Old 11-04-2014, 05:13 PM   #1
frs10
Drives: tezla
AT - shift from 1-2?
anyone else get a strange jerk from the car when shifting from 1 to 2 in manual mode under 4k RPM or is it just me?
frs10 is offline   Reply With Quote
Old 11-04-2014, 06:34 PM   #2
Sithspawn
Drives: '14 Hot Lava FR-S w/Flappy Paddles
Yes. How many miles do you have on your car? Have you done any spirited driving with it?
Sithspawn is offline   Reply With Quote
Old 11-06-2014, 11:09 AM   #3
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Yes I get that too. I track my car regularly and I noticed the tranny shifts smoother after I change the AT fluid.
Tye300 is offline   Reply With Quote
Old 11-07-2014, 04:10 PM   #4
frs10
Drives: tezla
22k~
and yeah, who doesnt...
Old 11-07-2014, 09:33 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
22k~
Apparently the owners manual says its for 100k and 30k after that which is extremely stupid, someone got a quote to replace the fluid at a Toyota dealer for $265, but your better off replacing it with a non-oem at every 30k with like Redline High Temp ATF, you will never get all the fluid out of course....
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Sithspawn (11-08-2014)
Old 11-08-2014, 10:28 PM   #6
Sithspawn
22k~
Yeah...I hear you. I really wish this car had come with better transmission cooling from the factory. After a couple spirited drives, my trans starting getting rough on the 1 - 2 shift as well. At only 11k on the clock, the viscosity of the fluid per a Blackstone analysis was significantly less than it should be (thus causing the rough shifts). If you want some good reading, check out this thread: http://www.ft86club.com/forums/showthread.php?t=61498
The only way a person can realistically run the factory trans fluid for 60k per the owner's manual is if they're driving Miss Daisy.
Old 11-09-2014, 01:30 AM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I thought the owners manual said 60k?
Old 11-09-2014, 01:52 AM   #8
FRSBRZGT86FAN
woops wrong stat
http://www.fr-sforum.com/forums/fr-s...formation.html
Old 11-09-2014, 03:40 AM   #9
10Stars
Drives: 14 Subaru BRZ Limited WRB
Happens to me as well.
I always thought it was normal? I know it doesn't happen in the higher rpms though
10Stars is offline   Reply With Quote
Old 11-13-2014, 12:22 PM   #10
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I always assumed I was just bad at manual shifting. The auto shifts perfectly smooth in full auto mode. But in manual mode it can be jerky, especially if it's cold. Once it warms up it's a bit smoother. I'll see if they'll change the trans fluid under my lease agreement, but they won't even give me windshield wipers so we'll see haha
Nevermore is offline   Reply With Quote
Old 11-13-2014, 12:48 PM   #11
frs10
Drives: tezla
so has anyone changed the fluid and shifts are smooth now?
AT can be jerky when cold
Old 11-13-2014, 12:56 PM   #12
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Subd
Old 11-13-2014, 01:08 PM   #13
FRSBRZGT86FAN
In the maintenance section alot of ppl replaced it after autox and immediately noticed a difference
Old 11-14-2014, 03:56 PM   #14
frs10
Drives: tezla
but for us regular drivers that dont track...
FS: WeatherTech Mats/Shift Knob/Shift Boot/Sunshade (WI) wgnzlz Interior Parts (Incl. Lighting) 8 06-09-2014 09:36 PM
How would you shift from 4 to 5? qqzj BRZ First-Gen (2012+) — General Topics 37 05-01-2014 08:10 PM
WTB TRD shift knob Vlady Interior Parts (Incl. Lighting) 0 04-17-2014 12:28 AM
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 02:54 AM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 01:11 PM
