#659 |
Drives: 2013 BRZ Limited
I pushed the letter pegs out from the inside (not much effort needed). I then placed the STI badge as best I could to cover all the holes, but it left the two on the right uncovered. Finally, I covered the right two holes with blue painter's tape and filled all the holes with black silicone from the inside.
| The Following User Says Thank You to FearBoy For This Useful Post: | Boxer486 (07-16-2014) |
#660 | |
Drives: Blue ZC6
#661 |
Installed
#662 |
Tuned a car with one of these yesterday. I've noticed on the last couple of these I've tuned that they really jack up the MAF a lot more than you'd expect a TRD product to do. With the stock rom it was pretty far off... causing power to be down considerably up top. After tuning we were able to get it all back and make some pretty nice gains.
Virtual dyno runs for comparison purposes only obviously (it was a street tune). They were made same day/conditions/road/etc though. Only difference was the rom:
| The Following User Says Thank You to jamesm For This Useful Post: | FearBoy (07-16-2014) |
#663 | |
Drives: Subaru BRZ Limited
Does TRD intake has much lower HP and torque than stock <4000rpm range? Thanks. |
#664 | |
I don't remember specifically how the other cars compared to this one on the stock rom.. but i've definitely noticed a trend towards leaning the cars out significantly. I do remember noting that the amount of timing being pulled was considerably more than what is typical on a couple of them. |
#665 |
BOXER FR
Drives: WRB BRZ Limited
is the TRD louder inside compared to OEM? I actually quite like the induction sound now, dont want it to go away... Or am I the only one that thinks that the sound tube actually works?
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
#666 |
Drives: 2017 WRB BRZ w/ PP
Definitely not louder, as the intake tube is removed. You will lose some of that induction sound, but I like hearing the more natural engine noise.
| The Following User Says Thank You to tomkozski For This Useful Post: | mokinbird87 (08-04-2014) |
#667 | |
BOXER FR
#668 | |
| The Following User Says Thank You to tomkozski For This Useful Post: | mokinbird87 (08-07-2014) |
#669 |
TRD is way quiter than stock, but you can modify the snorkel to get a lot of (real) noise back.
| The Following User Says Thank You to Kostamojen For This Useful Post: | mokinbird87 (08-07-2014) |
#670 |
Someone painted or dipped this part?
![]() I'd like "stealth" engine bay and I wonder if is it possible to dip it (and if resist the paint)
| The Following User Says Thank You to Teo For This Useful Post: | JOSI (11-17-2014) |
#671 |
The SquadWhisperer
Good luck painting silicone.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
#672 | |
Hit the road and I'm gone
Is this anything more than hexane/standard electronic parts cleaner? Thanks for the reply.
Slip, slidin' away.
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 01:43 AM |
| So cold air intake or air intake? | bcmakesiteasy | Engine, Exhaust, Transmission | 12 | 02-01-2014 09:06 PM |
| HKS intake setup VS Injen intake,,,what are your thoughts? | JDMrolla | Engine, Exhaust, Transmission | 4 | 10-11-2012 02:31 PM |
