Old 11-09-2014, 09:27 PM   #141
Originally Posted by travisb View Post
EDIT: I read it again and it makes more sense now. You mentioned adjusting the pedal too. Why?
It's a precaution because of the increased throw of the clutch fork. I don't know how much disengagement it takes to damage the pressure plate.
Old 11-09-2014, 11:21 PM   #142
All, I'm thinking let's keep peer review discussion on this thread for now. Not sure how that will work out in the long run. Here's the DIY in progress.
DIY - Swap clutch slave for improved feel and control
Old 11-11-2014, 12:39 AM   #143
All, ask me some noob questions so I don't overlook them in the DIY - things that would keep you from attempting the work.
As I said earlier, I'm trying to think like a beginner. Should I include a little blurb on righty-tighty-lefty-loosy?
Old 11-11-2014, 03:11 AM   #144
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
What's a clutch?
The Following User Says Thank You to Andrew025 For This Useful Post:
Ultramaroon (11-11-2014)
Old 11-11-2014, 10:18 AM   #145
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
I think that may be a little too basic lol! I think anyone going to do this mod is going to have some mechanical aptitude, but I guess it wouldn't hurt? :P I'm mainly unfamiliar with the bleeding process and the precautionary measures needed.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
The Following User Says Thank You to Phantobe For This Useful Post:
Old 11-11-2014, 12:28 PM   #146
What's a clutch?
Old 11-12-2014, 09:47 PM   #147
DIY is finished. Go tear it up!
Old 11-18-2014, 08:24 AM   #148
Cdub998
Cdub998's Avatar
Drives: 2014 BRZ
So anyone that has completed this I have a few questions. 1st the clutch pedal has a dead spot now up top. Does that mean I should move it towards the floor more? Next I noticed that sometimes now the pedal doesnt come all the way back. Normal? Last how do you test to make sure the clutch is fully released when you let go of the pedal? Do you just drive it and see if the clutch smells?
Cdub998 is offline   Reply With Quote
Old 11-18-2014, 09:52 AM   #149
mike the snake
In the olden days, you adjusted that "dead" pedal travel at the top to 1/2'' and called it a day.
IMO there's too much dead pedal, resulting in the clutch not being actuated enough, which causes the hard to engage 1st.
If you have the 1/2'' of deadband, you shouldn't notice the pedal not returning fully.
A soft spring from the hardware (like for a screen door) store hooked to the pedal will have it returning fully, with no difference in feel.
IMO a LOT of the complaints of hard to engage 1st and creeping in 1st is due to improper adjustment.
The Following 2 Users Say Thank You to mike the snake For This Useful Post:
37 (11-18-2014), Ultramaroon (11-18-2014)
Old 11-18-2014, 10:39 AM   #150
37
degrees
37's Avatar
Drives: 6MT BRZ
Put the car up on a lift or jack stands with the rear wheels removed. Start the car, then push the clutch pedal and release it a few times. See if the rear end moves. If it remains stationary then you're probably close.
It sounds like your pedal height and master cylinder piston rod needs adjusted so take care of those first.
Agreed on both points.
37 is offline   Reply With Quote
The Following User Says Thank You to 37 For This Useful Post:
Old 11-18-2014, 11:14 AM   #151
What's a clutch?
Maybe for you one of these??????
Hey, how the hell did I even know that??????????????????????
Andrew025 (11-20-2014)
Old 11-18-2014, 12:02 PM   #152
When you say the pedal doesn't come all the way back, do you mean you actually have to hook your foot underneath the pedal to pull it up?
I think this might be due to the assist spring but would like to hear more details. Is that still installed?
Old 11-18-2014, 12:09 PM   #153
Cdub998
Cdub998's Avatar
Drives: 2014 BRZ
so there are times when I have to pull the pedal back up. I do have the assist spring still. It only happens like at most 2 times per drive.
Old 11-18-2014, 12:36 PM   #154
How much travel between floor and touch point? I think I made up the term "touch point" but it makes sense in my head.
That assist spring is on an overcenter cam so if you have the pedal adjusted really low I could see it interfering with return at the top. That's not good because that also means the throwout bearing is engaged the whole time. There's a valve in the master cylinder which opens when it reaches the end of its travel. It needs to be able to reach that point to fully release the clutch fork.
You can prove this to yourself by pulling the fork forward to compress the slave cylinder. Be careful if your reservoir is full. That fluid has to go somewhere.
Won't be able to do that even with the pedal slightly pressed because, the valve closes and now it's into the compression (actuation) mode.
As I think about this, I regret suggesting the second adjustment to further lower the clutch pedal after the cylinder swap. It's likely what caused your situation. Please let me know what you find. I'll update the DIY accordingly.
Are these fake? shu5892001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-11-2013 12:57 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
fake Bugatti anyone? bofa Other Vehicles & General Automotive Discussions 16 07-18-2011 02:20 PM
