Old 05-05-2012, 09:28 PM   #1
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Engine Block #
No, I'm not asking for name of the engine.
So while I was reading Japanese 86 site, I read that, in the engine block, there are a five digit numbers plus a four letter.
Example:
22222 BBBB
232323 ABAB
They said that, if you have all the numbers & letters same, better the quality of that engine was built.
There were few owners w 22212 BBBB, 21122 BBBB, but most owner had 22222 BBBB
so just wondering how's US or other country FRS/BRZ/GT86 owner engine built was
Old 05-05-2012, 09:34 PM   #2
Dimman
Kuruma Otaku
Dimman's Avatar
That's for piston to bore fit on Subarus or something?
Because titanium.
Old 05-05-2012, 09:39 PM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Idk, the forum starter didn't explain enough. Just ask what everyone has on the block
Old 05-05-2012, 10:03 PM   #4
Dimman
Kuruma Otaku
Dimman's Avatar
Some of the Subie guys can probably clarify but I think it has to do with making sure the right pistons go in the right bores when the engine is being built. I guess ideally if they were all the same the motor could be better balanced, but that's pretty extreme.
Because titanium.
Old 05-05-2012, 10:21 PM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
I thought I'm a Subie guy, but man I must be not a Gearhead than I've thought. I need to go back to garage & study more lol
Old 05-05-2012, 10:33 PM   #6
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
This probably doesnt translate to Subarus, but the Honda J series has a stamp in the bottom of the block that coincides with the crank bearings.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-05-2012, 11:33 PM   #7
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Typically numbers like this on the block will indicate cylinder bore sizes and crankshaft main bearing bore sizes. If the numbers and/or are all the same, then the block is "more precisely" machined, and all of your sizing is the same.
It honestly doesn't really matter though, as what these are actually used for is to correctly select the bearings and pistons to give you the correct oil clearances, which should be consistent across all engines.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following User Says Thank You to Jeff Lange For This Useful Post:
Fly Guy (05-06-2012)
Old 05-06-2012, 06:49 AM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
That would seem to matter if you replacing those parts.
To throw some more fuel on the fire, it could indicate how well the different parts of the mold were lined up during the casting process. I know older engines sometimes had trouble if they were being bored out and the casting didn't line up well, the cylinder walls would be too weak.
Old 05-06-2012, 09:44 AM   #9
Jeff Lange
Jeff Lange's Avatar
Correct, it matters when replacing parts. There will be markings on the crankshaft that also indicate the journal diameters for the mains and rods and markings on the rods as well. If you are replacing these parts you will use these markings to know which bearings and/or pistons to order to maintain the correct clearances.
Jeff
Old 05-06-2012, 09:46 AM   #10
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The letters are for the bores, so I believe the numbers are for the main bearings.
Old 05-06-2012, 10:24 AM   #11
Jeff Lange
Jeff Lange's Avatar
Correct, there are 4 pistons and 5 main bearing journals.
Jeff
Old 05-06-2012, 11:17 AM   #12
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Example:
22222 BBBB
232323 ABAB
where exactly on the block is it?
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 05-06-2012, 11:18 AM   #13
ichitaka05
Site Moderator
ichitaka05's Avatar
Let me check the Japanese forum...
Old 05-06-2012, 11:22 AM   #14
ichitaka05
Site Moderator
ichitaka05's Avatar
He said
"Center of engine block below engine throttle."
civicdrivr (05-06-2012)
Open Deck Block nrclptcnsmniak Engine, Exhaust, Transmission 36 01-27-2012 01:00 PM
STI engine Aldo the Apache Engine, Exhaust, Transmission 49 11-03-2011 09:36 PM
Ken Block Gymkhana 3 Midship Runabout Other Vehicles & General Automotive Discussions 24 09-14-2010 11:55 PM
