Old 11-06-2014, 09:15 AM   #1
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
sub in the rear speaker location
Has anyone done a low profile sub enclosure to replace the rear speaker? It seems like a shallow mount sub would fit nicely in that locations, perhaps a 8" or maybe even a 10"?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 11-06-2014, 10:41 AM   #2
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Definitely would fit nicely with a custom enclosure. Biggest issue I think you would come across is massive rattling from the factory panel. Best plan would be to get rid of the panel all together and have a custom fiberglass box made to cover what the panel did and carpet it.
Too much weight to be worth it IMO.
Flat Black VW is offline   Reply With Quote
Old 11-06-2014, 10:44 AM   #3
aznatama
aznatama's Avatar
Can't weigh that much more than a custom trunk enclosure though... Hmmmm. If only someone made this. I'd buy the oem+ system if it had a sub in this location.
'14 BRZ LTD MT DGM
Old 11-06-2014, 12:28 PM   #4
toast
Drives: 14 BSP Edelbrock BRZ
I'm working on this. First version used an 8" and I'm not happy with it, going to modify it for a little more volume and use a 10" thin mount alpine driver.
My pics are interspersed with AtlasMick's in the following thread:
http://www.ft86club.com/forums/showthread.php?t=66561
toast is offline   Reply With Quote
Old 11-07-2014, 05:18 PM   #5
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I'm going to install the SI BM MKIV 12" subs in my rear speaker locations. The mounting depth is 3.3" and only requires .5 cu ft airspace. I'm going to do something similar to what @toast did as far as the enclosure.
kmbkk is offline   Reply With Quote
Atermarket Speaker crossover install location AL008 Electronics | Audio | NAV | Infotainment 9 10-17-2016 11:37 PM
Rear Tow location with Rocket Bunny Diffuser stevo_12v Cosmetic Modification (Interior/Exterior/Lighting) 4 08-27-2016 02:35 PM
Requesting Part Numbers for: '14 FR-S Knee Pads, Front Speaker Covers, Rear Armrest jbsali Cosmetic Modification (Interior/Exterior/Lighting) 1 02-26-2014 06:22 AM
6x9's Stealth install - rear speaker replacment GTS86 Electronics | Audio | NAV | Infotainment 7 10-16-2013 09:55 AM
ECU box location?? RehabJeff86 Electronics | Audio | NAV | Infotainment 2 09-18-2013 02:34 PM
