| Engine Swaps Discussion of engine swaps. |
Drives: red brz
Hi guys,
Im new on the forums, just got a blown brz and it was the perfect home for my 2jz-gte making 600whp on pump gas ... I bought a chase bays wiring harness which we altered alot to make most things work.. After 2 days of wiring and rewiring everything correctly, I cant get everything to work properly .. Few things like -gauges.. Iknow this car has gauges running CAN bus, is there a way to bypass that and rewire gauges to the sensor directly ? tach ? H2O ? atleast -the most important aspect, THE STEERING WHEEL AND RACK, I lost electric steering and ABS ..although speed works so abs sensors are reading, the steering is very heavy and does not work, is there a way to make this working manually ? Ill post some pix abit later
#2 |
Drives: red brz
some pix of the build
#3 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#4 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
This is an email I got from Ekanoo's tuner back in July:
"We utlized the stock ECU to provide all the standard functions. We acquired EcuTek to disable all the DTC faults and alter some of the parameters. The trick is to get the Crank, cam, coolant, and air inlet temp reading of bothe the standard and AEM ECUs. I used AEM series 2 to run the engine. " |
#5 |
Drives: red brz
The chase bays wiring i got runs both ecus too...i bought it Thinking the car would run like stock or close atleast but its far oem..the steering doesnt work..the gauges dont work except speedo which is useless..i contacted them nurmerous times n i only get a short reply every few days and cant really do anything..might just swap the steering rack to something else
#6 | |
My FR-S has 5 gears
Omar GC
#7 |
Drives: 2013 Raven FR-S
Subbed
#8 |
My FR-S has 5 gears
I posted in the other thread after I realized your location and actual car(gt86)... So I'll restate it here...
As for the @Chase Bays harness not working 100% plug and play for you, I'm going to go on a limb and say it's VERY possible that the pin out for YOUR gt86 is slightly but notably different than the pin out for the USDM cars in which chase bays bases their harnesses from. However, I'll be able to verify it this upcoming month for you.
Omar GC
#9 | ||
TURBOLICIOUS
Drives: a machine :]
My backup solution if the electric rack setup fails, I will simply go with either a SC300/400 or S14 steering rack and OEM 2JZ power steering pump. Both parts have adequate space to work on our chassis and the rack may require some minor adjustments. As far as the ABS setup, EKanoo and his team got the factory ABS to work with an aftermarket standalone (AEM) and I am sure we can figure it out together or pull resources to find a solution. Quote:
#10 | |
#11 | |
My FR-S has 5 gears
Omar GC
#12 |
I ordered it earlier this month. It should be here today I think. When I ordered it, I ordered it outside their website so I think my order slipped through the cracks, but I contacted them a few days ago and they expedited it to me. No worries... I don't think you'll have any wait time.
#13 |
Drives: red brz
how much is the Fullblown kit,, ? does the price include everything you need to convert to return fuel system ? and single pump ?
#14 |
| How many of you Swapped your 86 for 15 WRX ? | Xti | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 08-09-2014 09:09 AM |
| BRZ with LS2 V8 swapped in video | SnapOv3st3r | BRZ Photos, Videos, Wallpapers, Gallery Forum | 14 | 11-14-2013 05:04 PM |
| BRZ Swapped with LS2 | weedtank | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 13 | 09-05-2013 05:02 PM |
| Swapped badges | JesseE | Northwest | 7 | 03-13-2013 05:20 AM |
| EJ25 has already been swapped | Tad_07 | Engine, Exhaust, Transmission | 3 | 03-25-2012 05:10 PM |
