Old 09-20-2013, 12:35 PM   #15
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Do we need to use thread-lock on the bracket bolts? If so, what type would you recommend?
Fizz is offline   Reply With Quote
Old 09-20-2013, 02:40 PM   #16
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
awesome write up!!
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 03-27-2014, 01:27 PM   #17
amram
amram's Avatar
Drives: 2013 FR-S AT
Superbly detailed write-up. This is going to be very helpful. Thanks!
Wondering how important the greasing of the slide pins (and slide bush also as per service manual) is when just changing out OEM street pads for a track day assuming you are going to change back the next day to street pads again......
"That's why I like the GT86 so much..... It's a car designed for one thing only: fun." - Jeremy Clarkson
amram is offline   Reply With Quote
Old 11-09-2014, 11:36 PM   #18
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Just wondering: I am going to replace a front hub assembly (yay wheel bearing!).
I really just want to remove the rotor - will I need the caliper piston tool?
Will the pistons compress if I just slide the caliper/pads away from the rotor?
Thanks!
daiheadjai is offline   Reply With Quote
Old 12-20-2014, 09:50 PM   #19
kodyo
Drives: Scion FR-S
Originally Posted by F1point4 View Post
Thanks for the write up! It helped a lot today when I changed my pads and rotors out. Couple of comments.
1) For removal, you can actually use the same bolts that hold the aluminum under panel to the car. No need to buy any bolts.
2) These shims can actually come off, they are only stuck to the pad with grease and the way the shims clamp to it.
Sorry for quoting pictures, just figured it would be easier for others coming into this.
kodyo is offline   Reply With Quote
The Following 3 Users Say Thank You to kodyo For This Useful Post:
brz7400 (08-13-2016), Slammedsteve (06-18-2016), tobin (04-18-2020)
Old 12-21-2014, 12:03 PM   #20
Weasel Soup
Veteran RallyCrosser
Weasel Soup's Avatar
Drives: 10 Series FR-S, 95 Escort Rally Car
great write up
i vote for a sticky
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal
2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive
Weasel Soup is offline   Reply With Quote
Old 12-22-2014, 01:47 PM   #21
willypongtb
P MAI86
Drives: subaru brz limited
nice thanks for write up
willypongtb is offline   Reply With Quote
Old 12-22-2014, 02:57 PM   #22
CatDaddysBBQ
Drives: '13 FR-S
Originally Posted by Weasel Soup View Post
great write up
i vote for a sticky
Agreed. This was very thorough and well photographed. Sticky it!
CatDaddysBBQ is offline   Reply With Quote
Old 12-02-2015, 09:35 AM   #23
richmond
Drives: 86
I installed DBA T3 today and I did not compress the pistons. the thickness of DBA and OEM is the same.
richmond is offline   Reply With Quote
Old 01-27-2016, 04:01 AM   #24
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
@F1point4 is it crucial to bleed your brakes immediately (or at all) after this process? Is it fine to drive the car with the new brakes and rotors to a shop so they can bleed your brakes? That's the one thing I'd honestly like to not DIY.
Keenercarguy is offline   Reply With Quote
Old 01-27-2016, 10:45 AM   #25
dp1
driving smoother faster
Drives: Sold
It is not necessary to bleed your brake fluid just because of rotor or pad replacement.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
Keenercarguy (01-27-2016)
Old 01-27-2016, 10:57 AM   #26
kodyo
Drives: Scion FR-S
No, it's just a convenient time to do so.
The Following User Says Thank You to kodyo For This Useful Post:
Old 01-27-2016, 02:29 PM   #27
Keenercarguy
Mountain Runner
Whew good that's what i thought but his last picture was ambiguous as to whether or not it was necessary, wanted to be certain.
Old 08-13-2016, 08:49 PM   #28
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Big thank you for where to find the bolt to pop off the rotor!
Was replacing a broken rear wheel stud today and after banging on the disc to no avail and no good way to go buy a bolt, "borrowing" the bolt from front cover saved me from further profanities!
brz7400 is offline   Reply With Quote
The Following User Says Thank You to brz7400 For This Useful Post:
kodyo (08-14-2016)
brake pad, brake rotor, diy
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
R1 Concepts rotor, and brake pads ExtremeAutowerks Brakes, Suspension, Chassis 37 12-23-2013 03:39 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-25-2013 12:26 AM
Brake rotor differences between base and Sport-tech BRZ Sport-Tech CANADA 10 04-12-2013 08:15 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
