Old 11-20-2014, 01:11 PM   #7953
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by Gary in NJ View Post
You can investigate a drain condition by simply pulling fuses while in an off condition. If you get an increase in battery voltage while pulling fuses you've found the offending circuit.
Usually. Lol. I had a 2001 Saab 93 some time ago that had a bad drain... Somewhere. Battery and second battery were good. With assistance from my dad and another time my father in law, I pulled every fuse in the car. Twice. Could not locate the drain. None of us could find any explanation for it. Fortunately I was rear ended with no injury. Totaled the Saab and the other guys insurance paid more than I had paid for the car.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 11-20-2014, 01:44 PM   #7954
robwbright
Meeting over. Car tested 12.77 the moment the voltmeter touched the battery and within 20 seconds read 12.80.
2006 Saab 9-3 2.0t
Old 11-20-2014, 02:26 PM   #7955
robwbright
After 20 mile drive back, the battery read 12.89 and rose to 12.90. Five minutes later it was 12.91. Am going to check intermittently like @TM did and post results.
2006 Saab 9-3 2.0t
Old 11-20-2014, 02:46 PM   #7956
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by robwbright View Post
One more question... I still have the OEM battery. If I wanted to install it in the trunk, what gauge wire should I use for that? Would the long run require a larger gauge?
I think Jpit used 4 gauge for a while before converting to the 1.5 dump, I ended up running 2 gauge. I think I probably did over kill, but I haven't had an issue so far. I think you would be safe running 4 If you decide to relocate. It would be your choice to run a full ground to the engine compartment or just ground to the body in the trunk. Jpit grounded to the body in the trunk, I ran a ground from the engine compartment to the trunk, and grounded to the body at the back seat. Like I said, overkill.
I also think you guys just have some weak batteries. May not hold a charge, or may just be extra sensitive to temperature. IMO
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
The Following User Says Thank You to Target70 For This Useful Post:
robwbright (11-20-2014)
Old 11-20-2014, 02:51 PM   #7957
robwbright
Reasonable prices here?
http://www.wiringproducts.com/4-gaug...-battery-cable
What's it take? Will 25 ft do it?
2006 Saab 9-3 2.0t
Old 11-20-2014, 02:52 PM   #7958
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Before you guys move forward be patient. Let a few others chime in
Installed Mods:
Old 11-20-2014, 02:59 PM   #7959
robwbright
I'm not looking to buy in the next 24 hours or anything... but that Saab situation I mentioned earlier REALLY turned me off on electrical issues. I don't know how many times I had to pop the hood and unhook the battery terminals in the winter just so it would start when I came back out of the courthouse. My mechanic father in law came up with a solution - we were going to put a disconnect switch in the cabin to disconnect the battery from in there. But then the car got totaled and I bought a Honda.
2006 Saab 9-3 2.0t
Old 11-20-2014, 03:03 PM   #7960
robwbright
40 minutes later and it's 12.93 - higher than before. Hmm...
2006 Saab 9-3 2.0t
Old 11-20-2014, 03:47 PM   #7961
Target70
Target70's Avatar
25ft is more than enough. I think I did it with less than 15ft (per run)
here is my diy for anyone who is interested, or just wanting to see what is required: http://www.ft86club.com/forums/showthread.php?t=69409
And those are crack prices. If you have a harbor freight, northern tool, grainger, welding shop, etc.. you should be able to buy it local for much cheaper. Amazon has plenty of options if you have to have it shipped: [ame="http://www.amazon.com/TEMCo-Welding-Battery-Cable-WC0190/dp/B00LIB7XDM/ref=sr_1_4?ie=UTF8&qid=1416516035&sr=8-4"]TEMCo Welding Lead & Car Battery Cable WC0190 - 30' Black/Red (15' Blk, 15' Red) 4 Gauge AWG - - Amazon.com[/ame]
just search for 4 gauge welding cable.
just some starter info if you can't work anything else out.
Old 11-20-2014, 04:31 PM   #7962
robwbright
And those are crack prices. If you have a harbor freight, northern tool, grainger, welding shop, etc.. you should be able to buy it local for much cheaper. Amazon has plenty of options if you have to have it shipped: TEMCo Welding Lead & Car Battery Cable WC0190 - 30' Black/Red (15' Blk, 15' Red) 4 Gauge AWG - - Amazon.com
Very useful info. Thanks!
2006 Saab 9-3 2.0t
Old 11-20-2014, 04:42 PM   #7963
robwbright
Still staying up - 12.91. I'm confused. I'll check it once more before I have to drive 25 miles at 5:30.
2006 Saab 9-3 2.0t
Old 11-21-2014, 02:32 AM   #7964
Gums
Drives: SWP BRZ
Originally Posted by jwvand02 View Post
I ordered an odyssey pc925, I will have it tomorrow. I'll let you know how that works out.
My battery guy loves the Odyssey, he's convinced me to upgrade to them eventually.
He sells the same physical size battery as the recommended Powersonic to start V8 race cars.
Odyssey batteries also have larger terminals (less resistance) and are designed to cope with high under bonnet temps. They are a bit heavier.
No idea how they handle the cold.
Gums is offline   Reply With Quote
Old 11-21-2014, 09:08 AM   #7965
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Get us the part number & specs. A more powerful battery with the same physical foot print would be welcome news to just about everyone.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following User Says Thank You to Gary in NJ For This Useful Post:
robwbright (11-21-2014)
Old 11-21-2014, 10:53 AM   #7966
robwbright
Yes, it would!
BTW, I drove the car 25 miles each way last night, getting home at about 8:15. 12.90 when I got home. The car sat overnight with amp unplugged and ESC off.
12.55 a few minutes ago and it started at 32 degrees F. I checked the battery with the car running. 14.50.
I assume that 12.90 to 12.55 overnight in 20+/- degree F temps means I either have an unknown drain or a bad battery..?
2006 Saab 9-3 2.0t
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
