Old 10-29-2014, 04:31 PM   #57
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
@Wonderbar
Any CFD testing on the Type 2 diffuser?
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 10-29-2014, 04:52 PM   #58
8R6
8R6's Avatar
Drives: FRS
Originally Posted by Wonderbar View Post
I'm now including rubber/foam sticky strips as part of the piece just for that reason.
do you still have this rubber strip?? My HKS muffler touches the type 2 diffuser in two spots and at 1700-1900 rpms, it buzzes like crazy
8R6 is offline   Reply With Quote
Old 11-10-2014, 07:13 AM   #59
troek
troek's Avatar
Drives: 2012 Toyota 86
So what was the consensus on how low the leading edge can go before it starts to catch air?
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
Wonderbar (11-13-2014)
Old 11-10-2014, 11:54 AM   #60
Gunman
Drives: 2019 Mazda Miata RF
My gut, and how I mounted mine, is to keep the leading edge as close to flush with the subframe, and everything forward of the diffuser.
The Following User Says Thank You to Gunman For This Useful Post:
Old 11-11-2014, 02:33 AM   #61
troek
troek's Avatar
yeah, thats what im thinking. i have a home made diffuser, and a tad lower than the suspension arms, and just a bit higher than the bottom of the rear diff. but that is still higher off the ground than the fuel tanks and what not. it hasnt ripped off at 140mph and at 80mph i still get great millage so im assuming it isnt catching any air, although i may have to do some streamer testing with a go pro.
Old 11-11-2014, 06:18 AM   #62
Gunman
Engine assembly lube works too. A few drops on the surfaces in question, drive it, and then follow the oil streaks. No need for the GoPro then.
Old 11-11-2014, 05:29 PM   #63
troek
troek's Avatar
good tip. back to the wangan this weekend lol.
Old 11-13-2014, 11:05 PM   #64
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
I can send you some when I get home, or you can use any foam weather strip from your local hardware or auto parts store. It's pretty much the same thing I use.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 11-14-2014, 03:04 PM   #65
8R6
8R6's Avatar
Drives: FRS
i dont mind getting some on my own, but my biggest concern was getting one that can withstand the heat temperature from a hot muffler and not melt lol
Old 11-14-2014, 07:02 PM   #66
Wonderbar
Driveway labs.
Wonderbar's Avatar
The mufflers don't get that hot where you're looking at putting it @BRGT86
Old 11-14-2014, 07:14 PM   #67
8R6
8R6's Avatar
Drives: FRS
oh werd. cool ill go pick some up then. thanks again man!
Old 11-17-2014, 12:05 PM   #68
Hoosier Daddy
Drives: '13 Denali, '15 Volt, soon a BRZ?
Is the mesh available?
Hoosier Daddy is offline   Reply With Quote
Old 11-17-2014, 03:37 PM   #69
Wonderbar
Driveway labs.
Wonderbar's Avatar
Mesh?
Old 11-21-2014, 04:43 PM   #70
Hoosier Daddy
Yes, the CFD mesh file used for computation.
aerodynamics, cargasm, diffuser, downforce, driveway labs
BRZ Rear Diffuser Kimsey47 BRZ First-Gen (2012+) — General Topics 72 06-06-2015 01:41 AM
Rear Diffuser. Jive Turkey Cosmetic Modification (Interior/Exterior/Lighting) 129 03-07-2014 08:21 AM
New Rear Diffuser garfull Exterior Parts (Aero, Lighting, Etc.) 1 07-19-2013 12:13 AM
FS:FR-S/BRZ OEM Rear Diffuser MrTranxD Exterior Parts (Aero, Lighting, Etc.) 3 03-25-2013 06:17 AM
Rear Diffuser? kombatlion Cosmetic Modification (Interior/Exterior/Lighting) 0 02-17-2013 02:38 PM
