Old 11-08-2014, 10:05 AM   #1
OPGForce
Drives: 2014 BRZ
MTEC Shifter Springs - Long Term Impressions?
For those of you that have had this mod for quite a while, do you feel it still makes a difference? Also, please list your other tranny mods. ie.) bushings, short shifters, synthetic fluids, etc...
OPGForce is offline   Reply With Quote
Old 11-08-2014, 10:09 AM   #2
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
I still feel a crisp firmness to the shifter that I originally got. It was one of the first mods I did. I may be slightly biased since now the feel is muddled by my trans bushing/mount, shifter mount, diff mount, subframe mount, motor mounts haha. I can't definitively attribute it to the shift springs but most other transmission feels sloppy to me now. It does still let me return to center a lot more confidently so with that yes I still thing it was worth doing.
zkv476 is offline   Reply With Quote
Old 11-08-2014, 10:41 AM   #3
zooki
Drives: waiting on a 2021...
Love mine. I have the springs, a Kartboy shifter, Kartboy trans mount stiffener, Perrin rear shifter bushing, and Pentosin fluid. Feels like a well oiled rifle bolt. Definitely recommend!
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 11-08-2014, 10:52 AM   #4
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
X2 love mine can't wait to put same setup in our second car
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 11-08-2014, 01:59 PM   #5
akahenry
akahenry's Avatar
Drives: '18 STi
If you're on the fence whether or not to install the springs, I say do it. You'll immediately notice the difference from the stock springs and the Mtec Springs. With my current set up of the KartBoy Short Shifter, Kartboy Shifter bushing, and the Mtec Shift Springs, shifting is stupid easy and effortless (relatively). I think combined with the Mtec Springs combined with a Short Shifter, daily driving the 86 will be even more easy than it already is.
akahenry is offline   Reply With Quote
Old 11-08-2014, 03:30 PM   #6
twag4
Drives: frs
I still like mine. Still very positive gear engagement/disengagement, and easy to find neutral. They also helped with 4th to 5th gear selection, as it was an awkward transition for me when the car was new. I also have the whiteline transmission bushing and perrin rear shifter bushing. All made the shifter much, much better. It is a bit notchy, but notchy is not bad if not accompanied by vague shifting. The shifter is direct, not vague in the least, and has very positive engagement.
twag4 is offline   Reply With Quote
Old 11-09-2014, 02:10 AM   #7
jflogerzi
jflogerzi's Avatar
Love mine. Very big difference even in a stock car with just the springs. No regrets here
2013 Series 10 FRS #553
Old 11-09-2014, 08:19 PM   #8
Nardi330
Nardi330's Avatar
Drives: 86
love mine as well. well worth the money!
Nardi330 is offline   Reply With Quote
Old 11-09-2014, 11:20 PM   #9
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
I have the Billet Pro short shifter and the Perrin shifter bushing and when I installed the springs I honestly felt no difference. Maybe because I had a couple other mods on for the same thing.
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 11-14-2014, 05:14 AM   #10
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Anyone tried these with the TRD quick shifter? The shifter is very stiff with this kit and takes a bit more effort to get into gear, so was wondering if by increasing center spring force, might make the 4-5 easier. Very tough to do quickly with the TRD kit
xxBrun0xx is offline   Reply With Quote
Old 11-14-2014, 06:53 PM   #11
zooki
I would think it would make it more difficult since the springs will hold the shifter centered with more spring pressure. I would think that would make it harder to push the shift off the centerline.
Old 11-14-2014, 09:23 PM   #12
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Better question is....who has the mtec clutch spring? For the low price maybe I'll just try it out without any feedback from other users
Definitely get the shift springs though.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 11-14-2014, 09:55 PM   #13
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I have them both.
I never had trouble with 4-5 with the stock shifter, or with the TRD QS, or with the MTEC springs. But having both of them has made 5-4 even easier.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 11-15-2014, 01:25 AM   #14
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
I just picked up the clutch spring but I'm hesitant to install without any feedback plus I've kind of gotten used to the light clutch pedal. I'm sure I'll end up installing it anyway though. Worst case I can always switch it back.
Sent from my Galaxy S4 using Tapatalk
AllStar0419 is offline   Reply With Quote
>>>FT-86 SpeedFactory<<< Kartboy Short Throw Shifter Kits and MTEC Springs FT-86 SpeedFactory Transmission and Driveline 267 12-11-2016 09:20 PM
FS: Mtec Shifter Springs unlimited86 Transmission and Driveline 2 08-27-2014 04:19 PM
MTEC Industries Stiff Shifter Springs for 2013-2014 BRZ & FR-S YURparts Transmission and Driveline 16 08-07-2014 11:31 AM
MTec Industries Shifter Springs xravexboix Transmission and Driveline 2 04-24-2013 12:39 PM
