercharged with nice updates.
Vortech Supercharger - Perrin exhaust - 245 RS3 on RPF1's
FingR-S is offline   Reply With Quote
Old 11-22-2014, 12:29 AM   #7971
Gums
Drives: SWP BRZ
Get us the part number & specs. A more powerful battery with the same physical foot print would be welcome news to just about everyone.
It's Saturday here, I've emailed and will post part No's on Monday.
Gums is offline   Reply With Quote
Old 11-22-2014, 01:30 AM   #7972
robwbright
I don't really know how to compare power ratings between the wheelchair batteries and "normal" car batteries, but this looks interesting (although expensive):
http://www.phasteksport.com/2013-Sci...ery-b14115.htm
2006 Saab 9-3 2.0t
Old 11-22-2014, 11:53 AM   #7973
robwbright
Last drove yesterday at 1:00 pm. Turned everything off. Last night at 8:00 pm the battery tested 12.55. This morning at 10:50 am it tested 12.45 and was weak but started.
2006 Saab 9-3 2.0t
Old 11-22-2014, 12:24 PM   #7974
Gary in NJ
Gary in NJ's Avatar
Are you arming the alarm? The alarm system does have a fair quiescent current draw because it is actively listening to the vehicle sensors.
Old 11-22-2014, 05:38 PM   #7975
robwbright
I touch the two little slits on the door handle to lock the car... Which I think also arms the alarm. Correct?
Are you saying that the battery's power is so close to not being enough to start the car in cold weather that I will have to choose between using the alarm, having the ESC installed, or buying another battery?
If that's the case, then this battery was never strong enough for this car in temps below freezing. What I want - and I'd assume others want - is a battery that is strong enough to actually run the car like its OEM for the whole winter without shutting everything off everytime I get out of the car.
Is there a battery strong enough to do that and fit under the hood? Preferably that doesn't cost $200.
2006 Saab 9-3 2.0t
Old 11-22-2014, 06:22 PM   #7976
Gary in NJ
Gary in NJ's Avatar
What I'm saying is that your battery seems to drain faster then others. I too, as well as our friends in Canada, have had temps well below freezing, yet our cars start in the morning. I'm just trying to identify what is different with your car.
I don't use my alarm at night...or ever really. I know from past experience that an alarm system can draw a lot of current. I don't think I'd want to play starting roulette every morning, so if I was having inconsistent starts I'd probably go back to a 1.0 dump pack and run a larger battery in the colder months.
Old 11-22-2014, 11:35 PM   #7977
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I agree, all batteries are different, and operate within a set tolerance. Yours just seems to be so close to the low end of that tolerance that when it get's cold it can't get the job done.
Your condition seems to be rare, and a better battery would be much easier, but a few relays a step-down 2:1 transformer, and a toggle switch could be hooked up so we could actually use the dump pack to help start the car. It would be cool if we could do away with the starter battery all together, but that would be a serious undertaking.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 11-23-2014, 08:27 AM   #7978
WNDSRFR
Drives: FR-S,GTI
A transformer won't work (DC). But you could jumper 12V off the dump batteries in an emergency. You just need some really short jumper cables.
Old 11-23-2014, 11:48 AM   #7979
Gary in NJ
Gary in NJ's Avatar
Here's a $50 short-term solution to get you through the cold days...
[ame="http://www.amazon.com/Stanley-Ll1000-Li-Ion-Battery-Starter/dp/B005IU28AW/ref=sr_1_6?ie=UTF8&qid=1416757456&sr=8-6&keywords=lithium+car+battery+booster"]Amazon.com: Stanley Ll1000 Li-Ion Battery Jump Starter: Automotive[/ame]
Old 11-23-2014, 04:36 PM   #7980
TM
TM's Avatar
Drives: DGM BRZ 6MT
After leaving my car off for a little over 24 hours, it read 12.55v and started up nice and strong. It was also 52F, so I'm fairly certain the issue is temperature related. The only thing different I did was having the ESC switched to off instead of relay on/off.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
