Old 11-12-2014, 11:00 PM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Removing two silver pieces on outside of climate controls & steering wheel plastic
Does anyone know how do remove these? I took the radio surround piece off and removed the screw's from the two pieces I'm looking to remove but I can't figure out what's holding them in.
Also need help with removing the silver plastic from steering wheel.
Thanks
B-R-Z is offline   Reply With Quote
Old 11-12-2014, 11:29 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
http://www.ft86club.com/forums/showthread.php?t=12257
Old 11-13-2014, 10:01 AM   #3
B-R-Z
B-R-Z's Avatar
Is there any way to do this without removing the airbag? That make me nervous
Old 11-13-2014, 10:34 AM   #4
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
You can have someone hold the airbag without disconnecting it if you really want to play it safe, but it absolutely must be removed from the steering column to access the two screws that hold in the plastic.
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
B-R-Z (11-13-2014)
steering wheel controls inimitable BRZ First-Gen (2012+) — General Topics 79 09-05-2016 01:56 AM
Steering wheel radio controls brillo Electronics | Audio | NAV | Infotainment 6 12-26-2014 11:03 PM
BRZ Steering Wheel Radio Controls rmjjensen Electronics | Audio | NAV | Infotainment 30 02-16-2014 06:15 PM
Subaru dun goofed: what steering wheel controls? Turbowned BRZ First-Gen (2012+) — General Topics 9 03-20-2013 11:25 AM
Steering Wheel Controls theredtape Electronics | Audio | NAV | Infotainment 6 11-21-2012 10:59 AM
