Old 11-08-2014, 08:03 PM   #15
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
@FirestormFRS I had a filter while it was on it's just not pictured. It comes with a 3 in to 2.5in 90* silicone coupler.
glorydays is offline
Old 11-08-2014, 09:14 PM   #16
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Any chance we could get a few pictures of the main components? Uppipe, downpipe, FMIC, etc.
- The Ancient BRZ Sacrament
by Zaku
Guff is offline
Old 11-09-2014, 10:41 PM   #17
glorydays
Remember me?
glorydays's Avatar
@Guff ill take some pics of everything tuesday
Old 11-09-2014, 10:55 PM   #18
glorydays
Remember me?
glorydays's Avatar
a few more pics. no the computer did not stay there lol.
gt30 next to a 14b. it actually fits this kit but it needs something to attach it to the charge pipes.
Old 11-09-2014, 11:00 PM   #19
glorydays
Remember me?
glorydays's Avatar
Old 11-09-2014, 11:02 PM   #20
glorydays
Remember me?
glorydays's Avatar
oil return
Old 11-09-2014, 11:06 PM   #21
glorydays
Remember me?
glorydays's Avatar
that coupler has been replaced with a 4ply silicone
Old 11-09-2014, 11:10 PM   #22
glorydays
Remember me?
glorydays's Avatar
the coolant lines can be run underneath the instead of above the turbo.
Old 11-09-2014, 11:12 PM   #23
glorydays
Remember me?
glorydays's Avatar
Old 11-09-2014, 11:34 PM   #24
Guff
Guff's Avatar
Drives: BRZ LZR
What did you change with the up pipe when you got it reworked?
by Zaku
Guff is offline
Old 11-10-2014, 12:29 AM   #25
glorydays
Remember me?
glorydays's Avatar
It was angled too close to the frame and would occasionally rub so I had that section removed and straightened. It doesn't rub anymore.
The Following User Says Thank You to glorydays For This Useful Post:
Guff (11-10-2014)
Old 11-10-2014, 02:47 AM   #26
Guff
Guff's Avatar
Drives: BRZ LZR
Gotcha. So as far as clearance of all the parts goes, there's nothing else that could rub or otherwise potentially interfere with any other component?
Also, are the downpipe and uppipe 2.25" because there is not enough space for larger diameter piping or because that was the optimal diameter?
Lastly, did you use a bracket for the turbo in order to support it or is it just held by the uppipe and downpipe?
by Zaku
Guff is offline
Old 11-10-2014, 10:51 AM   #27
glorydays
Remember me?
glorydays's Avatar
No that was the only issue with the setup so nothing else should be making contact with other parts. The charge pipe almost rests on the alternate but it doesn't bother it at all. If I'd had the resources I would have had all the charge pipes pie cut and welded but it works great as is, just isn't pretty.
I wanted to keep continuity with the oem exhaust system which is why the pipes are 2.25. I figured I'd be using the front and mid pipes for awhile so I didn't think it'd make sense to go 2.5 back down to 2.25. There is room for larger pipes if they are designed closer together but that would require redesigning the entire kit pretty much. There isn't a bracket for the turbo but it is very firmly supported by the front pipe and header. It doesn't move much at all. This kit is pretty much the Works kit only with a larger turbo and FMIC. I think it could be potent in the right hands.
Old 11-10-2014, 01:31 PM   #28
Guff
Guff's Avatar
Drives: BRZ LZR
Cool! Another question: As far as the base map goes, do you have a rom that one could flash via a Tactrix cable and ECUflash? What exactly is the base map tuned to in regards to boost, fuel, etc.
by Zaku
Guff is offline
boost, turbo, turbo brz, turbo kit
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
- 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune aaronsadventures Member's Car Journals 6 12-04-2014 02:01 AM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
PTuning Turbo Kit GT3076R BNIB + 3" Exhaust sw20kosh Engine, Exhaust, Bolt-Ons 22 02-21-2014 02:24 PM
PRE turbo kit (garrett GT3076R) BRZPDX Northwest 90 01-18-2014 10:39 AM
