Old 11-19-2014, 11:59 PM   #1
magicchef
Drives: 2014 BRZ Limited
Choppy shifting
I've had a 2014 BRZ since June of this year. It is a ton of fun to drive! One problem is rough shifting, which I never had in my other cars. It seems that shifting smoothly or choppy-by bumping off the gears before slipping into the next gear-is only a matter of chance, and happens about half of all driving time. Does everyone else have this experience, and has anyone been able to address this successfully, maybe with Subaru? Thanks.
magicchef is offline   Reply With Quote
Old 11-20-2014, 12:23 AM   #2
aristo
aristo's Avatar
Drives: BRZ SWP 14
Welcome to da club.
some claim swapping transmission fluid makes a difference
some say a heavier shift knob will
some say transmission collars, mounts etc will
aristo is offline   Reply With Quote
Old 11-20-2014, 12:41 AM   #3
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
nothing wrong with my car... maybe shifting technique?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 11-20-2014, 12:49 AM   #4
kberkel
kberkel's Avatar
23k miles, mine feels good to me. My last car was 15 years old when I sold it. I think most people just expect more.
Do you mean while upshifting, it hesitates? Never had that.
kberkel is offline   Reply With Quote
Old 11-20-2014, 04:51 AM   #5
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Are you speaking of how you can hear the gears engaging after maybe 1/8 of a second, behind you when it's quiet outside? I personally have an issue shifting from 2nd to 1st. Sometimes it's smooth as butter. other times the shifter just won't go in.
carma143 is offline   Reply With Quote
Old 11-20-2014, 10:52 AM   #6
Erik1493
Drives: Blue Brz
Welcome to the basic sports car... If you want a butter shifter buy auto or get a civic si
Erik1493 is offline   Reply With Quote
Old 11-20-2014, 11:49 AM   #7
fika84
fika84's Avatar
I've swapped fluid to Redline and stiffened up the entire powertrain mounts. Cusco motor mounts, tranny insert, whiteline shift bushing, whiteline diff front bushing and cusco rear diff brace.
All of the above helped. When driving the car hard I noticed that it shifts much better in general and came to the conclusion that our transmissions just like being PUT into place, be assertive and accurate with your shifts and it should help out, don't be gentle. This is also why the heavier shift knobs help because they help shift with more force without changing the speed of your shifting motion.
fika84 is offline   Reply With Quote
Old 11-20-2014, 04:33 PM   #8
projectXTR
Drives: Sterling Silver BRZ
When your car is cold, let it idle in neutral for a minute or two. This usually does the trick for me !
projectXTR is offline   Reply With Quote
Old 11-20-2014, 08:36 PM   #9
Itzed
Assuming the engine and tranny are warmed up, I find the car very easy to drive smoothly when either going leisirely, or when driving with gusto. It's the in between normal speeds that seem to be a little jerky for me.
Itzed is offline   Reply With Quote
The Following User Says Thank You to Itzed For This Useful Post:
Formula Vee (11-27-2014)
Old 11-20-2014, 09:09 PM   #10
JACK 8URT0N
Black Blood of the Earth
JACK 8URT0N's Avatar
Drives: The Porkchop Express
In addition to the suggestions above, try leverage. I added a lever extender, paired with a weighted knob and rear shifter bushing. Shifts like butter. Latheworks custom made me mine, but they can also be found here:
http://www.circuithero.com/products.php
It's all in the reflexes.
JACK 8URT0N is offline   Reply With Quote
Old 11-20-2014, 09:10 PM   #11
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
It will get better with time, and as fika84 stated being assertive rather then gentle seems to get a much more positive shift while eliminating the bumping off of the next gear like you describe.
Jond63 is offline   Reply With Quote
Old 11-20-2014, 10:05 PM   #12
How many miles on the car now?
When cold, or all the time?
Upshifts, downshifts, or both?
Old 11-20-2014, 10:54 PM   #13
kberkel
kberkel's Avatar
I mounted my gopro to see the shifter tomorrow morning, it'll be about 15ºF. The car might not like 1st or reverse, but maybe it'll help show what it's like even at freezing temps. Once warm, it easily goes from 2nd-3rd or 3rd-4th with one finger.
Hopefully I can get good footage.. the shifter feels better than my last Ford, but of course no Audi
Old 11-24-2014, 09:27 AM   #14
fika84
fika84's Avatar
Is it only rough when it's cold?
shifting from 1st to 2nd jarviz Scion FR-S / Toyota 86 GT86 General Forum 35 05-26-2016 08:15 PM
shifting into 2nd cantaloupe BRZ First-Gen (2012+) — General Topics 63 06-23-2014 05:47 PM
Shifting into 2nd bpmorgan7 BRZ First-Gen (2012+) — General Topics 31 04-11-2014 05:39 PM
MT Shifting n8dog11914 Engine, Exhaust, Transmission 4 08-28-2012 04:28 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 06:09 PM
