Old 11-12-2014, 12:03 AM   #309
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Originally Posted by Dezoris View Post
0w20 was tested with and without FI. Very similar results as pressures are relative to oil temps.
All other results are with oil cooler and FI.
Do you have any info on the pressure drop associated with adding an oil cooler? Probably not a lot but I don't think I've seen pressure data on a stock engine yet.
Decay107 is offline   Reply With Quote
Old 11-12-2014, 12:31 PM   #310
BRZGM3
BRZGM3's Avatar
Drives: CBS brz limited
Not sure if anyone has seen it yet. But holinger just posted on their facebook a drop in 6 speed sequential trans for the 86 platform. . . Probably 20k but still.
BRZGM3 is offline   Reply With Quote
Old 11-12-2014, 08:10 PM   #311
keen as
keen as's Avatar
Drives: 86 GT MT
from one of their facebook posts:
"As per our post from August the Bellhousing featured in this kit can be used on the SG series [365Nm (270ft.lb) and RD6 series [880Nm (650ft.lb)] transmission, so regardless of your Torque rating we will have a solution covered. The bigger transmissions of course would require some Tunnel modification. The SG featured here will handle any NA application and mild force-induction situations. When viewing the Torque-Ratings we give our products, bear in mind that these are for 24 Hour Endurance racing, with professional teams, drivers, race cars and slick tyres. It has been suggested that the SG could potentially be weaker than the stock transmission due to size etc. We can assure you that it is much more capable than the stock transmission! Don't be fooled by size and always take "Torque-Ratings" published cautiously. Our Torque-Ratings are not "Failure-Ratings" in any way shape or form! This is not what you can say about most transmission companies........"
keen as is offline   Reply With Quote
Old 12-16-2014, 05:10 PM   #312
blown
Drives: ft86
thoughts on running 10w60?
blown is offline   Reply With Quote
Old 12-16-2014, 05:12 PM   #313
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
This has been covered many times in multiple threads already
Old 12-16-2014, 05:14 PM   #314
Reaper
Reaper's Avatar
Drives: violent
That scares me. 10 w 40 seems to work real well. Someone tested 50w and if I remember correctly oil temps went way up. I just see there being enough bearing clearance for that.
Old 12-16-2014, 06:29 PM   #315
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Pretty much get it out of your head bearing clearance or any motor clearances in this engine limit the viscosity you run. Trust your oil pressure gauge as it does not lie or have an opinion
Stay away from widespread oil viscosities because they aren't as stable at high temps. I have tested them without very good results. This is due to the polymers they have to add. I run Red Line 50w Race for what it's worth.
All coolers have some pressure drop but that drop is offset by the cooler oil having more viscosity at a lower temp. Remember viscosity is rated at 100c only!
Element Tuning is offline   Reply With Quote
Old 12-17-2014, 11:48 AM   #316
Reaper
Reaper's Avatar
Drives: violent
True^
Old 12-17-2014, 01:21 PM   #317
sw20kosh
Drives: 2013 Black FR-S
Widespread meaning... something like 10w30? 10w40?
Old 12-17-2014, 02:06 PM   #318
Calum
That Guy
Drives: 2013 asphalt FRS MT
More like 0w40, from earlier in the thread.
Old 12-17-2014, 02:45 PM   #319
Element Tuning
No. Like just mentioned a widespread would be 0w40, 5w50, 10w60, etc. Better would be 10w30, 15w40, 20w50, and the best would be straight weights like Red Line 30, 40, or 50 as they are more stable at very high oil temps (they flow like regular multi-grade oils when cold however).
Old 12-17-2014, 09:47 PM   #320
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
No not really. You have to remember the FRS/BRZ is an NA car and it's oil pressure is enough for that so there are no issues handling that power level. The 2015 WRX has much more power and the oiling system is barely better. Both are just adequate enough for +75 HP bump or so.
You stopped us from looking at the wrx. Thanks.
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 12-17-2014, 10:14 PM   #321
mike the snake
I'll be switching to 30wt Motul or Redline on my next change.
Old 12-17-2014, 11:26 PM   #322
Element Tuning
I feel like the STI stuck with the EJ because of the limits with the oiling system used for the FA currently. I'm sure they'll work it out in time but hopefully they don't just make it adequate for oem power levels.
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
