Old 11-07-2014, 09:52 AM   #645
Junkwipe
Drives: Toyota Gt86
Here. I think it's all ok like the firts post.
Sorry the first photo have a bad cut and i don't know why
Junkwipe is offline   Reply With Quote
Old 11-07-2014, 11:25 AM   #646
Junkwipe
Drives: Toyota Gt86
Here the second.
Old 11-10-2014, 03:29 PM   #647
Junkwipe
Drives: Toyota Gt86
no one can help me?
Old 11-10-2014, 05:14 PM   #648
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Hey guys,
after I came back from vacation I noticed, that the battery in my car was dead. Probably because I left the OBD2 adapter connected for two weeks. After kickstarting the car, no phone can find the bluetooth adapter. It's probably broken (it was a SainSpeed one) and I need a new one. I was happy with the adapter up until now, but I probably should get one, that turns itself off after a while.
Any suggestions?
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker
Flasher is offline   Reply With Quote
Old 11-11-2014, 12:22 PM   #649
fika84
fika84's Avatar
I want this too. Have you gotten anywhere on it?
Originally Posted by G_Rossney View Post
So I know that there are other PIDs that can be configured because you can get this information on the Vbox Lite Data logger. I downloaded the CAN log for a Toyota GT86 and the following are available. However, I have no idea how to figure out get the info I need to setup the PIDs myself. If anyone knows the info or knows how to access it, please let me know.
Would love to get the setup info for Torque Pro;
  • Gear
  • Steer angle
  • Brake Travel
  • Clutch
  • WSP FL, FR, RL, RR (I'm gessing this is Wheel speed?)
  • TRC Mode
The following are in Torque Pro
  • RPM
  • Accel
  • Coolant Temp
  • Throttle
  • Oil Temp (thanks to the above)
fika84 is offline   Reply With Quote
Old 11-21-2014, 05:15 PM   #650
Astroboy
Astroboy's Avatar
Drives: None
Does torque's afr(m) respond correctly with the cars ecu. When ever I do a wot pull with my turbocharged frs it's lowest value reds 12.1
Astroboy is offline   Reply With Quote
Old 11-21-2014, 05:46 PM   #651
Foobar
SLO NO MO
Foobar's Avatar
Mine goes lower than that with a Supercharger.
Old 11-21-2014, 09:25 PM   #652
Astroboy
Astroboy's Avatar
Drives: None
Why doesn't mine?
Old 11-22-2014, 06:49 AM   #653
Foobar
SLO NO MO
Foobar's Avatar
Why doesn't mine?
Dunno, which MAP sensor do you have, and which tune? Maybe MAF scaling is off or something?
The Following User Says Thank You to Foobar For This Useful Post:
Astroboy (11-22-2014)
Old 11-22-2014, 11:14 AM   #654
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Anyone use the ethanol gauge? Mine doesn't work. Figure it would with the delicious tuning flex fuel kit.
texasbound972 is offline   Reply With Quote
Old 11-22-2014, 09:33 PM   #655
Astroboy
Astroboy's Avatar
Drives: None
Oem map sensor
Old 11-22-2014, 10:45 PM   #656
Foobar
SLO NO MO
Foobar's Avatar
Oem map sensor
I think the OEM may be your culprit.
Astroboy (11-23-2014)
Old 11-24-2014, 03:49 PM   #657
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Not sure if this has happened to anyone else:
I had setup the "fuel remaining" PID (2129) exactly as instructed.
It worked - for a time.
Then, I got a new adapter (the old one would drop the BT connection after a few minutes) and now I can't get the fuel remaining function to work anymore.
I've even deleted it and reinstalled - no dice.
Anyone run into this issue?
Thanks!
daiheadjai is offline   Reply With Quote
Old 11-26-2014, 11:05 AM   #658
fika84
fika84's Avatar
Originally Posted by Junkwipe View Post
Here the second.
Did you ever get this working? It might be your equation. You have "AC-40" and I think it should be "A*C-40".
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
