Old 11-09-2014, 08:07 PM   #1261
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Originally Posted by Fizz View Post
I'm curious how that looks...don't think I've com across any pics of the AT kit's oil pump. How is it driven? Electrically?
Nope, it's driven off the right side intake cam.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 11-09-2014, 10:41 PM   #1262
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Does it matter at which point along the brake booster line to fit a T-fitting (for the vacuum distribution block)?
Point A: would be closer to the intake manifold.
Point B: would be close to the brake booster.
What's the ID size of that line anyway?
And do I need to add a check valve anywhere on that line?
Fizz is offline   Reply With Quote
Old 11-10-2014, 12:11 AM   #1263
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
I doesn't really matter where. I wish the car wasn't at the body shop, I would have taken a picture of my setup.
Also, no check valve is needed...
The Following User Says Thank You to @Art_Mighty For This Useful Post:
Fizz (11-10-2014)
Old 11-10-2014, 01:28 PM   #1264
qtwre
Drives: White FR-S
There is already a check valve in the brake booster line. You should be able to notice a lump somewhere in it.
qtwre is offline   Reply With Quote
The Following User Says Thank You to qtwre For This Useful Post:
Fizz (11-10-2014)
Old 11-10-2014, 01:49 PM   #1265
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It has to be closer to the intake manifold or your vacuum distribution block will never see boost. That line already has a check valve in it that prevents the brake booster from seeing anything other than vacuum.
Fizz (11-10-2014)
Old 11-12-2014, 06:52 AM   #1266
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I've been told that the "turbo-airbox silicone pipe" comes very close to the crank pulley. Has anyone had rubbing or contact in that area on their kit?
Old 11-12-2014, 06:59 AM   #1267
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
In step 42-43 of the installation manual calls for the removal of the vertical metal bar in the back-middle of the radiators (in order to flatten the bottom part).
But it looks like the top part is actually spot welded to the radiator support bar. How did you guys take it off?
Old 11-12-2014, 08:50 AM   #1268
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The radiator support bar and the vertical metal bar come off easily with a few bolts on top and you are correct they are one piece and that is what you take out of car to flatten the bottom.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Fizz (11-12-2014), mwjcyber (11-12-2014)
Old 11-12-2014, 09:12 AM   #1269
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
The silicon and pipe run really really close to the pulley but there is no rubbing. I also change the bolts on the pulley with some flat head ones, just in case.
I didnt flatten the bottom of the metal bar because I completely forgot about it when reinstalling but no problems so far.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following 3 Users Say Thank You to Draco_PR23 For This Useful Post:
Astroboy (11-12-2014), Fizz (11-12-2014), Sportsguy83 (11-12-2014)
Old 11-12-2014, 12:29 PM   #1270
kbogarto
Drives: 2013 BRZ limited WRB
I purchased AVO stage 1 from Paul. I'll be installing it december 13th and having HRI tune it.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
The Following 4 Users Say Thank You to kbogarto For This Useful Post:
@Art_Mighty (11-12-2014), Astroboy (11-12-2014), Draco_PR23 (11-12-2014), SkAsphalt (11-12-2014)
Old 11-12-2014, 03:38 PM   #1271
Astroboy
Astroboy's Avatar
Drives: None
Make sure you have all the required components for the kit, before installing
Astroboy is offline   Reply With Quote
The Following 2 Users Say Thank You to Astroboy For This Useful Post:
@Art_Mighty (11-12-2014), kbogarto (11-12-2014)
Old 11-12-2014, 09:28 PM   #1272
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Really? when I took off those bolts on the top the latch mechanism came off but that radiator support bar looked like it was tac welded? What did I miss?
Old 11-12-2014, 09:32 PM   #1273
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Good luck Bro, welcome to the family!
kbogarto (11-14-2014)
Old 11-12-2014, 10:06 PM   #1274
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
What he meant was the since they vertical bar is welded to the radiator support bar, you'd have to undo the support bar as well, and then they come off together as one piece....like to giant "T" looking piece.
The Following 2 Users Say Thank You to Fizz For This Useful Post:
@Art_Mighty (11-13-2014), Sportsguy83 (11-13-2014)
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
