#15 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Here is the only FT86 anti-reversion header
Here are some pics before i install it. Remember this is untested technology, and it could totally suck! I wanted more low-end torque and these are the only anti-reversion things I could find to adapt. They are made for Harley's and need some trimming to fit in the after-market header flanges I bought. The pics with the gasket show that it will seal to the flange just outside the weld holding the cone in. The cones are shaped with a taper going in and a shorter taper going out, and will act as a venturi to speed up flow into the header. I wonder if a dyno will go down to 1000 rpm? It should have more low-end torque when I'm done, and with an exhaust back-pressure valve, should get better mileage too.
#16 | |
Custom User Title
Drives: Asphalt FR-S MT
#17 |
I've already tried 2 other headers. They both had the same thing in common. Less low-end torque than the factory header making it harder to drive in traffic. This is my DD and I like the power and acceleration of a header. I just don't like falling behind in traffic because I don't even have the low-end torque of the factory header. The venturi cone inserts should increase the velocity of flow giving better scavenging, better torque. I actually installed it today, but with a stripped bolt in the over-pipe, I didn't get it all put together. Tomorrow I'll post my first impressions.
#18 | |
Are the venturi cones completely sealed behind them? to the rest of the header? Like is there an open space between them and the header tubing
#19 |
No, they do not touch the header tubes themselves. There is about 1/16 to 1/8" or more between the inside edge and the header tubing. They are only attached at the flanges. Once they heat up they should stay hot, since their heat can only travel out through the flange end, not through the header tubing. A hotter, narrower pipe and venturi will give greater velocity to the exhaust flow than the larger unflared transition from the exhaust port original header. I'm getting dressed for battle now, not only against the cold weather, but also against stubborn nuts and bolts. I'm also need to raise my coilovers 1 1/2" for winter mud and snow clearance. Long day ahead, but I'll let you know my initial impressions of the low-end torque capabilities once I get it back on the road this evening.
#20 | |
#21 |
Yes! It's a success! World's first FT86 anti-reversion header
It's back together, tuned with Shiv's latest 2.06 91 Octane Equal Length header tune, and it is fun to drive. Low-end torque and power are definitely higher than with just an ordinary header. I have an A/T and both 5th and 6th are overdrive. I climbed a hill I usually shift down to 5th for, in 6th gear, and even accelerated! I know you flat-earthers won't believe a word I say without a dyno for proof, so I'll try to book some time in the weeks ahead. The important thing is now there is something to give automatic's more low-end torque for better drive-ability. I'll be driving in traffic tomorrow, so I can see how well it keeps up with the V6 and V8 trucks and minivans. PM me for a parts list if you are interested in making one of these for yourself.
| The Following 2 Users Say Thank You to KoolBRZ For This Useful Post: | boredom.is.me (11-16-2014), FRSBRZGT86FAN (11-16-2014) |
#22 | |
#23 |
Any normal header, stock exhaust, turbo, compare it to whatever you want. I've had stock, SBD turbo, and an Xs-power headers with stock over-pipe, mid, and rear pipes on it before, also stock, dual, and single with dual outlet mufflers. So far the stock setup had the most low-end torque and gave the best mileage. The power and acceleration was sadly lacking though. This setup with A/R header, 2.5" overpipe, 2.5" midpipe, stock rear pipe and top speed pro 1 single inlet dual outlet muffler has more low-end torque, more power, and acceleration you have to see the video to believe. Videos coming later....
[ame]http://youtu.be/sbo8axAwIWI[/ame] Last edited by KoolBRZ; 11-17-2014 at 09:28 PM. Reason: added video link |
#24 |
Junior
Drives: a car
http://www.gomog.com/allmorgan/exhaustbackpressure.html
Exhaust back pressure should be at its minimal extrema, exhaust velocity should be at its maximal extrema.
#25 | |
| What do you consider low oil pressure? | protpibe | Engine, Exhaust, Transmission | 10 | 01-14-2014 10:19 PM |
| Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate | PineappleFriedRice | Transmission and Driveline | 0 | 11-08-2013 04:54 PM |
| Oil Pressure.. too low? | Dave-ROR | Tracking / Autocross / HPDE / Drifting | 65 | 08-24-2013 12:43 AM |
| Not enough exhaust Back Pressure? Quiet car? | mtimney | Engine, Exhaust, Transmission | 11 | 08-05-2013 11:10 PM |
| Possible trade? Nameless axle-back for Perrin Resonated Cat-back | GTB/ZR-1 | Engine, Exhaust, Bolt-Ons | 0 | 03-26-2013 01:51 PM |
