Old 11-11-2014, 07:04 PM   #617
mkivsoopra
Originally Posted by Mrc@ptuning View Post
That's the reason the coolant system is pressurized. The best coolant is pure water. The antifreeze is added on to keep the water from freezing and potentially cracking the block in cold weather. Plus the additive is there to lubricate the water pump. If you track the car often and live in a warm climate, the best "coolant" is pure distilled water and some water wetter.
Distilled water + water wetter here. Might put some anti-freeze in for the so-called winter here though, just in case.
mkivsoopra is offline   Reply With Quote
The Following 4 Users Say Thank You to mkivsoopra For This Useful Post:
CSG Mike (11-11-2014), Deadpool_25 (04-27-2015), kanundrum (11-11-2014), Mrc@ptuning (11-11-2014)
Old 11-11-2014, 10:57 PM   #618
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Originally Posted by Blizzz View Post
If you guys are seeing 212+ water temps, you've got boiling water running through your lines...
u gotta be effing kidding right???
I assume u have not taken high school physics.....
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following 3 Users Say Thank You to RehabJeff86 For This Useful Post:
civicdrivr (11-12-2014), mkivsoopra (11-12-2014), OICU812 (11-11-2014)
Old 11-11-2014, 11:04 PM   #619
CSG Mike
CSG Mike's Avatar
Pressure is your friend.
RehabJeff86 (11-11-2014)
Old 11-11-2014, 11:45 PM   #620
bjun
bjun's Avatar
Drives: white premium brz M/T
Actually it's more chemistry :p
Everyone is right but I also wanted to add that water in our car does not boil at 212F because the chemicals in antifreeze not only decrease the freezing temperature of water but also increases the boiling point. So although normal water boils at 212F, water mixed with antifreeze "coolant" will see a significantly higher boiling temperature
bjun is offline   Reply With Quote
The Following User Says Thank You to bjun For This Useful Post:
Old 11-13-2014, 12:08 AM   #621
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
last night with regular street driving ambient temp around 59F.
mnsayer is offline   Reply With Quote
Old 11-13-2014, 04:12 AM   #622
sw20kosh
Drives: 2013 Black FR-S
Coolant right? Not good. why are you running so hot on the streets with such low ambient? I wasn't running that hot even in 90-100 deg ambient on street. Fans would kick in at 214 and stop at 208 so worst case scenario in traffic I would see those temps.
The only time I saw hotter temps than that on the street was with a leaking robispec radiator.
Right now with a 25 row setrab oil cooler, my coolant never goes above 200 and oil never goes above 160 on the streets in 60-70 deg ambient.
The Following User Says Thank You to sw20kosh For This Useful Post:
mnsayer (11-13-2014)
Old 11-13-2014, 04:45 AM   #623
mnsayer
mnsayer's Avatar
Thats whats getting me confused, I have a Koyo radiator installed and installing the Ptuning oil cooler today. Im very surprised I am going to check the sensors as well to make sure thats not the issue.
Old 11-13-2014, 02:23 PM   #624
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Where does your gauge get the temperature from? The absolute highest water temp my car has seen on the track in 100F degree weather was 237F via EcuTek logs using the single oem sensor in the car. Something is definitely wrong with that readout. Make sure you don't have air in the system, that would definitely cause a bad read.
rb6freak is offline   Reply With Quote
The Following User Says Thank You to rb6freak For This Useful Post:
mnsayer (11-14-2014)
Old 11-13-2014, 09:49 PM   #625
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Originally Posted by rb6freak View Post
So a while ago I showed some of you a custom firewall strut tower brace I was coming up with to clear the 4" intake pipe. Do these things really help? I'm not sure, but I suspect they help with high speed turns. They wouldn't just be there for looks. Anyways, I'm getting closer to building the final product. I made sure this will clear the hood and it also clears the pipe. I will test fit the first set. The bracket is stronger/thicker than the pipe in the event of a front collision so hopefully the bar will bend or snap out the way and not punch through the firewall. The bar is only 18" long or so, so I wouldn't be too worried either way. Here are some pics:
Early mock-up of the design with paper and cardboard.
And the brackets.
And here is the finished piece! I'm going to test it out this weekend.
The Following 4 Users Say Thank You to rb6freak For This Useful Post:
bjun (11-13-2014), buddy32 (11-14-2014), mkivsoopra (11-14-2014), sw20kosh (11-13-2014)
Old 11-14-2014, 08:38 AM   #626
buddy32
Drives: WRB Subaru BRZ Limited
Just ordered the kit and a supporting cooling stuff, anxiously waiting since kits are backordered. Hoping for early December delivery. Can't wait to install and hit Road Atlanta!!
Thanks to MrC, Toan, Mike and Patrick for answering all my questions patiently and getting the order through! Shout out to @rb6freak and @CSG Mike for helping me along the decision path as well!
@Mrc@ptuning, @ptuning
buddy32 is offline   Reply With Quote
The Following 3 Users Say Thank You to buddy32 For This Useful Post:
CSG Mike (11-15-2014), Mrc@ptuning (11-14-2014), rb6freak (11-14-2014)
Old 11-14-2014, 09:51 PM   #627
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
I know you guys are all drooling, its okay, let it all out.
bjun (11-14-2014), CSG Mike (11-15-2014), Hicklinc (01-16-2018), mnsayer (11-15-2014)
Old 11-14-2014, 11:21 PM   #628
bjun
bjun's Avatar
Drooling? I think that's an understatement.
I think I wet my pants...
The Following 2 Users Say Thank You to bjun For This Useful Post:
kanundrum (11-14-2014), rb6freak (11-14-2014)
Old 11-15-2014, 03:38 PM   #629
CSG Mike
CSG Mike's Avatar
This is still my favorite turbo kit.
The thought of it with a GTX28 makes me giggle.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
mkivsoopra (11-16-2014), rb6freak (11-15-2014), sw20kosh (11-16-2014)
Old 11-15-2014, 08:36 PM   #630
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Last couple photos before it goes on the car. It's so gorgeous - I would totally mount this on the wall as a centerpiece.
ptuning, turbo kit
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2639 04-05-2026 10:31 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
