Old 11-12-2014, 07:14 AM   #1
jvincent
jvincent's Avatar
E85 and oil temperature
Either my google-fu is bad, or there isn't a specific discussion on this topic.
I'm curious if anyone has compared the oil temperatures when running E85 vs 93 octane (or 91) on the track.
There are lots of oil temperature and oil cooler threads but I'm curious if the added cooling of E85 will also help to keep oil temperatures down.
@Reaper, I know that you run E85 pretty much exclusively, but I didn't see that you ever did a comparison. If you did, could you share the data?
Old 11-12-2014, 07:49 AM   #2
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
I've only run e85 on track once, but I noticed my oil temp was 8-10C cooler with e85.
Tye300 is offline   Reply With Quote
Old 11-12-2014, 11:27 AM   #3
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Well I've never used pump gas. But with just a deep oil pan and a cut cowl running amsoil dominator 10w30 running 16-19 psi in the mountains pretty hard. Hard enough to damage stock brakes I have pretty consistent oil temps. Now I have an oil cooler sitting on my bench ready to go in completely assembled but until the oil temps get higher it's not going in. 8 quart oil changes are expensive enough without adding another quart to it.
Old 11-12-2014, 12:53 PM   #4
Reaper
Reaper's Avatar
Drives: violent
Hottest oil temp I've seen is 230* F and that was when I melted a dust boot on my brake caliper being wreckless in some extreme elevation changes. I also damaged a transmission that day. Flat foot shifting in the mountains.
Old 11-12-2014, 01:10 PM   #5
jvincent
jvincent's Avatar
Thanks for the info guys.
I've hit 262* on the track this summer, so I'm trying to figure out my options for next seasons.
If E85 runs cool enough then I won't need to mess with an oil cooler and I'll get the moar powah benefit, so that's a double win.
Old 11-12-2014, 08:17 PM   #6
jflogerzi
jflogerzi's Avatar
Get an oil cooler trust me
2013 Series 10 FRS #553
Old 11-12-2014, 08:21 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
You'll need an oil cooler to begin with. These cars should come with one from the factory, right out of the 2015 wrx.
Old 11-12-2014, 08:23 PM   #8
mkivsoopra
I've always run E85 at the track. I don't have any hard numbers, but the temperature difference (if any) is not enough to offset the need for an oil cooler. FI and NA.
mkivsoopra is offline   Reply With Quote
Old 11-12-2014, 08:39 PM   #9
jflogerzi
jflogerzi's Avatar
I think you are sadly mistaken. In hot temps in na form these cars get much to hot let alone boosted. Get an Bluetooth adapter and torque. Log your temps.
Old 11-12-2014, 08:46 PM   #10
mkivsoopra
No, the only sad part is your reading comprehension. We're in agreement.
The Following User Says Thank You to mkivsoopra For This Useful Post:
jflogerzi (11-12-2014)
Old 11-12-2014, 08:51 PM   #11
jflogerzi
jflogerzi's Avatar
That's what I get for reading on my mobile. My apologize.
Old 11-12-2014, 08:53 PM   #12
mkivsoopra
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 08:55 AM
Color Temperature FRSure Cosmetic Modification (Interior/Exterior/Lighting) 14 01-03-2014 11:19 PM
Running Temperature? 350matt Engine, Exhaust, Transmission 13 10-29-2013 03:55 PM
Intake Air Temperature sw20kosh Forced Induction 18 06-19-2013 04:49 PM
Exterior temperature 2thdoc Scion FR-S / Toyota 86 GT86 General Forum 15 04-28-2013 04:45 PM
