#29 |
Drives: 2013 Scion FRS firestorm
I love how plain/stock looking this intake is and how much visual room it clears up. I just wish I could believe that this would actually be better than a drop in filter. :/
#30 | |
I plucked this from post #1173 of the development thread: "The gains in power over the drop in filter are EVERYWHERE. Most intakes are good or even noticeable if you happen to drive your car between 6300 and 7300 rpms daily, otherwise gains anywhere else in the powerband generally don't exist. The drop in filter and other intakes we tested don't show gains in the torque dip, which is definitely something you experience in normal driving constantly. I think that the AFRs are a little better than "slightly," as hitting nearly 14.0 AFRs at WOT is fairly unacceptable. Continue to hit AFRs that lean, and you risk knock, which will then lower your advance multiplier, and all the sudden those gains you were making will be all gone. THAT is the major advantage of mimicking the stock AFR curve, especially when you get into tuning it. The time to install will vary for people. There is NO DOUBT that spending 50 bucks on a filter, and being able to just drop it in, and make a few horsepower is awesome. But there is also something to be said about having a fun, short project to work on, especially one that drastically changes the appearance of the engine bay. Some people will love this, and some people will choose not to get the tools out and wrench on their cars, we completely get it! I threw together a dyno chart that shows some key points. What is shown in this dyno chart is stock intake, K&N Drop in only, K&N with silicone elbow, and GrimmSpeed intake. All have stock snorkel, so this represents how most people will install their intakes, especially to save on time. ![]() The GrimmSpeed intake makes more power than both options from 2200 rpm, all the way to 7000 rpm, where if you look at the AFRs it has gone richer than stock. The K&N drop in alone actually loses a little in the torque dip, makes about 1hp over stock for most of it's horsepower curve until 6300 rpm where it picks up a little less than 3hp. It's a solid gain for very cheap, but the AFRs are a full point leaner (and sometimes more) the entire time. When you add a silicone elbow into the mix there is a slightly improved gain nearly everywhere (but still less than the GrimmSpeed intake) but the AFRs are even worse between 5000 - 6300 rpm, where it even crosses over 14.0 AFR. All in all, this shows that we've made something that makes power over a cheap and great option, without making power by being excessively lean, in an attractive package. We understand that this option isn't for everybody, but for a daily driver this will be one of the best options available for these exact reasons. We're not here to trick anyone, post false dynos, or show anything that you yourself could not go to a dyno and perform yourself. We want to show everyone what we've accomplished (very proudly we might add), and show how it performs against other options honestly. I don't think there is another company out there that is doing what we're doing here." Chase Engineering |
| The Following 3 Users Say Thank You to GrimmSpeed For This Useful Post: |
#31 | |
With that said, here's a chart from our dyno testing of the final production intake. ![]() Matt Beenen Engineering |
| The Following User Says Thank You to GrimmSpeed For This Useful Post: | F1fletch (11-12-2014) |
#32 | |
I'd love to see how much gain to expect. I love my Perrin intake, the noise it makes is so sexy, but I'm getting sick of taking my bumper off to clean the filter. Looking at my options and this would go a long way toward my decision.
| The Following User Says Thank You to phrosty For This Useful Post: | Sherb (07-13-2016) |
#33 | |
I can tell you that we did do pulls with OFT 1.59 with stock intake when we dyno'd last time, and our intake untuned was able to out perform the stock intake + OFT 1.59 tune almost everywhere, but still not in the torque dip where Shiv was able to add TONS of power. ![]() Run 1 is stock intake stock tune, run 3 is stock intake with OFT 1.59 tune, and run 5 is GS Intake UNTUNED, and run 7 is the GS Intake with the 1.59 OTS (not the GS Intake tune). So like I said, we're extremely excited to get our hands on this tune as well, and will get it on the dyno as soon as we can, weather permitting. So while I can't answer your specific question, this information alone should be a good indicator that that our intake WITH the new OFT tune will be a beast. Chase Engineering Last edited by GrimmSpeed; 11-13-2014 at 10:38 AM. Reason: Posted the wrong dyno! |
#34 | |
Drives: FR-S 10 #103 AT
There is also a significant improvement from 1.x to 2.x. There would not be such a difference if that dyno was with a 2.x map. Of course, with what they learned developing the 2.x, they could probably get even more from your intake too.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#35 | |
But after poking around the software forums (which I rarely get to do anymore), I was able to find this link: http://openflashtablet.com/Automotiv...ads/index.html Which has the missing 2.0 files, which i would have NEVER found. However, I wasn't able to find any dyno charts showing the significant improvement from 1.59 to 2.0 that you're talking about. But you're right, since this GS Intake OTS tune was only developed a few weeks ago, it's probably safe to assume that it has said improvements included. Chase Engineering |
#36 | |
.The trick is to go to the Site Map then choose Downloads from the FR-S section. You get a different list.
#37 |
Señor Member
I am running the OTS 2.0 and the GrimmSpeed intake and it is super smooth. It is the best idle and low rev drivability I have had on my car yet including stock everything.
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | GrimmSpeed (11-13-2014) |
#38 |
Drives: '13 BRZ Ltd
#39 | |
With the 1.59 OTS, it is awesome, even MORE power. The sound it makes during the cam change in the torque dip through the airbox is nothing short of amazing. We can't wait to get our hands on the dedicated GS Intake tune OTS from Shiv, even though we probably won't be able to drive our car for a while til the snow melts ![]() Chase Engineering |
| The Following User Says Thank You to GrimmSpeed For This Useful Post: | ck-GT86 (11-14-2014) |
#40 | |
Drives: 2015 WRX
| The Following User Says Thank You to Malt For This Useful Post: | Cop (11-14-2014) |
#41 | |
aeiou
Drives: WRB BRZ
| The Following User Says Thank You to unsurety For This Useful Post: | ck-GT86 (11-14-2014) |
#42 | |
| Grimmspeed hood strut review | whataboutbob | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 03-26-2025 07:35 PM |
| ** GrimmSpeed BRZ/FR-S Air Intake - GROUP BUY ** | GrimmSpeed | Engine, Exhaust, Bolt-Ons | 1902 | 08-29-2017 07:47 PM |
| GrimmSpeed Review | Khalis | User/Vendor/Sponsor Reviews, Feedback, Comments | 45 | 03-06-2014 11:20 PM |
| Grimmspeed Review | Thongpocket | User/Vendor/Sponsor Reviews, Feedback, Comments | 4 | 11-07-2013 11:56 PM |
| REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley | draggin_az | Engine, Exhaust, Transmission | 21 | 04-29-2013 04:58 PM |
